Question about Haier Convection & Rotisserie Oven Stainless Steel
I plug my Haier rtc 1700 in and there is no power
Plug in my oven and no power
Toaster oven won't turn on...light not on, no heat
check breaker and plug--if power to plug you would need a meter to test the controls and elements for problem
Sep 05, 2016 | Oster Toaster Ovens
Osher toaster oven
check breaker and plug --if power to unit will need a meter to test the controls,switches and elements
Sep 05, 2016 | Oster 003905-000-000 4-Slice Toaster...
Where to get wiring diagram
Not sure where you are but try this link: http://www.haier.com/us/ if you are not in the US you should be able to get to the country you want but the manuals should be the same except the language.
Nov 28, 2014 | Haier RTC1700 1700 Watts Toaster Oven with...
The outlet plug gets very, very hot
STOP using the unit immediately. Your plug getting very hot indicates a very poor connection somewhere between your outlet and the oven switch. This is definately a fire hazard so do not use the unit until you have found and fixed the problem. It could also be the outlet itself not making a good connection with the plug. Look at that first. If the plug doesn't fit tight in the outlet, the outlet must be replaced. If the plug is tight, you may have a switch in the oven itself with a poor connection. The oven must be taken apart to find out where the problem lies if your outlet is good. You may find parts that are melted in the oven which would indicate a problem. It's hard to say exactly what the problem is without actually looking inside the oven to see whats going on. Whatever you do, DO NOT use the oven until the problem is fixed or the oven may end up being the least of your problems...
Mar 14, 2014 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Plug is too hot
Please see the answer I posted for the previous question concerning the plug getting hot. DO NOT use your oven until you have fixed the problem. This is a fire hazard....
Mar 13, 2014 | Euro-Pro TO160L 1380 Watts Toaster Oven...
My toaster oven has no power
This can be due to three reasons:
1. It can be fault in the wire to the oven, if the plug is faulty or the wire has opened out.
2. Secondly if the switch to activate the heating coil is bad it will not connect the power to the coil
3. Finally if the coil is OPEN , then it can be checked using a multimeter as also the wire connection to the heating coil.
Aug 25, 2011 | Black & Decker CTO649 Toaster Oven with...
Slow to heat Haier Convection Oven
you are correct . it is the convection . the fan blows the air around and away from the elements ,when that is happening the elements can never get hot enough to glow , as the oven gets hotter and at some point the air is so hot even with it blowing the elements will start to get red ... this is good because todays elements are thin and cheep and melt easy so the fan keeps the heat away from them and the elements last longer ...... if this answer helped please rate it a 3 or 4 stars .this high rate will help keep me in the paid answer department ... thank you
Apr 04, 2009 | Haier RTC1700 1700 Watts Toaster Oven with...
Toaster Oven Unresponsive (Farberware Model# FT032055
I would check the cord or the plug before anything else. Plug another appliance into the outlet if it works try bending the male plugs on the cord slightly and try again. If this doesnt work call the man.
Feb 24, 2009 | Toaster Ovens
Manual for Haier RTO1400SS
http://www.haieramerica.com/en/support/
Apr 26, 2008 | Haier RTO1400SS Toaster Oven with...
Haier Convection & Rotisserie Oven Stainless Steel Logo
Top Haier Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Haier Toaster Oven Expert? Answer questions, earn points and help others
