Question about Sony Alpha DSLR-A300 Digital Camera
A300 shutter shutter broken
After i take a picture it says camera error every time and the the shutter locks
You need to replace SQ (sequence ) unit.Send to Sony service station.
Feb 15, 2011 | Sony Alpha DSLR-A300 Digital Camera
I have just purchased a 500mm mirror lens but when attached to the camera I get the message 'no lens attached shutter is locked' any suggestions please
The lens lacks the electronic circuitry to interface with the camera. You'll need to use the camera in M(anual) exposure mode.
May 23, 2010 | Sony Alpha DSLR-A300 Digital Camera
I have trouble with my Sony A300 firing when the shutter is pressed. I have to keep trying & trying til it finally goes. It has done this since I got it. What can I do? I miss many moments do to that
Do you press the shutter button half-way and allow the focus to lock in (it will beep) before you press the rest of the way? If you don't and the focus isn't locked, the shutter will not fire.
Apr 06, 2010 | Cameras
I recently tried to take some pictures with my powershot a300 and was only getting black pictures. I have used it for several pictures about 3 months before that and the camera has been stored in a drwer...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Dec 09, 2009 | Canon PowerShot A300 Digital Camera
Image of pictures has lines on it? help
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
However, if movement IS seen, then you may be experiencing CCD sensor failure.
If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Sep 09, 2009 | Canon PowerShot A95 Digital Camera
Pictures are very over exposed with many white horizontal lines through them. Solution?
Hi!
The lens shutter cable is broken or the shutter blades are stuck - happens when lens get wet or something adhesive gets in the lens. It's a hardware problem so I'm afraid you will have to give it away for a repair. I must warn you that it is considered a complicated repair, so it could be expensive.
Hope this helps!
Tom
Jul 29, 2009 | Canon PowerShot S1 IS Digital Camera
HOW TO USE HDR FROM SONY ALPHA 300
HDR IS NORMANLLY A PROGRAM AND IT WORKS GREAT BY TAKING THREE IMAGES AND GETTING THE BEST TONAL RANGE .
Nov 27, 2008 | Cameras
Sony Alpha DSLR-A300  Digital Camera Logo
13 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
