TV not turning on
I have a UMC TV that keeps scanning every time I turn it on. It says not to turn it off and let the scanning finish, but then once it gets to 100%, it just starts again from 0%. Any ideas on what's wrong with it, how I can fix it, or how to set it back to factory settings?
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Main system control memory IC damaged. Replace it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Apr 16, 2014
SOURCE: Modified Picture Settings Reset Each Time TV Is Turned Off/On
Your TV may have been put into shop mode or demo mode. How to get out of "Shop Mode"
1. Press [Source] to get to the Air or Cable input on the TV or TV remote
2. Press [Volume +] once on the TV itself (not the remote)
Next step must be completed while the volume bar is still on screen
3. Press and hold [Menu] on the TV itself (not the remote) for about 7 seconds
If the screen flashes "Dynamic Mode", the process worked
4. Finally check whether the Picture Mode is "Shop Mode" or not after passing "INFO" on Remote Control. If picture mode is still in “Shop Mode” try the alternative way below
Alternative Method
Press [Source] on TV remote to get to the AIR or CABLE input
Press [Menu]
Press [Down Arrow] to highlight SETUP and press [Enter]
Press [Enter] again on PLUG AND PLAY
Wait 10 seconds
Press [Enter] to select ENGLISH (or choose an alternative language
Press [Right Arrow] to highlight HOME and press [Enter]
Press [Menu] repeatedly until you see the message ENJOY YOUR WATCHING
Confirm you are out of shop mode by pressing [Info] on the TV remote
Posted on Apr 23, 2009
  • 8457 Answers
SOURCE: When I turn on my
This problems very common on a LCD tv.It the tv power supply board,have bad dying capactors,these capacitors are alway bulges or puffing up on it tops.That the board,where the power a/c cord plug into it.U have all the tools,know basic electronic and can do basic soldering?Just check the power supply board,for those dying capacitors that bulges or puffing up on it tops.Replaced these dying capacitors on the tv power supply board,ur tv will power up normal again and have no more clicking sounds and will not take anymore 2 mins or more to turn it on.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 25, 2010
SOURCE: I have a polaroid FLM153b
Hello, the picture disappears after a little while, sound still available, in rest its flickering
Posted on Apr 10, 2011
  • 24 Answers
SOURCE: my UMC tv keeps comen up scan and gets to 100% and
Hi Ziggy. Firmware issue on your main AV board my friend. I have heard of this with UMCs before.
You could try a factory reset. If that doesn't work, you could try updating the firmware with a usb flash drive - you would have to find the firmware for your particular model from the manufacturer's website (assuming they have one).
If that doesn't work:
Obviously, if it is under warranty contact the seller or the manufacturer and they should sort it out for you.
If it is out of warranty then you could try replacing your AV board. Spare parts from TVs damaged in transit or used parts are often listed on eBay and other specialist TV parts websites.
You would have to open the back - remember to UNPLUG IT FIRST - and you're looking for the big circuit board that has all the video inputs in. Find the part number on it and search it on eBay or a site like www.flattvparts.co.uk - replace the board and (assuming they sent you a working board) that should solve your issue.
Posted on Jun 19, 2013
gopakumarg43
  • 75311 Answers
SOURCE: when tv goes on stanby it starts scanning
The firmware corrupted. Contact the authorized service centre.
Posted on Apr 09, 2014
Testimonial: "ye done this and they said maybe firmware or a software problem and are going to charge more than what i paid ti fix it"
How do I input my sanyo television and make it stop trying to search for channels?
Have you tried keeping it disconnected for several minutes ? So when you turn it on it automatically start to scan, but what happens if you press the menu buttons while its scanning ? If you are able to get to the menus, try to change the scanning settings. Also have you tried letting it finish scanning ? Maybe it only wants to do it once.
Dec 02, 2014 | Sanyo Televison & Video
Hi, Can any one please shed any light on my problem, When I switch the tv on it says DO NOT POWER OFF and under that SCAN it scans upto 100% then scans again upto 100% and again and again does not stop...
Try a hard reset by unplugging the tv while it is turned on. Then push and hold the power button for a few minutes to drain the electronics and memory of all. Then release button and replug back into outlet and then turn on to see if that has done the trick. If that does not work you can contact tech services for a hidden code to restore unit to factory defaults.
Sep 09, 2017 | Televison & Video
TV UMC SCAN
Please provide more details. What do you want to know? Gopakumar Gopalan Google
May 12, 2014 | LG 42LC2D 42 in. LCD HDTV
Stuck on scan
It may be that the power cut was the result of a power surge. It may be that the outage has caused damage to the components of
your tv.If it does not return to normal you will need to get a very GOOD technician to diagnose the fault. It may be that the tv can be repaired, it may not ...but eirher way I would think about seeing whether the power company is liable for the damage.
The fault is almost certainly something that needs to be checked out by a pro
Aug 20, 2013 | Televison & Video
My UMC tv x216/17c-gb-ftcd-uk does not turn on with power applied. How can I test to find the problem
Hi boys,
Hope you are still here. :)
My tv UMC x216/17b gb-ftcd-uk 21.6" doesn't turn on anymore. No LED light but consecutive clicks on DVD area.
The power supply is working (12V), I unplugged the backlight screen board and the DVD unit but still not working.
So I decided to replace the main AV board.
I found on eBay the board with the same code B.LT712C 8373 but for UMC 23" or other makers with different screen size.
Do you think this board will gonna fit on my UMC 21.6" as long as is the same part code ?
Thanks,
G.
Aug 20, 2012 | Televison & Video
My UMC 22" LCD TV
Please don't just keep trying random fixes until you've spent more money than it's worth. Research the problem online, and if that fails, there are still some good TV repairmen out there, but it may take a lot of digging.
Jan 10, 2018 | Televison & Video
I have a 19"umc LCD tv,that is in protection mode,how can i fix this problem?
my 19" lcd tv umc model no s19-2ng wont turn on the standby button is flashing on and off please help
Nov 05, 2009 | Televison & Video
How do you turn off the progressive scan
I own this model and do have the manual; however, standard AV and S-Video connections do not transfer progressive scan video images. If you hookup a progressive scan output to a non-progressive scan TV input, you will not get an image, so it is probably the way you have your machine connected to your TV that is the problem. If you are trying to watch regular TV through your machine, you will probably need to use a standard Coaxial Cable. I hope this helps.
Nov 03, 2007 | Avion AV-DVR100 DVD Recorder
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
