Siemens wxd 1260
It will not switch on it has no power
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 13 Answers
First things first
this may sound condescending but we need to rule out the minor thing first,
ensure that there is power going to that socket by testing it with a different electrical item ...radio or whatever.
if that's ok
ok change the fuse in the washing machine plug...ensure you replace like for like in terms of the fuse will normally be 13amp but read what the fuse says.
failing that you will need to get a certified person out as I would not recommend anybody to touch the electrics were water I concerned.
Hope it's an easy fix for you, if not it may be just a loose wire to the main board in the machine of it could be more sinister like a fried board :-(
good luck hope its an easy nd quick fix
Posted on Apr 16, 2014
Bush 1260 washing machine when you attempt to switch on all the buttons flash 5 times and then shops. Any ideas?
Possible fault in the program controller unit, remove power for sometime and check again.
Nov 01, 2013 | Washing Machines
My hp pavilion 1260 won't re power up after removing the battery
Hi, go to you tube and write: hp pavilion 1260 and you will find the instructions to fix it. i just did it with mine hp dv6000.
Jan 30, 2012 | HP Pavilion dv7-1260us Notebook PC
Siemens SE25M851 randomly looses power. power to the unit is fine ie fuses ok and constant power. if i give the unit a bit of a jiggle it some times comes back to life. any suggestions?
It could be the lid switch. See if "jiggling" the door handle pin points the problem. The door switch normally sits behind the door handle.
If so, it is either a faulty door switch, or more likely a brocken piece of plastic which holds or triggers the lid switch.
Good luck.
Ash
Oct 22, 2009 | Siemens Dishwashers
How do I turn off the alarm beeper on my WXD 1260
Hi
The sound for program status can be set by pressing and holding the button with a T-Shirt marked on it. Hold the button until a sound emits from it. Wait until the sound level changes to the level you want it at - release the button and the setting will be saved.
Hope this helps. Please remember to rate my answer. Thanks.
Jul 19, 2009 | AT&T Siemens S46 GSM Cellular Phone
I cant turn on the Siemens SP65.
find the power switch, and press it
May 24, 2009 | Siemens SP65
Can't reset the dpr-1260
Ok try to reset it again, try this steps use a pen then while the power is ON to your router press and hold the reset button for 30 seconds then after that release the reset button and power OFF the router for 10 seconds and then try to access the router setup page using the computer that is wired to it....
Nov 02, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Problem with DPR-1260
this kind of problem occurs in dlink router sometimes & after some time router stop responding after 10 -15 min & once u reboot the router it again start work for a while. the best solution to this problem is to reset the router back to its factory defualt settings u can do this by press the reset button on the back on the router ( it looks like a small hole u have to use a pin for press that button) once u have reset the router to factory default settings just reconfig the router & i am sure it will start working fine in case u still face the same problem just contact D-link or send me the details about the problem & the physical setup of ur router & printer etc
Sep 28, 2008 | D-Link DPR1260 Rangebooster G...
Printer eventually loses connection...
Try to upgrade the firmware revision to the last one (1.21).
I had similar problem with the dpr-1260 firmware rev 1.00.
Now after the firmware upgrade the problem seems solved
Nov 06, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
