Question about General Electric Washing Machines
Washer keeps restarting its cycle - General Electric Washing Machines
My Whirlpool Washing Machine W10560167A restarts after completing a wash cycle. Is their any way to fix this problem or why it keeps restarting?
Need model # that is apart # or diagram number the unit is programmed for continous run provide model # will explain how to take out of this mode
Sep 25, 2014 | Whirlpool Washing Machines
Washing machine keeps restarting its cycle
which cycle is it restarting? does it fill with water then stop or does it spin and then stop
Apr 15, 2014 | GE GTWN4250DWS Top Load Washers
Spin cycle keeps restarting
Likely to be motor, specifically the brushes. depends on how old the machine is. brushes are replaceable and tend to need replacing from4-5 years with some makes
Dec 08, 2013 | General Electric WCVH6800J Front Load...
My washer keeps pausing during the cycle
Hi claire64 - Usually when "PAU" displays on the screens, it indicates that the unit thinks that the door is not securely latch when you started the cycle, or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and resume cycle. If fault reoccurs, then it typically means that the unit either has a faulty door latch assembly or a communication error from the control board. Since there are cost differences in parts, it is always a good idea to have a service tech properly diagnose your appliance.
Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
Keeps saying PAU
The PAU, or pause, error usually means that the washing machine cycle was interrupted and was not restarted properly. If you try to modify the cycle or start a new one before the first cycle is complete, the PAU error will appear on the display. If the washer was stopped midcycle and not restarted, the cycle must be canceled or completed before a new selection can be made. Push "Start/Pause" to allow the current cycle to finish before making a new selection, or push "Cancel" to stop the current cycle
Oct 15, 2012 | Frigidaire Washing Machines
How to restart the cabrio washer
my washer when spins knocks like crazy from the inside when spinning and sometimes when on the wash cycle washer keeps saying unlevel but clothes are level
Aug 14, 2012 | Washing Machines
Washer wont complete cycle
Sound like the control board is bad
Jul 25, 2012 | AEG Lavamat 72640 Front Load Washer
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F-21
replace the contol board
Apr 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
89 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
