The toner cartridge needs to be replaced soon. Replacement of the toner cartridge is not yet needed.
What kind of a moronic error message is this. It's broken, but it's not really broken. Fix it but, don't fix it. How do I get rid of this error message. I already tried turning off the printer and back on. Thanks,
Soulvisitor
  • 1113 Answers
SOURCE: Replace Toner Message Will Not Clear
Are you sure that it is not asking for one of the colour toners?
Was it a genuine cart?
Did you replace it before machine instructed Replace Toner ie no message or Order Toner/Toner Low was displayed?
Posted on Nov 21, 2007
  • 4 Answers
SOURCE: OKI C3200N laser printer, low toner problems
For each toner there is an individual toner sensor. There is a real good possibility that the metal contacts on the sensors have become dirty. Typically, a little bit of canned air directly on the sensor contacts will resolve the issue.
After removing a toner cartidge, look to hte left side of where that cartridge rests. The sensor is located there.
Posted on May 23, 2008
LizBux820
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
  • 1684 Answers
SOURCE: B4600, "Install Toner, Toner Missing" Error
I had a customer with that problem and the issue was the toner cartridge. If you take it out of the photoconductor unit and look on the end there should be a metal connector tab. If you look on the left side of the photo unit you will see metallic contact points that need to connect to the metal tab. Oki has several toners that will physically fit in the B4600 but they have to be the ones with the metal tab to work right or you get the error. The correct toner part numbers are: 43502301 or 43502001
Check your toner for the tab is that is not the problem, get back with me and we can go from there.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 07, 2009
SOURCE: Hi, My canon mx870 all
My Canon MX870 is experiencing streaks through some of the black printing. I have preformed both a cleaning and deep cleaning and have changed the cartridge.
Posted on Aug 21, 2010
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
Get rid of the error message "toner empty stop" after replacing the cartridge with a new Samsung cartridge?
After replacement with OEM cartridge it will never show Toner empty
however refil cartrdige will show the same , You need to replace the chip to remove the empty indication
Oct 01, 2014 | Samsung Office Equipment & Supplies
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Error message 88 Replace magenta
Magenta is one of the colors of toner you need for it to run. You will need to install a new color cartridge.
Mar 01, 2011 | Lexmark C534dn Color Laser Printer
CRU FUSE ERROR SAMSUNG
hello,
their is small fuse in your toner cartridge.you have to replace it . it is also damage.
Jan 13, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Message received drum life end soon
The message means the imaging drum is going to need replacement soon. The imaging drum and toner cartridge are the two main parts that need replacement sometimes. In some printers the drum and toner cartridge are replaced in the same unit, but the Brother has separate parts. The drum is rated for a certain number of copies, so as it gets close you get the message. Replacement drums are available at big-box office places and online. An original Brother is in the $100-$150 range and generics around half that cost.
Apr 01, 2009 | Brother MFC-9440CN Laser Printer
Replace toner message still displaying
Have you already tried powering the printer off/on to see if this would clear the error? If so, are you using a Dell branded toner? If not, this could be why the printer has not recognized the replacement. It could be you recieved a bum toner cartidge, although this does not happen often, it can still happen. If you take your old toner cartridge and put it back in the printer, does it recognize it? If so, perhaps it is the toner cartridge.
If it is a bum Dell toner cartridge, Dell carries a seperate warranty on toner, apart from the warranty on the printer. Call Dell laser printer tech support. They will need your order number for the toner and have the cartridge handy as they will need an identification number off of the cartridge.
Mar 28, 2009 | Dell 3000cn Laser Printer
Have a cru fuse error
Rick and Felix are discussing the fuser, not the fuse error you are getting with the your printer. The error relates to a small fuse that is on the toner cartridge which goes into the printer. I am having a similar error message after getting a replacement from Cartridge World (although this is not the first Cartridge World replacement for this printer).
After much research, one suggestion was to remove the cartridge fuse and reinsert the toner cartridge. That worked for me and the CFU Fuse Error message disappeared for me, but I am trying to find out the PURPOSE of having a fuse on the toner cartridge itself. To protect the toner cartridge? Protect the printer? Other?
Mar 10, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
10 people viewed this question
k24674
jasbo
jasbo
