Question about Fisher and Paykel Washing Machines
Mw612 rest code
Need to reset machine after total rebuild.
  • Fisher and P... Expert
  • 555 Answers
Was the motor controller or display board replaced.
You need to re-size these to your machine.
SIZE SETTING MODE.
To set the size switch,
turn the power on at the power point and off at the console.
Push and hold the WATER TEMP UP button then press the
POWER button.
To select the size of the machine,
push the temperature up button until the cold LED is on for
5kg machines,
push the water level up button until the low water level LED is on for
the 6kg machines,
push the SPIN SPEED UP button until the hold LED is on for 7kg
machines.
Posted on Apr 20, 2014
Mw612 not working
It looks like Error Code 130,
130. (10000010) Phase 1 to 6 Single Rotor Position Sensor Error
The Motor Controller has found an error in the pattern received from the Rotor Position Sensor.
Likely causes of this fault are a bad connection on the harness
between the Rotor Position Sensor and the Motor Controller,
or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action:
1) Check for corrosion on the edge connector of the Rotor Position Sensor and
the Motor Controller module connector.
2) Check the contacts on the rotor positional sensor end of the hall harness to
see if any have been damaged. (Each set of contacts in the socket has two
wipers. If the distance between these wipers varies between different
contacts, replace the rotor positional sensor harness).
Secondary Source: Rotor Position Sensor.
Action:
Check the Rotor Position Sensor with an R.P.S. tester.
Replace if faulty.
Tertiary Source: Motor Controller module.
Action: Replace Motor Controller module.
Jun 12, 2013 | Fisher and Paykel GWL11 Top Load Washer
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Jul 19, 2012 | Electrolux EIFLW55HIW Front Load Washer...
MW612 NZ FAULTY PUMP .... [CODES]
replace the pump most likely has burnt copper windings
Jan 08, 2012 | Fisher and Paykel Washing Machines
Hi I have a Fisher & Paykel MW612 top load washing machine. It will start to fill normally on warm wash then the hot stops coming in and the cold fills intermittantly then the whole ting stops and...
Gary - LEDS 00110010 as you have not mentioned the last LED which will be red if on is 00110011
Ok - your code is 50 indictes a faulty hot water valve - question - have connected the hoses correctly - as per your descriptions - it should always be cold 1st then hot water- cold - then hot etc until it fills.
Pays to check this as the fault code is totally opposite to what your saying..
May 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
Canon image RUNNER 6000 Copier error E 000001-0000
A E000001-0000 is a error code for the fuser unit. It means it is not warming up to correct temp. Also, it may show up after a power surge or power lose. You may be able to reset it in service mode.
Nov 14, 2010 | Canon imageRUNNER 6000 Copier
Grand Total Clear z/1 z/2
Hi. On most machines, the Grand total is non resettable and is just ignored if you don't want to track the total sales of the machine long-term. It should not affect the daily totals. The rest of the report should reset at the end of the day. If you don't see CASH totals and departments etc returning to zero, then there is another problem. If you still want to try to stop the GT on the reports, tell me the brand and model number and I'll see if it can be forced from the report.
Mark
Nov 24, 2008 | Casio Parts Cash Register PC Desktop
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
