Question about Panasonic Massage Chair Real Pro Ultra EP30005KU
CALIBRATE Panasonic EP30005KU
After locked unit, fixed and re-installed. I need to calibrate the up and down system and not sure how to set it in correct default position? I would like a service manual if anyone has it? Thank you
  • Official Brand Answer
  • 350 Answers
We recommend you contact our National Parts Center by calling 1-800-833-9626 to obtain this unit's service manual.
Posted on Apr 16, 2014
How to calibrate hvac module on 2004 gmc envoy only get from vents no defroster
Did you replace the mode door actuator ? Manual or automatic HVAC system .
When replacing the HVAC control module it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC control module be sure to perform the following:
Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result.
Place the ignition switch to the OFF position.
Disconnect the scan tool.
Install the HVAC control module.
Connect all previously disconnected components.
Start the vehicle.
Wait 40 seconds for the HVAC control module to self-calibrate.
Verify that no DTCs have set as current DTCs.
When replacing the HVAC actuator it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC actuator be sure to perform one of the following:
Preferred Method (w/ Scan Tool)
Clear all DTCs.
Place the ignition switch in the OFF position.
Install the HVAC actuator.
Start the vehicle.
With the scan tool, initiate the Motor Re-calibration feature of the Heating and Air Conditioning Special Functions menu.
Alternate Method (w/o Scan Tool)
Clear all DTCs.
Remove the HVAC B fuse for a minimum of 10 seconds.
Install the HVAC B fuse.
Start the vehicle.
Feb 19, 2018 | GMC Cars & Trucks
How do I calibrate my Panasonic TC-P55ST50 for the best picture quality?
Tweak the factory default settings until you are satisfied with the results.
Oct 15, 2014 | Panasonic VIERA TC-P55ST50 55 in. 3D...
How to calibrate speed on a treadmill
Make sure power switch is off; hold down any key on the display and turn power switch back on. Unit will go into diagnostic mode. Press and hold the start key until unit beeps and begins to calibrate. Make sure you are not standing on the belt during process. Let unit run its course and slow completely then hit stop. you're done.
Dec 30, 2013 | Cybex 530T Pro Plus Treadmill
How do you calibrate the leapster learning game system?
  • Follow these steps to calibrate your Leapster Learning Game system -
  1. Remove any game and turn the Leapster off.
  2. Turn the unit on.
  3. When the sign in screen appears immediately press and hold down "home"(house), "hint"(question mark), and "B" buttons together for 4 seconds.
  4. Now you will see a few options.
  5. Press the "A" button for the touch calibration option.
  6. Now just touch the stylus on the cross-hairs and it will be calibrated.
  7. Now you want to restart the unit.
  8. Redo the steps if this should not work the first time.
Regards, Tony
May 19, 2011 | Toys
I purchased a Coby Kyros Android it will not load any apps either from the market or online. I get Android error message and it does a "forced close". Help. Called customer service & they...
Market Apps will not load on this unit.
This is the procedure to fix consumer's who have the issue with the AppsLib error message and forcing them to exit.
1. Make sure you have back up any data on an external source before beginning
2. Make sure you know your SSID# and WEP key prior to starting. If not please contact your Internet Service Provider before beginning.
3. Go to Settings
4. Go to Privacy
5. Go to Factory Data Reset
6. Reset Data
7. This will take some time and unit will re-boot.
8. It will then instruct you to Calibrate Screen
9. Calibrate the screen by touching each X that appears on screen, until screen confirms calibration
10. Go to Settings
11. Go to Wireless and Networks
12. Set up WIFI (you will need your SSD# and password)
13. Go to Applications
14. In Applications the UNKNOWN SOURCES box must be checked
15. Go AppsLib to download
16. Install Apps
Nov 02, 2010 | Computers & Internet
Upper body workout arms on Startrac 6230 crosstrainer are locked in the ''None'' position. How do I switch to ''Pushing'' or ''Pulling''?
You May have to recalibrate Here is the procedure
Engaging Maintenance Mode 1. Press and hold the , and keys together. 2. A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information window. 3. Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode The following keys are used to modify Maintenance Settings: Upper and Lower Data Information Window SCROLL keys: Display the next and previous settings. Increase and Decrease Level Keys: Adjust the value of the displayed setting up and down respectively, in increments of 1 unit. OK Key: Updates (saves) the value of the display setting in the Flash
Diagnostics - UB Calibration UB (Upper Body) Calibration (Elite Only) The UB Calibration will set the minimum and maximum range of the upper body arms in which they can move within. You can do a Manual Calibration or an Auto Calibration. Auto Calibration is recommended. To calibrate the Upper Body: 1. Enter the Maintenance Mode (see Settings – Maintenance Mode). 2. Press until UB Calibration is displayed in the information window. 3. Press to enter UB Calibration Mode. Manual Calibration 1. For Manual Calibration press 1. 2. Press the until the upper body arms stop moving (None Position), and then press to save. 3. Press the until the upper body actuator stops, and then press the to save. Auto Calibration For Auto Calibration press 2. The display will automatically raise the arms up, then bring them back down to calibrate the positions.
Mar 15, 2010 | Startrac Fitness Products Exercise &...
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra 105Se power on calibration
If this unit has the LCD screen you need to Press Setup. Then Press Next till you get to Media Power Up and set it to FEED. Next go to Head Close and set it to FEED also and then save settings. It will only shoot one label out instead of Calibrate. Which is needed when they install new lables if its the same type of label all the time really don't need to Calibrate every time you stick new labels in it.
Mar 18, 2009 | Zebra 105SL Thermal Label Printer
I have a cect i9+ mobile and when I swith it on and try to unlock it from the arrow it is not working (like it is jammed). Any solution pls?
You need to recalibrate your screen.
There are 2 ways to get to the calibration screen. Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
Mar 06, 2009 | Dual Electronics CECT P168 Cellular Phone
HP2600n color printing not registering
Looks like theres a problem with the color ragistration.
I would calibrate the printer. Heres how;
  1. Go to "System Setup" on the display. Press Select.
  2. Go to "Print Quality". Press Select.
  3. Go to "Calibrate Color". Press Select.
  4. Go to "Calibrate Now''. Press Select.
  5. Press Select again to confirm Calibrate Now.
This will calibrate the printer and should eliminate the color registration problem you are having.
Nov 11, 2008 | HP Color LaserJet 2600n Printer
Panasonic Massage Chair Real Pro Ultra EP30005KU Logo
217 people viewed this question
Top Panasonic Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Panasonic Furniture Expert? Answer questions, earn points and help others
