Question about HP ScanJet Office Equipment & Supplies
My hp scanjet n6310 is defaulting to duplex scanning
SOURCE: How to Default Duplex Scanning
  1. Image Scan Can not be Found.
  2. please check and Cable connection
  3. and the scanner is not used by other application.(Code:DS42019)
THIS THREE ERROR WILL SHOW AT MY SCANNER.
AFTER PUT GHOST IT WIL SLOVE.OTHERWISE WIL NOT SLOVE.
COULD U PLS GIVE SOLUCATION
Posted on Jul 16, 2008
bschilz
  • 2049 Answers
SOURCE: hp scanjet 8250
Have you considered simply scanning from within Adobe Acrobat or similar software that produces .pdf and then use the email feature within Acrobat?
As I look over the HP User Manual, I can't see any method to set the default output. It simply says...
Use the E-MAIL button() to scan documents or pictures and insert them in an e-mail message as an attachment. You must have an Internet connection and a supported e-mail application.
1. Place the original face down on the scanner glass or face up in the ADF. If you are scanning two-sided originals from an ADF, slide the DUPLEX switch to two-sided mode.
2.Press the E-MAIL button().A message appears asking if the original is a document or a picture.
3.Select Document or Picture, and click OK.Note:A preview image will not appear when scanning from the ADF. To change this preview setting, see the HP Photo & Imaging software Help.
4. Select the final scan area (the area inside the dotted lines) in the preview image.
5. Make adjustments to the preview image if needed.
6. Click Accept.The final scan area is scanned and your e-mail application is opened. The scanned image is added as an attachment to the e-mail message.
7. The Save As dialog box appears. Type a file name and choose a file type, and click OK.
8. Complete the e-mail as usual.
Posted on Aug 07, 2009
sunnylab85
  • 302 Answers
SOURCE: my scanner hp scanjet 2400 not scan second copy
you must try and install the CD first before the system will recognise the hardware......kindly download another drive from the manufacturer site without that i won't work
Posted on Aug 23, 2009
  • 105 Answers
SOURCE: HP Scanjet 2400 scanning picture green and backgroud green
go to scanning software in ur computer change color section and remove this problem
regards
john
Posted on Nov 03, 2009
SOURCE: HP Scanjet G3010 scans blue page always
check by changing the tonner of that printer.
check by reinstalling the drivers.
check its head.
Posted on Mar 02, 2010
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
Where do I find a disk so my scanner will talk to the computer?
Get the name and thos model of your scanner the OS of your computer and do a google scan: i.e. if your scanner is an Hp 5590 Duplex Scanjet Adf and OS is Windows 8 search for Windows 8 Driver for Hp 5590 Duplex Scanjet Adf
Oct 09, 2014 | Office Equipment & Supplies
My HP 7800 creates a blank area on one side when using duplex mode
No manual, but have you checked the scanning light and plates. It could be that some material has been transferred on the to light or plate in such a way as to only effect the scanning when in duplex
Nov 25, 2012 | HP Scanjet 7800 Pass-Through Scanner
regards
john
Nov 03, 2009 | HP ScanJet 2400 Flatbed Scanner
Cancel double sided copying
Slide the DUPLEX switch to the one sided mode on the ADF.
Also you should be able to set the single and dula sided mode from your scanning application in the setup tab.
Oct 15, 2009 | HP Scanjet 8250 Flatbed Scanner
Hp scanjet 8250. I want to set my scanner to default to PDF when I am trying to email. That is the way we do most of our scanning and right now it defaults to RTF.
Aug 07, 2009 | HP Office Equipment & Supplies
Purchased new, didnt have an instruction manual in box, need one, please help
Here is your solution :
http://www.generalmanual.com/Scanners/HP-Scanjet-N6310-Document-Flatbed-Scanner.htm
Thanks,
Mukund Ubhadiya
www.einfochips.com
May 25, 2009 | HP Office Equipment & Supplies
HP Scanner 3570C-can not scan my slides
According to the manual, you should always scan from the HP scanning software to scan slides using Scanjet transparent material adapter. There is no button that you can set for default slide scanning properties. This is shown on page 8 of the manual for the 3500 series scanners. The manual is available here: https://www.manualslib.com/manual/72847/Hp-Scanjet-2300c-Series.html?page=13#manual .
Since the scanner works with pictures, make sure that the TMA adapter is plugged into the back of the scanner. Next open the software, HP Photo & Imaging Director. In most versions of Windows, press Start and look for the HP programs heading. Expand this to find the executable file. Alternatively, find the icon on the desktop or find the software in the file explorer (Program Files/HP/ on 32-bit versions, Program Files (x86)/HP) and then the appropriate sub-folder. Now try to scan the slides when they are loading in the adapter.
I hope this helps. Please add a comment with your OS if you are still having problems. Some newer OS versions may have installed generic drivers for the ScanJet 3570C. The generic driver might not communicate with the TMA properly.)
Jul 12, 2017 | HP ScanJet 3570cv Flatbed Scanner
HP scanjet 4370 focus problem
adjust the brightness resolution or default settings for scanner while scaning. Also read the manual of the scanner.
Aug 25, 2007 | HP Scanjet 4370
HP SCANJET 8250
Do you have the scanner set for "duplex" (two-sided) scanning? Check the switch near the front of the unit.
Feb 20, 2007 | HP Scanjet 8250 Flatbed Scanner
Seeker5211
Seeker5211
