Question about Little Tikes Yamaha Rhino 660 Ride on Car
Rhino only will go backwards
I have had the Rhino almost a year, yesterday it started only running in reverse, in all 3 gears - any help would be appreciated.
  • 1 more comment
  • jeff_vandenh Jun 19, 2009
    Thanks for the help, I ordered a new gear box and hopefully that will fix my problem.
  • jeff_vandenh Jun 26, 2009
    I ordered the new gear shifter from Fun Creations Inc. 1-877-743-3899. Worked like a charm and a very easy fix for $32.00.
  • clive pearson
    clive pearson May 11, 2010
    Hi I am Vortash it sounds like the polarity is reversed this may be the switch that puts it into reverse is jammed or the battery is the wrong way round ?. is that possible not sure as my car is slightly bigger lol .. regards Vortash
I had the same problem and there was a VERY easy fix. If you unscrew and remove the shifter on the floorboard of the rhino, you will see two rocker switches that control the forward and reverse. For me, the reverse switch was stuck down. All I had to do was reset it and clean out the debris that was making it stick. If that doesn't work, you can change out the switches. Either way, problem solved!!!
Posted on Aug 26, 2009
    President:
  • 1,392 Answers
You have a bad circuit board if it is the one I am thinking about. If it doesn't have a circuit board, then the switches are bad. There is a web site called www.modifiedpowerwheels.com that can answer any and all questions you may have. Read their FAQ, and enjoy all that you can do with the toy.
Posted on Jun 19, 2009
The tines are not moving forward on my Rotavator. The engine is Tecumsah Vantage 50. The tines move backwards and the engine seems fine. The rotavator will not move forward
I have seen a number of domestic rotavators but haven't yet seen one with a reverse gear. You didn't make it clear in your description whether yours has a reverse gear and that is all that is working or whether it usually only moves forward but is moving backwards?
While it is theoretically possible for a 2-stroke engine to run backwards, your engine is a 4-stroke that is incapable of running backwards and so it would seem the gear selector is stuck if it has one or someone has carried out repair work and made a mistake or something else is broken.
The only thing that comes to mind is some of the older designs used an over-long drive belt that crossed in the middle like a figure eight in order to reverse the driven pulley and replaced the belt with one that seemed the right size would cause the machine to run backwards.
More information needed, perhaps...
Jul 24, 2016 | Garden
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Jan 01, 2016 | Crafts & Hobbies
I have trouble accelerating out of first gear. Is my transmission slipping?
If you have a tach on the dash & it flairs when you first take off,then it is slipping
On a vehicle about 10 years old, it is about due for a rebuild,
unless the fluid was changed every 3 years
Jul 31, 2012 | 2003 Saturn VUE
The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
Jun 22, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Tractor will not go in forward gear, only reverse.
Try rocking the mower forward and backward while you try to shift it.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
2005 Yamaha Rhino 660 will not shift out of High to Reverse or Low but runs fine in High where I can run it in 2H 4H and 4HLock. Gear shift handle easily moves to R and L positions but does not actually...
I just had the same problem...driving down the trail and went to park...no gears and stays in hi. Did you ever find a solution for this problem?
Aug 14, 2009 | 2005 Yamaha YZF-R6
Toyota 1993 GLI Automatic Transmission
Hi Jun,
I would check the auto trans oil level and condition first. For the engine hard starting I would check the plugs, fuel filter and coolant temperature sender unit a well.
Cheers.
Mar 22, 2009 | 1993 Toyota Corolla
My son's Yahmaha Rhino only goes in reverse
It sounds like a switch on it is bad. It's a manufactures defect so returning it should be easy since it's not worn. Good Luck!
Feb 01, 2009 | Little Tikes Yamaha Rhino 660 Ride on Car
1996 Rodeo Isuzu - I put it in Winter Drive and now 1 rear wheel
Based on another similar problem and it was fixed driving backwards, that's exactly what I did. I drove the Rodeo backwards and then would stop and put it in gear and did this for 10 minutes until I worked the 4x4 gear loose and now all four wheels run. I must say, I created quite a sight driving backwards in a Wal-Green's parking lot for 10 minutes.
Jan 28, 2009 | 1996 Isuzu Rodeo
Little Tikes Yamaha Rhino 660 Ride on Car Logo
801 people viewed this question
Top Little Tikes Toys Experts
Marvin
Marvin
Jim Goldsmith
Jim Goldsmith
Adam Fjeld
Adam Fjeld
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
