Question about Creative SB Tactic3D Rage Wireless
Headset not charging
It seems the micro usb port in the headset has been pushed in and now it is unable to be charged...I've had this headset for a good 6 months now.
    Problem Solver:
  • 9 Answers
TRY THE SHOP YOU GOT THEM FROM..........BECAUSE THEY SHOULD HAVE A ONE YEAR WARRANTY 99.9 PERCENT OF THINGS YOU BUY NEW HAS
Posted on Apr 15, 2014
How long should i charge the headset and how to turn it on
The headset contains a lithium ion rechargeable battery, which should be charged before using the headset for the first time.
System requirements for battery charge using USB
Personal Computer with pre-installed with any of the following operating systems and USB port:
Operating Systems (when using Windows)
Windows® 7
Home Basic / Home Premium / Professional / Ultimate
Windows Vista® (Service Pack 2 or later)
Home Basic / Home Premium / Business / Ultimate
Windows® XP (Service Pack 3 or later)
Home Edition / Professional / Media Center Edition 2004 / Media Center Edition 2005
(when using Macintosh)
Mac OS X (version.10.3 or later)
Charging the headset
  1. Open the cover of the micro-USB port.
Insert the tip of your fingernail in the groove, and open the cover.
  1. Connect the supplied micro-USB cable to the headset, and then connect the other end to a computer.
Make sure that you connect the plug of the micro-USB cable in the direction as shown in the illustration below.
Charging starts when the headset and the computer are connected.
Make sure that the indicator (red) lights up. Charging is completed in about 6 hours* and the indicator (red) goes off automatically.
*Time required to charge the empty battery to its full capacity
Notes
  • If the headset is not used for a long time, the indicator (red) may not light up when you connect the micro-USB cable to charge the headset. In this case, do not disconnect the micro-USB cable from the headset and wait until the indicator (red) lights up.
  • When you close the cover of the micro-USB port after charging the battery, push the catch at the edge (the round part) of the cover into the port compartment.
  1. Catch
Tips
  • If the micro-USB cable is connected to a computer while the headset is turned on, the headset will be turned off automatically.
  • To charge the headset from an AC outlet, use USB Charging AC Power Adaptor* (sold separately). For details, refer to the manuals supplied with the USB Charging AC Power Adaptor.
  • The headset cannot be turned on while charging the battery.
*Refer to the Reference Guide on the recommended adapter.
Caution
If the headset detects a problem while charging, the indicator (red) may turn off, although charging is not complete.
Check for the following causes:
  • Ambient temperature exceeds the range of 5 °C - 35 °C (41 °F - 95 °F).
  • There is a problem with the battery.
    In this case, charge again within the above-mentioned temperature range. If the problem persists, consult your nearest Sony dealer.
Notes
  • If the headset is not used for a long time, the battery may be quickly depleted, however, after a few recharges, the battery life will improve.
  • Even if you do not intend to use the headset for a long time, charge the battery to its full capacity once every 6 months to maintain its performance.
  • If the headset is not used for a long time, it may take longer to charge the battery.
  • If the life of the built-in rechargeable battery drops to half the normal length, the battery should be replaced. Consult your nearest Sony dealer for replacement of the rechargeable battery.
  • Avoid exposure to temperature extremes, direct sunlight, moisture, sand, dust or mechanical shock. Never leave the headset in a car parked in the sun.
  • If the computer enters into hibernation mode while connected to the headset, charging will not be completed properly. Check the setting of the computer before charging. The indicator (red) will go off automatically even if the computer enters into hibernation mode. Charge the headset again in this case.
  • Use the supplied micro-USB cable only, and connect directly to a computer. Charging will not be completed properly by an indirect connection, such as via a USB hub.
Usage hours
Status Approx. usage hours Communication time (including music playback time) (up to) 30 hours Standby time (up to) 200 hours The communication time will be about 15 hours when it is charged for 2 hours.
Time stated above may vary, depending on ambient temperature or conditions of use.
Checking the remaining battery
If you press the POWER button while the headset is turned on, the indicator (red) flashes. You can check the remaining battery by the number of times the indicator (red) flashes. The indicator (red) flashes immediately after the headset is turned on to indicate the remaining battery power.
Indicator (red) Status 3 times Full 2 times Mid 1 time Low (needs to charge) Note
  • You cannot check the remaining battery during pairing operation.
When the battery is almost empty The indicator turns red. When the battery becomes empty, the headset sounds a beep and turns off automatically.
Mar 26, 2016 | Jabra Bt2045 Bluetooth Headset
Can the explorer 220 be charged with any charger, or does it need its original chager??
This should pair up with any Micro USB port to charge. I have done this when I left my charger at home home and used the charger that my friend loaned me.
Good luck from Headsets Direct!
Sep 24, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How do I charge a PLANTRONICS EXPLORER E220 BLUETOOTH HEADSET OEM E 220? Thanks
There are about 4 different chargers that can be used, look at the A/C charger with the micro USB port on it, part number 76772-03. You didn't say which you preferred.
Good luck from Headsets Direct - 800-914-7996.
Aug 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a BlueAnt Q2 that I just recently purchased. Even though I fully charge the device within about 10 minutes it will lose it's charge and shutdown. I've checked the batttery level and it...
levertjames,
Unfortunately you have a defective unit. I have seen several of these same units with the same issue. Return the item and get your money back. Thanks for visiting FixYa.com. Have a great day!
Sincerely,
TechGuy21
Jul 05, 2011 | Blueant Blue Ant 091022 X3 Micro Bluetooth...
Why do you send usb connection to charge jwin jb-th130, why not receptical plug. do i plug into computer and how long to charge?
The standard connection is a USB plug (mini or micro USB style). You can plug it into your computer or any wall plug that has a USB connector on it (the bigger rectangle shaped plug like your computer has). The USB standard is 5 volts so if it comes from your computer or a wall adapter or your car charger - as long as it is a USB connector and likely says 5 volts, they will all work the same way.
Every headset I have worked with seems to charge about 50 to 75% in 2 hours (it is ok to do a quick, partial charge). Leave it plugged in overnight for full charge (8 to 12 hours).
Jun 14, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
Headset is not charging through USB
If you are using a USB hub, then try connecting the USB dongle directly to the USB port of the machine/laptop. Some USB hubs will not charge devices properly.
I had a similar problem with my headsets solved by plugging into a USB port directly.
Mar 28, 2011 | ASUS HS1000W Wireless Headset
Hello, i cannot connect my headset (ASUS HS-1000W) with my playstation 3.i ve check it with my laptop and it connected.the flash light is green but not steady.i ve done all the procedure from the manual
If this is a Bluetooth headset, I have found that not all headsets play nice with the PS3. I had to switch to the Sony PS3 headset to get mine to work consistently.
Mar 09, 2011 | Video Game Consoles & Games
I lost the charger for the jabra bt135 bluetooth headset...where can i buy a new one?
Hey there sanjeev! There should be an USB port on the back of the headset, it is the micro-usb port. Therefore, if you have a cable from your camera, mp3 player or any other gadget that uses a micro-usb port, take their cable, plug it into the headset and let it charge! :D
I hope it helped! Take care! :)
Mar 04, 2011 | Jabra BT135 Bluetooth Headset
I have a madcatz headset, Well The Headset still working in the ps3, but today when i put it to charge doesnt want to charge anymore, and the USB cable looks perfect, i didnt dmged it or moved it. is weird
Seems you should order another cable from madcatz because your charging cable might of become faulty or you might want to change usb ports on the computer you are using.
Jun 12, 2010 | Mad Catz Bluetooth Headset for PS3
Creative SB Tactic3D Rage Wireless Logo
52 people viewed this question
Top Creative Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Creative Radio Communication Expert? Answer questions, earn points and help others
