Question about Brother MFC-7340 All-In-One Laser Printer
My laser printer is squeaky when it prints
It prints well, it just makes a loud squeaking racket after paper pickup while the paper is traveling through the printer being printed. I'd like to clean it or lubricate it if I knew what parts to examine, what products to use and what to make sure I don't do so I don't ruin the printer while I'm trying to fix it! Advice appreciated.
  • 78 Answers
More than likely it is a problem with the toner cartridge.Try another one and your noise will most likely disappear.
Posted on Apr 16, 2014
Testimonial: "Thanks for your thought. However, it has been this ways for a couple years, through at least 3, maybe 4 toner cartridges. And I only use the brother brand cartridges. The inside of the printer seems remarkably clean for such an old machine. I lift the scanner top, remove the toner carriage and paper tras, open up the back and pull the lever forward to reveal the orange cylinder and all seems clean. I nudge what small plastic moving parts I can find and nothing makes noise or seems to stick at all. The paper feeds well most of the time. I only get the occasional paper jam when I try to stop/interrupt printing suddenly or a few times when paper is down to the last few pieces. I'm stumped."
  • jcoch8
    jcoch8 Apr 16, 2014
    When you run paper through your printer over time paper dust can get into the plastic or metal bushings on the drive assy. causing squeaking. I would not recommend lubricating it because there are circuit boards in your printer and could get on them and short them out.
SOURCE: Paper jam with Brother HL-2030 laser printer
Being a retired electronics technician, I located and downloaded a copy of the service manual. Then proceeded to hunt for the reason why the Paper LED was staying on. I put the printer into the Production diagnoses mode, then by process of alimination opened and closed each panel and cheack each sensor switch one at a time. At which time it was apparent the problem was the rear door sensor. So I started to disassemble the printer getting instructions from the Service manaul, as most electronic equipement there is a sequence process to accompliah this. and once I found that the method of the rear door sensor operated I found the bracket was not in the right position. I put the sensor bar back into it's proper position and put the printer back to normal opperateing mode, I found my problem was solved. So I reassembled the unit and plugged it back into the compter ran a couple of test sheets and cleaned and aligned the printer head(s) made a few adjustment and everything was back to normal.
I must say that locating the Service Manual was a feat, but worth every cent I paid for it which was $9 USD. Personally i think all service manuals should be available for all Brother products for a fee, then a large number of problems can be fixed by the owners without much bother to Brother.
I ahve two of these printers and would still purchase a Brother colour printers, my next purchase is going to be a Brother color laser printer. Out of all the printers i've used on my computers I like the brother the best.
Posted on Mar 22, 2008
SOURCE: Squeaking
that's a mechanism issue inside..it's going to fail quite soon, so you may not have this problem for too much longer.
Posted on Aug 20, 2008
  • 138 Answers
SOURCE: Brother 5250 DN Paper Jams
You problem is actually in the pick-up roller and separation pad areas. the paper is delaying and not making it through to the next check point in the machine fast enough.
1st
Take it by your closest Brother Service Outlet. They're in the phonebook under "Computer Service & Repair". It's a cheap fix but requires parts.
2nd
Use good paper. Paying a little more for paper will save you a lot over time in repairs and premature toner and drum failures. Brother printers are really finicky about paper quality. Recommend "HP Office" brand paper as a minimum. It's a known good paper for general everyday printing and won't break the bank.
Posted on Aug 26, 2008
komguy
  • 2306 Answers
SOURCE: Print unable 32 ?
Print unable 32 is dirt or scratch on the transfer belt assembly. There's a timing mark on the belt that a sensor must read. If the belt is damaged, you will need a new one.
Posted on Aug 07, 2009
SOURCE: Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Posted on Apr 23, 2010
My Dell 5210n printer has a very loud squeak in the back. How do open the printer to lubricate the bearings?
Usually you don't lubricate. It is probably the fuser assembly wearing. How is the print quality? Have you ran a test page, ran a supply status page? Checked the error log?
Jan 17, 2013 | Dell 5210n Laser Printer
I have owned numerous black & white HP laser printers and numerous Konica color laser printers. I purchased 2 HP Color Laserjet CP3525N printers new from HP 1.5 years ago. Now they both squeak loadly...
The squeaky wheel gets the grease! Yes it's a mechanical problem. The paper feed rollers and gears are loaded with paper dust and need to be cleaned or replaced.
Jul 26, 2011 | Dell Studio Xps 9100 Desktop Computer
Makes a loud squeaky noise
hi do one thing that at the right side do you have any thing stuck whih is causeing this problem..open the rear door of the printer and try to clean the rollers..close every thing if its working then grt! else its causing this problem because the encrouder srtip is gone bad...so you need to replace that ..in order to resolve this issue..
Jan 25, 2010 | Brother MultiFunction Center MFC-440CN...
Loud squeaky when i turn in either direction..1999 dodge ram 1500
replace belt and make sure power steering fluid is full and check belt tensioner, make sure its keep tight tension on belt it should move freely with lots of tension . good luck.
Oct 29, 2009 | 1999 Dodge Ram
Squeaky printer/copier
Probably paper dust stuck in the gears, you can try to blow it out with some compressed air, it could be due to differing humidity levels now that it is getting colder - I wouldn't worry too much over it, some noise is normal. Clicking, grinding, popping, however - that could mean something is about to go. But slight squeaking shouldn't be too much cause for worry, there's alot of moving parts in there to keep well lubed up... ;)
Oct 20, 2009 | Xerox WorkCentre 4118X All-In-One Laser...
Squeaky HP printer
Typically the squeaking comes from the toner cartridge. If you just purchased it, take it back, it's bad. If you can find an identical printer, swap cartridges and see if it makes a difference.
May 27, 2009 | HP LaserJet 1300 Printer
Brother MFC-7340 All-In-One Laser Printer Logo
319 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
