Question about Music
I need the complete board for behringer model#lpa1180 how and where can i get one
    Problem Solver:
  • 8 Answers
Behringer Legacy parts:
Posted on Apr 16, 2014
Xenyx 1832usb effects noise
Needs the effects board replaced. The board is about 2"x 3" is not too expensive and easily replaced. Contact Behringer or a Behringer service center for help.
May 02, 2014 | Behringer Music
No effects output xenxy 1204fx
Likely needs the DSP board replaced. It is the small board held on by 2 screws(if I remember correctly) and is easily replaced. I think retail cost is about $30 and can be ordered directly from Behringer.
Aug 03, 2013 | Behringer Xenyx 1204fx
Behringer amp not working
I am afraid to give you bad news but behringer stuff is something that is very difficult to get parts for. The question you should be thinking is more, "Can you get that board?", "Can the repairmen at the service center get it?" OR, "Can you or the repairman get the parts to repair the board?" I have had this experience many times trying to repair behringer equipment and I can't even find a cross reference to a single transistor on a behringer circuit board, as if they don't exist. It seems that the manufacturer has most of their components custom made to their specs so they would be known as "genuine behringer parts" that they will not sell to a consumer. They don't want you to repair it, they want you to buy another one. It's the American marketing process. Think about it, Westinghouse wouldn't sell many light bulbs if they lasted forever. The best option you have on this is to make a 1-15 cabinet out of it, by drilling a hole for a 1/4 inch socket and wire the speaker to it and mount it, then you can put an amp head on top of it. Sorry. Didn't want you to go through a lot of time, travel, and aggravation to find this out the way that I did.
Mar 31, 2013 | Behringer Ultrabass Bxl3000 300w 1x15"...
I puchased a Behringer EPX2000 and I am not getting much volume out of it.
As you can see in these pics ,
http://www.avsforum.com/t/1236585/inside-pics-of-behringer-epx2000
, this is not a simple unit to troubleshoot. I need to know more about how you are using it, it needs some sort of preamp system or mixer board to drive it. Behringer stuff is also something extremely hard to find parts for, they are custom made for Behringer. Most power amps are made to be driven because the line in signal is very low for that reason. Let me know a little more info and I can help you more.
Mar 29, 2013 | Behringer EPX 2000 EUROPOWER
Where can I find the entire circuit board for TRUTH B2031A
Unfortunately Behringer equipment is hard to get parts for generically. You may be able to order the whole amp from behringer but I doubt it. I have had lots of problems repairing them for that reason and I will no longer use any of their stuff. The IC's could be repaired but can't find any record or crossover to any of their output transistors. It appears they are custom made for Behringer. Sorry, I can't help any more than that.
Mar 28, 2013 | Behringer B2031a Truth Active Monitors
My behringer xenyx 802 premium 8-input mixer worked fine for 1 day but now it sounds watery and behringer support was no help at all
Sounds like it may have failed. Yes, it is likely that it needs to be returned. Another option is to unplug all inputs and outputs. Plug in ONE device into the board, and use the headphone jack on the board. Does it sound the same? Just basic troubleshooting may help.
Oct 02, 2012 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
I bought a Behringer Xenyx 2442FX Board on Craigslist, knowing that it wasn't powering up, but figuring that it was just a bad fuse and the guy didn't know what he was doing. I was wrong. ...
The C23 part is a capacitor and the 7085 is more likely a 7805 which is a voltage regulator. The regulator is easy to find. For the capacitor, you will need the service manual to determine the value required. The main issue is that the leg of hte 7805 is lifted. This implies that the part was conducting more current than expected. This is an indication that the problem with the regulator is a RESULT of a problem, not the defect itself. I would not suggest replacing the power supply blindly as the root cause may beon another board. Just changing the power supply board may result in the same problem again.
I would suggest a trip to the repair shop to get a detailed repair estimate. The shop shouldbe able to determine whether or not the only issue is the power board.
Also, from the experience I have with Behringer units, the power boards are unique to each model.
Dan
Aug 20, 2011 | Behringer XENYX 2442FX Mixer
I need a circuit board for a EP4000...
If the board has not been burned up, one should troubleshhot the bad components.
If you need to replace it call Behringer at 1-425-672-0816. Have the board number including any revision number to get the Behringer actual part number. They will give you and incident number as well for you to call FullCompass who distributes the spare parts now. You can find FullCompass phone number via Google.
Dec 13, 2010 | Behringer EUROPOWER EP4000 4,000-Watt...
I need to buy an input board for a behringer bx4500h. Where do I get parts and is this a solder issue or is it a plug in type board
Chances are you are just needing a new inout connector. They are available by selecting from online sites like Digikey.com and Mouser.com.
Aug 19, 2010 | Behringer Bx4500h Ultrabass 450w Bass...
I need a wiring diagram for the main circuit board in a behringer djx700 mixer
Behringer only gives schematics to their authorized service people.
I find I can usually trace stuff out as needed as the mixers are a very symetrical repeating circuitry.
Most components are readily available from other sources.
Aug 26, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Music Logo
113 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
