Question about Philips 42PFL5603D - 42 IN. LCD HDTV
Need inverter board 42pfl5603d/27
No picture on screen
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: model #42PFL5603D/27, approx. 2 yrs old. Fine one
You have to check the 24vdc power supply to see if it is putting out the voltage or the backlight inverter board has failed. Disconnect the inverter board and see if the 24vdc come back.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 11, 2010
  • 19 Answers
SOURCE: Philips 47pfl7403d/27 screen blanks, i
no, this is the t-con board, some panels have the inverter built in to the panel and some have the inverter as part of the power supply board. if you see two pairs of wires with extra clear plastic sheathing comming off the power supply, then the inverters are part of the power supply board. most likely the culpret. if this does not fix it, then one or more of the lamps in the panel are shorted keeping the rest from lighting. if that is the case, you are screwed...the lamps cant be replaced,the entire panel has to be replaced.
Posted on Aug 19, 2011
Why does it have sound but no picture?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 16, 2016 | Philips 42PFL5603D/F7 LCD TV
Picture will not show, even when its on the correct source, and all the connections are hooked up properly.
Are you getting black screen? Still under warranty?
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Jan 01, 2011 | Philips 42PFL5603D/27 42 in. LCD TV
My 27' tv has sound but no picture at all
Now,the tv turn on u have a picture flashes few sec.than dies have sound lelf only?Yes,the tv have 1 or 2 long boards that call the LCD inverter boards are dead.These 1 or 2 Long LCD inverter boards job are to help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbihes 1 or 2 long LCD inverter boards for the replacement.
Dec 11, 2010 | Akai LCT2715 27 in. LCD Television
When i turn on my tv it stays on the philips screen. never goes to tv. i tried unplugging it and leaving it unplugged for an hour, no help
You give insufficient information to provide you with a more streamlined solution, so excluse me for being too brief.
What I'd do if I were you is to try and re-flash (update) the firmware in your TV.
if that doesn't help you'll likely need a new main board.
TO update the firmware you'd need the exact model of your Philips. 42PFL5603D has two versions - /F7 and /27.
The update for the first is at
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL5603D/F7&slg=en&scy=US&mid=Link_Software
The second is at
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL5603D/27&slg=en&scy=US&mid=Link_Software
Those are Philips provided and supported pages, so you should be able to find your way around there.
Hope this helps. If it does, please rate it with thumbs up - we need your votes if we can't get your money :-)
www.coppelltvrepair.com
Oct 18, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
The picture wont come on but the sound will
the picture on your TV won't come on because the picture board of your TV has developed fault.
The best thing for you to do now is to take the TV to a local repairer within your vicinity, because the fault is not something you can fix yourself.
Good luck.
Apr 14, 2010 | Philips 42PFL5603D 42 in. LCD HDTV
Red light flashing
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
Aug 09, 2009 | Philips 42PFL5603D/27 42 in. LCD TV
Philips 190B - flickering screen
Its looks that Inverter board not work well for CCFL cus a CCFL inverter is a device (an inverter) for providing drive power to a Cold Cathode Fluorescent Lamp CCFL
Jun 17, 2009 | Philips 190B6CB/27 19" LCD
Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
27" Philips flat screen
the color tubes are either miscalibrated or going bad.
Jan 13, 2008 | Philips Magnavox 27MS343S 27" TV
Philips 42PFL5603D - 42 IN. LCD HDTV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
