Question about Kenmore Elite 45986 Front Load Washer
I have F 06 error code on my washer - Kenmore Elite 45986 Front Load Washer
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 13 Answers
Hi there
an F06 problem usually relates to a long drain problem the solution could mean one of the following but best to star with the least expensive first.
1.ensure that you have emptied the clog filter ( this filter usUSA.y at the bottom left of the machine behind a small door,
place a cloth on ground, unscrew the plug, some water comes out, and hopefully something that has prevented it draining correctly.
2. Ensure their is no kinks in the drainage hose ( usually a 1inch flexy hose at the back of the machine that will run into a hard plastic drainage waste pipe)
3. The pump may be a goner
4. If the heater has failed the washing machine will not drain your clothes correctly, this is an often overlooked cause when it comes to draining problems
hopefully your problem will be number one or two (DIY jobs)
good luck either way.
Posted on Apr 16, 2014
What dose it mean AE6 error code in Samsung wash machine
SAMSUNG WASHER FAULT CODES: AE or AE6
SAMSUNG WASHER ERROR DEFINITION = communication errors sub and main PBAs - main and inverter PBAs
AE and AE6 represent communication errors between the sub and main PBAs or the main and inverter PBAs.
HOW TO REPAIR/CLEAR ERROR?: If either of these errors is displayed, troubleshooting is needed or service is required.
http://removeandreplace.com/2016/06/15/samsung-washer-quick-troubleshooting-guide-error-code-definitions/
Feb 17, 2017 | Samsung Washing Machines
06 error code 110 on an affinity washing machine Frigidaire
Hello Jenny, thank you for your inquiry!
I understand that your Frigidaire washer is displaying an error code of "06". I am unable to locate that specific error code and it could be invalid. I would suggest performing a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If you continue to experience an issue with the error code you need to speak with a professional technician for proper assistance. I hope this information is helpful to some degree. -Matt
Mar 16, 2016 | Frigidaire Washing Machines
Error code 06 F or a nepturne washer
the 06 code refairs to motor problem or mcu control board,i assume the machine is not turning this is because a wire has come apart from the motor, or the mcu board needs replaced as it can no longer read the signal from the motor.adrian,,,,
Jan 26, 2015 | Maytag Neptune MAH5500B Front Load Washer
Not sure bout ur code. but a no spin is either a bad door switch, a bad motor coupler or belt, bad clutch or tranny.
Kenmore He4t front load washer f 06 error code
This answer is actually from Sears Parts Direct: The F06 error code
indicates a drive motor tachometer error. This error is virtually impossible to accurately diagnose. The most suspect components that would cause this failure code are the drive motor, the motor control unit (control board) or the wire harness. In some instances, this could be caused by severely overloading the washer so that it cannot spin properly. Make sure that the washer is not overloaded. Another problem that could cause the error code to be displayed intermittently would be a loose wire harness connection that is affected by vibration when the washer is spinning at high speed. Good lucks, hope it helps
Dec 07, 2014 | Washing Machines
Not finishing the spin cycle and have a code that says dc
here is a website you can view a bulletin on the error code DC pertaining to your washer
http://fixitnow.com/wp/2009/06/11/e3-and-dc-error-codes-in-maytag-mah6700-8700-and-9700-washing-machines/
May 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer shuts off and flashes code 06
ive had this error code before its a drive motor tachometer error it is the same error code in both kenmore and whirlpool when you order to replace the piece it comes in as enitre harness fromthe motor all the way up the side of the machine to the board
Apr 30, 2010 | Kenmore 45081 Front Load Washer / Dryer
Servise code f 06
"F06" is a Motor Speed error code. The following link explains how to troubleshoot:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Read through the link provided and verify all your wiring and connections, first. Sometimes the problem is as simple as a loose plug. Make sure resistance checks are done with the washer unplugged. If you have any questions, please let me know. I hope this helps you.
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
