How do I get a cable from the engine compartment to inside the car
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
First off your going to need a few things..: an old metal hanger cut to a piece 6"-12" long,a flashlight, and electrical tape or duct tape.
First your going to get down so you can freely look under your dash with the flashlight. It may be necessary to remove the big plastic cover under the dash where your knees are.
What you are looking for is anywhere that there are existing wires in bundles going through rubber grommets, before you do anything else, look carefully and see if you can find a rubber grommet blank ( no wires), if there is none to be found, then we are going to use an occupied grommet.
If you do find a blank, find that grommet on the opposing side of the firewall. Once you have found it, grab your hanger rod and wire. Take your wire end and overlap the end of the rod and tape it securely to the rod.... Now you have a giant sewing needle to push through the blank grommet and pull the wire through.
If you do not have a blank and just occupied grommets, take your hanger rod and put a very slight bend in it, 10*~15* . Tape your wire to the end of the rod. Your going to move your wires to the side a bit and use your giant needle and push through the grommet along side the wires with it curving back outward so you do not cut any wires.
I hope this was very helpful and not complicated
Posted on Apr 15, 2014
Every now & then my etc light comes on , my truck loose power and i have to pull over then shut it off then turn it back on runs fine till the next time it does it , how do i fix it
You could have loose battery cable connectors at the battery. However you also need to check the other ends and also check a short flat cable that grounds the engine to the firewall of your vehicle. Firewall is inside your engine compartment which along the backside of the engine where all cables and come from and connect to the motor.
Feb 03, 2018 | Cars & Trucks
Crossed up cables while jumping car cables started to smoke switch cables on battery to the right way car started.. but now now car will not go more than a 1000 rpms, when I give it gas nothing happens...
I would start by checking all of the fuses in your car. You have one fuse box under your steering wheel and one inside the engine compartment. You could have blown a fuse controlling the computer related to the acceleration or transmission system.
Mar 24, 2015 | 2009 Ford Fusion
Kia sportage fuel pump fuse in passenger compartment
Nothing between the fuel pump relay in the engine compartment and the 10 amp pump fuse inside the car.
Jan 16, 2014 | Cars & Trucks
Where is the location for the blower motor relay on a 1998 Nissan Quest?
Firewall is the wall that separates you from the engine compartment. Everything that goes from the inside of your car to the engine i.e steering shaft, throttle cable, heater hoses etc. goes through the firewall. Hope that clears it up for you.
Oct 31, 2012 | Cars & Trucks
94 jetta oil alarm light sounding and flashing
Could be 2 separate issues. Try locating your oil sensor inside the motor compartment and see if the wire is unplugged. if not you might need to replace the sensor (cheap fix). As far as the speedometer, try following the cable to the side of the ******. a lot of times they get twisted and just break. call a parts house and see how much one is. You actually just replace the inside of the cable usually. Both are fairly cheap fixes. Check fuses first to make sure there arent any blown ones. There are some under the dash and in the engine compartment. Good Luck. should not be too hard to fix both. Good Luck
Apr 10, 2012 | Volkswagen Jetta Cars & Trucks
WHERE IS THE HEATER CORE REMOVED FROM? ENGINE COMPARTMENT? OR INSIDE UDER DASH? I HAVE 2 REPAIR BOOKS - 1 SAYS ENGINE & ANOTHER SAY INSIDE
toosharp2004, The easiet way to find what you are looking for is to follow the heater hoses from the engine. If they go through the fire wall then the core is located inside but if they end up at a box in the engine compartment then this is where you will find it. Based on the year of your car I think that GM put them inside under the dash in the middle. Good luck with this.
Apr 10, 2011 | 1989 Buick LeSabre
Can not locate horn relay in a 1998 sunfire looked in manuals and does not show if it is inside the vehicleor in engine compartment looked in engine compartment could not see it
Most relays are in fuse/relay boxes inside the engine compartment. There may be several of these boxes in various locations.
Oct 18, 2009 | 1998 Pontiac Sunfire
I have a 1991 Lexus 400. It cranks but won't start.If it does start it stalls or runs perfectly for days.Any thoughts??
Check battery cables. MAke sure they are on tight, and not corroded. Check ground wires inside the engine compartment, and even inside the car, for tightness. Try a good fuel injector cleaner, like Lucas.
Aug 27, 2009 | 1991 Lexus LS 400
The heater only blows hot air
You didn't mentioned the model year of your Ford, but you might try lubricating the heater control switch which is located in the engine compartment side against the firewall. If you have someone try to move the temp knob inside while you look in the engine compartment, you might find the control valve. Once you find it, check to see if the cable is still connected, then try lubricating it with some WD-40 at 1st to get it sliding like it should. Once the cable is opening and closing the valve like it should, you will notice the temps adjusting like they should. Good luck!
May 08, 2009 | Ford F-150 Cars & Trucks
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
