Question about Harman/Kardon AVR 1700
Bco update the receiver displays bco update and freezes up
  • 66 Answers
You need to connect the receiver to the internet make sure you have a direct connection with a cat 5 cable.
Posted on Apr 19, 2014
Why does my bell 3100 receiver keep freezing?
Al, check your aim, to make sure you are getting good reception,are there any trees that could be intermittently causing signal loss, check cables and LNB damaged,moisture, loose ends, etc.
Call the satellite service provider, you may need to update software,etc., or they may want you to replace/update your receiver.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 10, 2016 | Televison & Video
Lifetime of BCO 130
when did you last descale the unit?
also running Milton fluid to the correct strength through with out heating may kill any bugs
Dec 06, 2013 | DeLonghi Coffee Makers & Espresso Machines
Hello, My problem is ; when I start the receiver, it simply freeze, where they no longer respond to any remote command or buttons on the faceplate. The volume knob, the on/off switch... nothing works, but...
What kind of receiver are you refering to? Firmware update for your receiver could be the problem but instead try to restore the old update and test the unit as the update might not be suitable for your unit. Please provide more information on the make and model of the receiver.
Hoping to hear from you soon.
Thank you for visiting fixya
May 18, 2011 | Audio Players & Recorders
My garmin freezes on startup. Can't master reset
You could try pressing and holding the power button for 10 seconds. If that doesn't work, try a master reset by:
Start with the unit off and unplugged from power.
  1. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  2. Continue touching and holding the lower right hand corner of the screen then power the unit on.
  3. Release the power button when the device powers on.
    • You will see a new message: "Do you really want to erase all user data?"
  4. Remove your finger from the touchscreen when this message displays
  5. Touch "Yes"
  6. Restart the unit
Please let me know if it helps.
Thanks
May 03, 2010 | Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 1340 freezes on start up
If your nuvi series device is freezing on the map screen but still providing voice prompts there are two steps you can try to resolve the issue including updating the software using WebUpdater* and performing a master reset.
To download WebUpdater and update the software:
  1. Go to http://www8.garmin.com/products/webupdater/howtoinstall.jsp
  2. Follow the on screen instructions.
To perform a master reset on your nuvi series device: CLICK HERE
Warning: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 18, 2010 | Garmin nuvi 1300 Car GPS Receiver
Video freezes on dazzle dvd recorder operating on win vista.
I suggest to you to uninstall your Instant DVD recorder program and then download and install this update version http://pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+Plug-Ins/Instant+DVD+Recorder+Support/Download+Area/Drivers+-+Updates/IDVDR261.htm?mode=documents&Display=1
Checked also if your vista is 32 bit then download under 32 bit but if that is 64 bit then download for 64bit. Try again.
Sep 29, 2009 | Pinnacle Dazzle DVD Recorder
Sagem pvr 6200T UK freeview box, display frozen.
I left the box and went for a walk!!!
About four hours after having freezed an error 09 message came up on the set top display and then everything returned to normal, after an on TV screen message that update had been successful.!?!
No difference in in any operation of the freeview box.
Note to self and other users
DO NOT PRESS OK WHEN ASKED TO UPDATE SET TOP BOX.
Updating the channel tuning does seem to work ok, though I have to vary between where channel 4 can be found - or learn welsh!
Jul 19, 2008 | Televison & Video
LCD freezes
Generally, when an LCD freezes, it is a signal source problem. By that I mean that the TV is receiving insufficient signal strength to continue to display moving images, so it holds on to the last signal it received that it was able to display (freezing or pixelating.). Have your cable or satellite company come and look at the strength of the signal at the incoming port on your set top box, or back of your set if you are not using a box. The solution is usually adding a power amplifier to the incoming line to boost the signal strenth to the TV, or if you are in an apartment that has the signal split, moving that feed 'higher on the tree'.
Mar 18, 2007 | LG L1915S 19" LCD Monitor
Harman/Kardon AVR 1700 Logo
360 people viewed this question
Top Harman Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harman Audio Player and Recorder Expert? Answer questions, earn points and help others
