Question about Samsung Maxima Zoom 105GL 35mm Point and Shoot Camera
Dead battery primary 3volt lithium battery is good. Is there another battery? If so how do I change it?
  • 20 Answers
Yes, there is almost always a secondary battery for things like the time and date, they usually do not make it easy to get to this battery. For a point and shoot you'll need to take apart the camera.
Diane
NYC Photo Safari
Posted on Apr 29, 2014
Bad back-up battery
If the computer cannot keep the Date and Time after you set it and when you boot up next time the Date and Time has changes or not set then the BIOS battery is flat and needs to be replaced.
When you remove the case the BIOS battery most likely will be a coin size 3volt lithium battery, type CR2032.
After replacing the BIOS battery, boot up the computer and go into the BIOS setting and set the Date & Time etc.
Jun 13, 2012 | Compaq Presario S4000NX (DF213AR) PC...
How do i replace back up batterry (cmos) in my desktop presario
The BIOS battery in most desktop motherboards is a coin size lithium battery approx. 20mm in diameter. The most common type used is a CR2030 3volt lithium battery.
To release the battery, press the metal clip to the side and the battery should pop up.
Nov 26, 2010 | Compaq Presario SR1050NX (DW257A) PC...
New Ryobi 18v lithium battery goes dead after a couple of seconds. Is there any solution other than returning it?
No, just return it, for the money they should give you one that works. It is common to get a defective Ryobi 18v lithium battery. I've had 2 out of 7 purchased that wouldn't hold a charge. But when you get a good one they work awesome!
Jan 24, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Hi. The clock on my Acer will not keep the correct time any more and it doesnt change dates on the calendar either. Do I need to change a battery in my motherboard?
If you change the BIOS date and time and when you boot up next time and the date and time has changed back or is incorrect, then the most likely fault is a flat BIOS battery. Replace the BIOS battery, it maybe a coin type lithium 3volt battery. this is the most common type used in motherboards is a CR2030 lithium battery.
Nov 03, 2009 | Acer Aspire 5630 Notebook
Clearing cmos
The BIOS battery maybe under one of the panels on the bottom of the laptop or under the keyboard.
To reset the BIOS ack to the default settings, go into the BIOS configuration and look at the various configurations, usually there is a setting to load the Default settings, then save and exit, and this would not change the Date & Time setting.
The other way to set the BIOS default setting is to remove the BIOS battery (it is probably a lithium 3volt button battery), wait 1/2 hour and replace the battery, the go into the BIOS configuration and set the Date & Time setting etc.
Jul 04, 2009 | Compaq Computers & Internet
Where can i find the internal battery
The BIOS battery could be under the laptop under one of the panels, or it could be under the keyboard. The battery most likely a lithium 3volt battery.
Jun 27, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hi the cmos battery on my m450c needs replacing but I do not know how to access it
Not sure on your model laptop. The battery is usually a 3volt lithium button battery approx the size of a small coin.
The battery could be located on the bottom of the laptop under one of the scewed panels to one side of the opening or it may be under the keyboard.
May 08, 2009 | Computers & Internet
Blinking film on screen.
Sounds like the batteries went dead, and the internal lithium memory battery was already dead, causing it to forget the settings. install fresh batteries, and reset the ISO of youtr film by holding down the ISO button, and pressing the up/down buttons behind the shutter release. That should return it to normal, but you will have the same problem again whenever you are changing the batteries until you replace the lithium cell. To change the lithium cell, remove tha battery pack, and open the metal plate in the camera's battery compartment. The cell is a lithium CR 2016.
If that does not fix it, you may have a broken camera.
-John
Sep 03, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Hi, Ive got a BT Contour 100 Payphone, but there is no dial tone or display. Cheers
You need to dismantle phone and replace Varta CR1/2AA 3Volt lithium battery. Dismantling is easy enough but you MUST lay out the screws etc so they go back in the right place, particularly the one with the two nylon washers underneath the head.
Apr 23, 2008 | Lands Phones
Samsung Maxima Zoom 105GL 35mm Point and Shoot Camera Logo
115 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
