Question about Lexmark Office Equipment & Supplies
Series X46xe: LR.BS.P645 - Lexmark Office Equipment & Supplies
I need a owner's manual for my Pioneer DEH-645
Are you sure about the model number? THis isnt listed in the Pioneer User Guide: Car/ch.CD-Receivers.
Keep in touch.
Aug 15, 2011 | Pioneer DEH-P645 CD Changer
Washer displays LR Locked Rotor when washer is on rinse cycle. Motor NOT spinning. What and where and app how much is the part?
Hello, The "rotor" is the actual shaft of the motor and depending on your exact series number (which can be found on the label inside the door) the motor and motor control board must be replaced together if it is series 88 or below (series 1 to series 88) the appx. cost for the motor kit including motor and control board is $300 just for the parts
if it is series 89 or higher then just the motor can be replaced w/o the board and the price is about $190 for parts then in either case i would estimate the labor cost of a repair company to be $175-225
Jul 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
I need to know which wire on the 4 wire oxygen sensor (2 white, one grey one black) is the heat wire on a ford f-150 o2 sensor?
Hello! There are four O2's...Each O2 heater, left and right bank, front and rear, has it's own wire colors...These colors are "at the connector"...First series are the control ground sent by the PCM..
RR=White/Black...RF=Red/White...LR=Tan/Yellow...And LF=Yellow/Light Blue...........This series are the battery leads, hot when fuel pump relay pulls...RR=Violet/White...
RF=Red/Yellow...LR=Violet/White...LF=Red/Yellow...
If you have any questions feel free to ask...Guru...Saailer
Oct 20, 2010 | 2001 Ford F150 Styleside SuperCrew
Need manual for Sears LR 4500 generator
Go to: Searspartsdirect.com and enter the complete Sears model number minus the decimal point. You will get a series of screens that show various parts of the generator along with drawings of same. Look there for your manual and any needed parts. Hope this helps!
Aug 10, 2010 | Garden
I have that same problem but i own nikon D60 what settings do
M (Manual).
You won't get autofocus, nor will you get any metering. It's completely manual.
Aug 28, 2009 | Canon Opteka 650-1300mm F8/16 Super...
I have a series of .NEF RAW files photos from Nikon D50 digital camera. Need to take them into PhotoShop CS3 Camera RAW. I have one that has a grey card for balance and will use for color...
Droplets are simply actions contained within an icon in which you drag your images.
All those things are more appropriate for scripts. Actions can be a part of the script. You can learn about how to create them at PhotoshopSupport.com here. It takes some skill. But it can work out very nicely for you.
However, I recommend you consider Adobe Lightroom (LR) for your Raw files to help you go through and do quick edits. LR will export as any format, resolution and bit depth. Then you can fine tune them in Photoshop. LR can also exports DNG for you as well.
Jul 30, 2009 | Adobe Computers & Internet
Lr code on display
it is a problem with the motor .this is confirmed.
Issue
Washer stops in mid-cycle and/or flashes a code.
Warranty Standard product manufacturing warranty applies.
Action The motor drive system experienced a momentary loss of neutral feed from the power cord to the
Motor Control Board. The neutral line for the Motor Control Board passes across the water valve
solenoids. Neutral to the motor drive system can be momentarily lost If there is poor crimping of any
of the wire terminals in this circuit. This situation could result in a misdiagnosis and unnecessary
replacement of the Motor or Motor Controller Board.
Current Neptune front load washers will indicate a false locked rotor signal to the Machine Control
Board. Washers with a LED display will flash code “LR” in the display. LCD washers will display
“Locked Rotor.” The earlier built front loaders will not display a code, but simply shut down in midcycle
or will not start.
Pull each terminal of the white wire harness connected to each water valve solenoid and verify the
wire is properly stripped and crimped to the metal terminal connector of the wire harness. Make sure
the wires fit snug on the terminals of the water valve solenoids.
A product improvement has been made to the following models. The neutral wire is routed across
the pump only, and now by passes the water valve solenoids.
MAH55FLBWQ/W ..................... Series 12
MAH5500AWQ/W ..................... Series A7
MAH6500AWQ/W ..................... Series 33
MAH7500AWQ/W ..................... Series A6
May 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Pioneer DEH-P645 faceplate display is FAINT
The circuit board is broken.
I was trying to find out about setting the display dimmer option. I found someone that had a manual and was told to set/reset the "dimmer on/off" by pressing the function button repeatedly while the unit is powered off. When dimmer showed on the faceplate press up or down to set or reset the dimmer option. This was done in a dark closet as the display was so dim. Anyway, setting dimmer to on/off made no difference in the brightness of the display. Oh well. . . BTW, I found that the manual is not a free download and can cost between $18 - $40 on the internet - geeeeee whiz, Pioneer is not a user friendly company.
Mar 06, 2009 | Pioneer DEH-P645 CD Changer
Hp bs or ps 2100 series printer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&lc=en&cc=us&dlc=en&product=79488&lang=en
Nov 27, 2007 | HP PSC 2110 All-In-One InkJet Printer
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
