Question about Symantec Winfax Pro 10.03 (winfax10.03) for PC
When I type in phone numbers the program shuts down
When i type in phone numbers the programme shuts
Posted on Aug 29, 2009
  • 143 Answers
SOURCE:
How to program numbers in for speedy dialing
To program speed dial on a non smart phone hold down the 2 key and it will prompt you to type in the number you want assigned to that key. Then do it for the rest of them.
Mar 17, 2011 | Cell Phones
This afternoon, i was trying to type my password with the number pad when all of the sudden, i got shut down. Apparently, the number pad ''4'' is the one that caused me to shut down twice =.=. When i typed...
seems to be a problem with keyboard layout. click on start--control panel--language and regional option and change keyboard layout according to ur country.
Dec 13, 2010 | E-Machines eMachines Desktop PC
How to assign and extension to a DSS key on a samsung dcs 12B
Hi, to programme a softkey on the samsung DCS you must first enter customer level programming;
with the handet down press TRANSFER 200, 1234 , 1 to enable, then the blue speaker key,
now type in 722 followed by the extension number of the phone that you want to program, this will be in brackets, next type the number of the button to be programmed.
Next using no.3 on your keypad (to get to D) then +/- again until you see DS follow this with the ext. ie DS210.
Transfer brings you out.
I have posted a video to show you how its done too, you might want to look at the other 60+ videos from abbeytel.
Jun 09, 2010 | Samsung DCS 12 Corded Phone
All i do is click shut down but it doesnt do anything at all. what should i do?
CTL,ALT.DEL select task manager under there you should see that there is a program that is not shutting down thus causing your issue. You need to shut it down before shutting down the computer again. Otherwise hold down the power button to FORCE SHUTDOWN.
Thanks and do be considerate when leaving feedback and ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 29, 2010 | Dell Inspiron Mini 10 Notebook
Placed password shut phone down
Which model are you wanting help with - You mention both the 8300 and 8900?
In any case - The 8300 doesn't have a reset button? On the 8900 it may be behind the battery cover if so you will need a paper clip.
The following advice is general to Blackberry's and will help clear the memory and reset issues - These are both the soft and hard reset.
You can do a soft reset using Left Alt, Right Shift and Delete - Hold down keys simultaneously for a couple of seconds.
If that doesn't work - Try power down, remove the battery for a minute or so, re-insert battery and then power back on.
Let me know how you get on with the above - If they don't work - Can you also clarify which model no as I have given you generic advice for both models...
Jun 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Keyboard typing extra letters >.<
Sounds like the windows key is stuck down, pressing start+r opens run, start+e opens explorer etc. The start key being the one between control and alt.
May 25, 2009 | Computers & Internet
what you need to do now is take the phone to a mobile service center and have the mainboard fix or flashed....jun error means that the unit is going bad.
money_kohil - after the passowrd was enter incorrectly 10x then take the will blank and reset to its default and clear al saved data.....if it s not powering up after that then you will need to take the phone to a mobile service center.
Dec 27, 2008 | RIM BlackBerry? Curve 8330 Cellular Phone
CHANGING THE RINGTONE
Depending on your model system, it may or may not be possible. I included the two different methods to change the ring tone below depending on your system. Give it a try.
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Program Press the CO Line key you wish to change
Press the same key again, enter the tone number (01 through 30)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 02, you will hear the tone associated with tone type 22. Press each number (01-30) until you hear the tone you desire.
Press STORE
img%20right%20hand.gif The tone is now stored for that line on that phone only.
Press PROGRAM 99 (or PAUSE 99 if you do not have a PROGRAM button
Press the same key again, enter the tone number (1 through 8)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 2, you will hear the tone associated with tone type 2. Press each number (1-8) until you hear the tone you desire.
Press STORE
Mar 20, 2008 | Panasonic KX-T7730 Corded Phone
Iphone.........week number 47
Press and hold the power/home button till the screen gose black.(before the apple logo appers)
then plug iphone into your PC and hold home button down,
iTunes will see the iphone as a new phone.
Now do a restore on your iPhone in iTunes.
Hope this helps!
Jan 06, 2008 | Apple iPhone Smartphone
Symantec Winfax Pro 10.03 (winfax10.03) for PC Logo
109 people viewed this question
Top Symantec Computers & Internet Experts
Peter Dragonetti
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
