Question about Seagate STCA3000101 - 3TB Backup Plus Desktop Drive
The back up drive will not complete the back up process
The back up process begins, but ay 2% it gets stuck and then halts on it's own. When I try to manually drop and drag info to the drive it denies me access.
    Problem Solver:
  • 9 Answers
THE COULD BE BAD NEWS.......THE HARD DRIVE COULD BE FAULTY OR HAVE BAD SECTORS.......IF THIS IS THE CASE IT WON`T WORK BECAUSE IT CAN NOT WRITE THE FILES TO THE HARD DRIVE....I HAD LOADS OF HARD DRIVES DO THIS TO ME............I HOPE THAT HELPS
Posted on Apr 15, 2014
'97 volvo 960, Orange W-mode arrow blinking, then lost power. What is wrong?
The usual cause of this is a bad PNP switch or gear position sensor.
The "W" is flashing because the transmission control module is stuck in the Winter mode. If you are not familiar with sensor, I suggest you go and have the transmission codes read and reset to begin with and then post back the results.
May 10, 2015 | 1997 Volvo 960
HP Pavilion Slimline s5503w will not load. Replaced CMOS battery & now, all I can get is DOS or Cmd Prompt
If you mean a flat 'blinking' Cursor at the top-left of the Display.....then the load process did not complete; it halted at the partition table which could not be found.
some causes of this : In order of likely-hood
Invalid Boot Sector (it is pointing to the wrong place,)
(if you have Win7 or 8, startup repair will usually fix this.)
Bad Read-Head on the Hard drive causing errors (must replace hard drive.)
Virus.
May 29, 2014 | Computers & Internet
My PC will only go as far as the "HP Invent " screen, halting the boot process at that point. It never gets to the POST. Any recommendations.
on HP, if you seeing the Invent sign, that is the post. What you could do tho, is Unplug the Optical Device and Fixed Device Data Cables from the motherboard, also, Reset the CMOS.
Email me if you this does not work.
Apr 13, 2010 | HP D220MT PC Desktop
L have dell optiplex 520 and 330 computer and it now giving me amber light and how can l solve the promblem
See Diagnostic Lights, and Diagnostic Leds, on this page:
support.dell.com/support/edocs/systems/opgx520/en/ug/tools00.htm?dgc=CJ&cid=24471&lid=566643&acd=10550055-3312504-#wp1114558
computer has four lights labeled "1," "2," "3," and "4"on thefront or back panel. The lights can be off or green. When the computerstarts normally, the patterns or codes on the lights change as the bootprocess completes. When the computer starts normally, the patterns orcodes on the lights change as the boot process completes. If the POSTportion of system boot completes successfully, all four lights displaysolid green. If the computer malfunctions during the POST process, thepattern displayed on the LEDs may help identify where in the processthe computer halted
Jan 15, 2010 | Dell OptiPlex GX520 PC Desktop
Getting orange flash light instead of green stable light on my dell optplex 520 and 745 what should to solve the problem
replace the power supply with a known good one. If that doesn't solve the problem then the motherboard is bad and would need to be replaced.
Jan 15, 2010 | Dell OptiPlex 520 PC Desktop
Can not get the Recovery Disks to restore my system,
Ok. What you have here is:
1. A bad Hard Drive.
2. A so corrupted files due to several factors including the possible hard drive failure.
Try to remove it from the pc and mount it on another one as a secondary hard drive or better as a slave (you can find a way to do it on the web, explanation is too long). Or, get your self a Hard Drive External Enclosure and mounted on it and connected to another pc as ay External Hard Drive (to me, the external enclosure is the best choice since you can use them for different hard drives and is just a swap out procedure, pretty simple). Either way you do it, if your pc can load it up, run check disk utility for it. That, for the most part, should fix some files to let you access it and do a back up. If I was you and if you succesfully save all the stuff you want to save, I would reinstall the Operative System from scratch. If it fails to install or gives you problems after the fresh install, get a new Hard Drive. Good luck.
P.S.: If my explanation helped you, please leave a review.
Jan 10, 2010 | Sony VAIO PCV-RS720G (027242658103) PC...
XEROX 8550 7,010.43 error code
Hi guitargurl:
Your printhead is stuck in the tiltposition,or is not able to tilt forward to the print position, due to another problem with a motor
7,010.43:
The printhead is stuck in the tilted position, or is not able to tilt forward to
the print position, due to problems.
7,011.44: This is a soft fault, and will not halt the printer.
7,012.45: The drum transfix home sensor is still in a not homed position, after the
return home motion has been completed.
7,014.47: The printhead is not locked in the head tilt restraint spring.
7,015.43: The head tilt restraint spring is out of place.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Reboot the printer.
2. Did this correct the problem?
Complete. Go to Step 2.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair/replace
the lock arms.
3 1. Has ink spilled ink around the printhead that
prevents the printhead from moving to its
center position? You should be able to
manually push the printhead right to left.
Clean the
printhead area.
Go to Step 4.
4 1. Does the X-axis motor drive the printhead to
it’s center position (so it can tilt forward)?
Go to step 5. Troubleshoot
the X-axis
drive.
5 1. Check the process gearbox for obstructions
or damaged.
2. Ensure the gears are correctly aligned and
homed.
3. Verify the process shaft and drive module
shaft are at their home positions.
4. Did this correct the problem?
Complete. Go to Step 6.
6 1. Has ink spilled on the head tilt gear on its
drive train (near left side of the printhead).
Clean the
gears.
Go to Step 7.
7 1. Use service diagnostics to run the Head
Maintenance Wiper Clutch
test.
2. Did the test fail?
Replace the
wiper drive
clutch.
Go to Step 8.
8 1. Ensure the wiper is properly aligned.
2. Use service diagnostics to run the Wiper
Drive
Test.
3. Did the test fail?
Replace the exit
module
assembly.
Go to Step 9.
9 1. Use service diagnostics to run the Load
Maintenance Clutch
test.
Inspect the
maintenance
drive system,
replace any
defective parts.
Jan 08, 2009 | Xerox Phaser 8860MFP Printer
PC halts while formatting hard drive
make sure your hard disk is error free Try formating the disk with FAT first ,if it doesn't work out the try disk utilities .
Nov 29, 2007 | Microsoft Windows XP Professional for PC
Seagate STCA3000101 - 3TB Backup Plus Desktop Drive Logo
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
