Question about Garmin nuvi GPS
WILL NOT CHARGE
DORMANT FOR A YEAR, CILL NOT POWER UP
    Problem Solver:
  • 9 Answers
I THINK THE BATTERY NEEDS REPLACING (INSIDE)...OR A BAD CIRCUIT BOARD.........IT JUST IDEALS I HAVE
Posted on Apr 15, 2014
The electrical contacts needs cleaning. Using a baby bud (Q tip) soaked in metholated spirit clean the contacts on both the watch and the charger. Allow to dry and then re try.
This fixed mine - but does need repeating every 2 to 3 weeks when used regularly.
The cause is the salt in perspiration that causes oxidation on the contact surfaces.
Good luck.
Steve
Posted on May 21, 2014
Having leak in front drive shaft. Have put installed new one and new seal but still dripping slowly.
Hi,I beleave you mean where it gose into the gearbox if so,
then Im affried that you will have to do the job again ,
make shore you clean the the serfices with a brake cleaner to make shore there is no dirt what so ever,before replaceing the cill just smear a tuch of oil on the new seal to make it easyer to slide in,it would be good also if you have a tool socket or something the same size as the cill to put on the cill to tap it home with.
its so easy to damidge the cills when putting them in we have all done it from time to time.
well wish you all the best,hope this was some help.
Apr 18, 2015 | Cars & Trucks
What is a dormant volcano
a steaming hump of dirt. stand back!
Feb 12, 2015 | Miscellaneous
GPS DORMANT FOR 1 YEAR, WILL NOT POWER UP
Just replace the battery. Check online for places that have replacement batteries and the tool to do it correctly. There usually are video help also. This happen to one of my devices.
Apr 15, 2014 | Garmin nuvi GPS
Hp6910p screen goes dormant if left idling, don't know how to reactivate
See if any of these work:
Move the mouse... Hit the enter key... Hit the Esc key... Hit the power button...
Jul 27, 2012 | HP Compaq 6910p Notebook PC PC Notebook
No power to fuel pump for a 89 nissan sentra
Hi Gresse, Have the fuel pump relay checked for operation and also check the fuse. Sometimes these vehicles are fitted with an anti theft device which may remain dormant for years and suddenly begin working for no apparent reason. If that is the case you will need to have the key re encoded. regards John.
Mar 29, 2012 | 1989 Nissan Sentra 4 Door
I have a laptop which is around 2 months old. My question is: can i run it on ac power all the time with the battery fully charged or should i only use the ac to charge the battery only?
Yes, you can but in time it will wear out the battery. Don't leave the charged battery dormant for long periods of time. Once charged, you should at least use the battery at least once every two to three weeks. Also, do not let a Li-On battery completely discharge.
Dec 20, 2010 | Toshiba Computers & Internet
My latitude c640 works with the AC plug but it won't charge the battery.
The battery is probably in need of replacement. Try to search amazon.com or ebay.com for an economical one for your make and model.
I would try to get the highest amp hour one available for your computer to avoid having to replace every year or two, depending on usage.
Dec 15, 2010 | Dell Latitude C640 Notebook
Alette 12volt car horn does not work power is there at terminals
check terminals are clean, and has wiring round the right way. remove from vehicle to inspect thouroughly check no holes.
should be an adjustment screw on the horn, try putting power through the horn and turning the screw to see if it releases anything.....failing this, replace horn
Mar 17, 2010 | 1981 Ford F 100
Display filickering
The unit had not been used for some time, I simply charged it up and left it on a window cill where it could find a satellite signal and the flickering stopped.
Mar 06, 2010 | Tomtom GO 910 GPS Receiver
GPS Logo
222 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
