Question about Vision Panini My X 60 Check Scanner
Makes shaking noise - Vision Panini My X 60 Check Scanner
When i turn my camera on it makes some noise. Until i shake the camera, noise disapeare, but it could come againe at any time...
The hardware inside is defective. You will need to replace the camera either by warranty or buy a new one. Make sure you save your pictures!
Jan 08, 2014 | Panasonic Lumix DMC-TZ1 Digital Camera
Motor makes a noise
The motor will make a noise as that's the sound of the gears miving along the lens. I wouldn't shake the camera if I were you though.
Car shakes when coming off the hwy
Great to hear you fixed it.
Jul 21, 2012 | 1999 Lexus ES 300
Vacuum shaking badly right up to handle and very loud noise
Could be a broker motor retainer. There should be two motor retainers in this model, when one is borken, it causes the unit to
shake and vibrate.
May 13, 2010 | Hoover U5507900 Elite Rewind Bagless...
Everytime i turn on and off my A200(sony DSLR) it shakes and makes noise,, and before it focuses on something it shakes and makes alot of noise?? wahts wrong with it?
It is not your camera, it is your lens, The af lens trying to engage and the gears are grinding. Just for verification go to your nearest camera store and try a different lens on your camera. They will not shake like yours.
Jan 10, 2010 | Sony Alpha DSLR-A200 Digital Camera
ENGINE MAKES NOISE,SHAKES
The engine is probably misfiring. You can verify if the engine is misfiring unplugging one spark plug cable at the time. If you have not done this before, better going to a mechanic and have the engine checked.
Jul 12, 2009 | 1998 Ford Aerostar
Wheel or brake is making noise and shaking when applying brake
This could be one of 2 problems,a warped brake rotor or bad wheel bearing.
May 05, 2009 | Chrysler Town and Country Cars & Trucks
SHAKING AND KNOCKING NOISE
it could be tht the exhaust pipe is loose and therefor makes shaking and kinda banging noise. hope i helped! ;-)
Jul 26, 2008 | 1994 Jeep Grand Cherokee
Amana NAV8800AWW making noise while running and spining. It used to shake the floor while spining. But lately machine is making noise but not as shaky as it use to be. Thanks for your help.
Spin Shake is usually contributed to a weak floor support condition. Also, carpeting under the leveling legs can cause a "spongey" effect, which can produce the shakes. Prolonged shaking can cause parts to loosen and make noise.Firstly, we must determine what loosened up from all the shaking.
Remove the front panel by removing the 2-5/16" screws located at the bottom front. Pull out at the bottom to release the top retainer clips, and set aside.
Warning! Never reach inside the machine while it is in operation!
Investigate the cause of the noise by setting the washer to spin, and turn on. Inspect all moving parts for possible wear or breakage. Next, stop the machine and inspect for loose or worn suspension parts, nuts, bolts, struts, hoses banging the cabinet, etc. A protective motor cover can cause noise, or a belt slapping the base mount. Once you have conquered your noise issue, then we will have to eliminate the shakes, provided, what you repaired wasn't the cause...and usually isn't.
Carpeting under the leveling legs should be removed or cut away.
If other items in and around the laundry room shake, then you will need to add support to your floor joists. Shim the floor from under the house while the washer is spinning for best results.
Your installation instruction manual should tell how level the washer properly, after you have added support to your floor.
Good Luck! Post me back if can be of more assistance.
Dave E. (Illeagle)
May 20, 2008 | Amana NAV8800E Top Load Washer
IT WORKS GREAT
Are you holding the play button when shaking?
Mar 06, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Top Vision Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Vision Office Equipment and Supply Expert? Answer questions, earn points and help others
