Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Craftman model 917.271920 run at high speed all the time.
    Problem Solver:
  • 9 Answers
NOT A EXPERT BUT IT MIGHT HAVE CARBRATOR TROUBLE
Posted on Apr 15, 2014
When you reconnect battery how much time does it take for cpu to program itself ?
All makes & models are different. You have to drive the car at several miles high speed, than several miles low speed & repeat the process. That usually covers most vehicle. But just drive normally at high & low speeds and soon enough you'll be good to go. Does not do the clock & radio for you. That your on your own.
Sep 19, 2015 | Cars & Trucks
Craftman model 917.271920 run at high speed at the time.even with the throttle in idle position
If a cable operated throttle the far end of the cable may have broken or come off. Linkage between throttle cable and carburetor bent/broken/
missing, spring broken/missing. Shouldn't be too serious.
Apr 15, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I need the size belt for a craftsman snow blower model 315-601D515
That model number is not matching up with any model in the craftman models. Are you one number off somewhere?
Jan 04, 2014 | Craftsman 16" High Garden Tractor Snow and...
I have a craftman varible speed scrollsaw that only run wide open
sounds like the switch is bad. it has a rheostat type, that gets variable voltage. change switch they are not repairable.
Apr 11, 2013 | Measuring Tools & Sensors
I have a craftman 4 cycle mini tiller, running to slow. need to run at a faster speed. do not where to adjust.
If the carb has the "fixed" throttle control. Find the governor control lever with the small, long coiled spring attatched to it in the middle. It may be hooked to a metal tab that is on the back carburetor bolt. Bend the tab to your left to increase set speed or to the right (towards governor lever) to decrease.
Sep 05, 2011 | Craftsman Gas Mini - Tiller/Edger
I have a 5hp tecumseh motor HS50-67324K on a craftman snow blower,could you please tell me the high and low RPM speed settings on this unit.
Here is a 70 page Tecumseh service guide. Locate the type of carburetor you have in the guide. All instructions with diagrams are available. This is a PDF file. Adobe Reader will be needed to view it.
http://www.smallenginesuppliers.com/html/engine-specs/tecumseh/Tecumseh_quick_reference.pdf
Dec 14, 2010 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Kenmore over the stove microwave,model # 721.62629200,only low speed fan works on the keypad,no high speed fan.
The fan has a setting for high speed, low, and off. Fan only running at low speed.This indicates problem towards. 1) the fan motor. 2) The loose fan wiring. 3) The fan switch. IN the unit there is a motor for fan.If the motor gets weak or short. The fan will run but only at low speed.Because at high speed the motor will require more power to run.In this case motor needs to be checked and replaced. The other possibility is the fan wiring.There are two wires going from fan to motor and two going from motor to power board.If any of this wire is got loose or getting short then this will stop the fan to run in high speed.In this case the wires needs to be checked and reconnected properly. In the unit there is a switch internally.When you select the fan to high speed mode the switch goes up. when you select the fan to low speed mode the switch turns down.But if the switch is faulty or got worn out.Then it will not move properly up/down.In this case switch needs to be replaced.IN some brand models the High speed and low speed are directly controlled from front control panel.There is no switch in that models.In that case the control panel needs to be checked and replaced. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 10, 2010 | Kitchen Ranges
Craftman Chainsaw do not run
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button HTH
Lou
Oct 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Model 3400, runs on idle but not at full speed,
I think like you it is running lean. Normally I would provide a link to the IPL (exploded parts list) for your saw but Poulan just locked the site for non-dealers. Please register your displeasure here http://www.poulanpro.com/node4020.aspx. IMO as an owner, you should have free access to these.
Sounds like time for carburator kit, HTH
Lou
Sep 25, 2009 | Poulan Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
50 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
