Question about Casio Exilim EX-Z110 Digital Camera
CAsio EX Z110 6.0
What happened is i accidently dropped it on a rug from about a foot and a half and now the lens ( the eye ) is stuck opened and it won't open, close, or do anything at all and just a little flashing light shines once and it then makes a beeping noise and tries to close the lens but it wouldn't close. WHAT DO I DO?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 93,991 Answers
Re: CAsio EX Z110 6.0
  • 208 Answers
SOURCE: I have a Casio Exlim
Posted on Nov 16, 2008
0 characters
3 Points
Casio Exslim EX-Z33: Lens Error Message; Lens stuck
The camera might not of had been dropped or abused at that moment, but it sounds like one of your ribbons is not full connected to its port due to a previous unnoticeable drop or mishandling. In other words, if you are savvy enough to open the camera, remove the ribbons (2 of them, found on the front side of the camera coming from the lens) and re-insert them into their ports. I have only needed to do this once on this particular camera, but at least 30 times on the Exilim line of Casio cameras. Hope this helps.
Jul 18, 2010 | Casio Digital Cameras
Compact digital camera lens assembly jammed after dropping
i worked as service engineer on life support equipment for 15 years but alas my cannon g10 with above symptoms didnt make it back together .... never start without a manual to assit you ....adrian
Dec 27, 2009 | Casio Exilim EX-S500 Digital Camera
Lens error restart camera
same thing just happened to me today. the little girl that I babysit dropped it about 1 foot to the rug on the ground, not a hard drop at all. so i tried taking out the batteries and hit it on the table (read on other sites) then i gently turned the end of the lens (my lens was stuck out) counter clock wise and it clicked and then worked.
Apr 20, 2009 | Canon PowerShot SD1100 IS Digital Camera
Casio Exilim EX-Z60 won't turn on
This happened to me too, fiddle with the lens as its obviously stuck. Don't be too rough but try to figure out if it is slightly bent.
You will only be able to this if the lens is sticking out a little, enough to get a grip.
Good luck
Apr 12, 2009 | Casio Exilim EX-S600 Digital Camera
Casio exilim lens problem
this is a weird problem but i found out why it sometimes happens. You have some how broken a cog inside the camera and therefore it doesnot work. I opened my camera and the cog came out and shot me in the face and the cog i half broken...
Nov 04, 2008 | Casio Exilim Card EX-S100 Digital Camera
How can I fix the lens? It's stuck.... :(
There is no way to fix on your own. You would have to send into Casio.
Aug 20, 2008 | Casio Exilim EX-S600 Digital Camera
Casio camera lens stuck
I fix digital cameras call 214-650-6531 or email me at
Feb 06, 2008 | Casio Exilim EX-S500 Digital Camera
Casio EX-Z120 Lens Stuck
I have the same problem. No one knows how to solve this?
Dec 15, 2007 | Casio Exilim EX-Z120 Digital Camera
Casio Exilim EX1050 10.1 Megapixels
Remove the screws/case and with power on, slightly push the lens back
make sure you disable the play mode so it not turn on by itself if you accident touch the play mode
hope this help
Nov 20, 2007 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX-Z110 Digital Camera Logo
51 people viewed this question
Top Casio Digital Cameras Experts
Starnley Johnwells
Starnley Johnwells
Are you a Casio Digital Camera Expert? Answer questions, earn points and help others
