Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch next 500 series stops mid-cycle - Bosch Nexxt 500 WFMC3301 Front Load Washer
  • Nicole
    Nicole Apr 15, 2014
    We have tried to reset the electrical panel, unplugging the machine, cleaning the filter, & checked for clogs & it will spin for one load but during the next load it won't. It doesn't seem like it is fulling draining.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 13 Answers
I had a similar problem, after ruling out the following
kink in drainage hose
no blocking of filter
drainage pump ok
ok we eventually found out it was the heater, sounds strange I know as you would not necessarily relate the heater to mid cycle stop an drainage problem....but it sorted ours
ours hope this might help
help regards R
Posted on Apr 16, 2014
  • 1462 Answers
SOURCE: my bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Posted on Oct 18, 2008
SOURCE: Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Posted on Dec 28, 2008
cjrepairs
  • 60 Answers
SOURCE: Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
Posted on Aug 16, 2009
  • 1075 Answers
SOURCE: Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Posted on Jun 29, 2010
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
My Bosch Vision 300/500 DLX series washer machine washer stopped in mid cycle, with error code 13. What to do
The code means that the water is taking to long to pump out
unsrew the pump filter at the bottom front right
have some towel ready to soak up the water
clean and replace filter
most times this fixes the fault
if it doesn't then check for a blocked drain hose or faulty pressure switch
Jul 22, 2015 | Bosch Washing Machines
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Oct 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Nexxt 500 series dryer
Make sure the vent outside isn't blocked either.
May 21, 2012 | Dryers
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My bosch nexxt 500 series washer won't spin
Oct 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
500 series washer
Hey try this, open the doo rand oil the door lock mechanism. next turn the machine on and push start/pause button. repeat ,repeat, repeat. if it does not release open round acees door at the bottom of the washer,there should be a manual unloccking pull inside pulldown to unlock(very thin strip of plastic. repeat process. also make sure rubber gasket around tub is secure and flush around washer openig.
Aug 31, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
136 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
