Not booting my toshiba c50-634 not bootong says no bootable device please restart system
  • 320 Answers
Hi it looks like your boot is corrupted or your hard drive is faulty.
power on your laptop and long press F2 to go to bios and check there if your hard drive is detected if so restart and use recovery partitions or recovery disc to get it fixed. If not you need a new hdd.
Posted on Apr 15, 2014
SOURCE: No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Posted on Sep 25, 2008
endisforever
  • 36 Answers
SOURCE: MY SYSTEM SAYS NO BOOTABLE DEVICE--INSERT BOOT
Okay, first things first. Unplug everything except for the power cord. Make sure the floppy drive (if you have one) and CD-ROM drive are empty. Go into your computer BIOS settings and make sure that the computer is set to boot from your hard drive first. (Depending on the computer, usually holding down F2, F4, F6, F8, or even other function buttons will allow you to do this. Not all of the buttons at once, but just hold each one down when you start the computer until the BIOS comes up). If this doesn't work, your Hard Drive is either corrupted, all information has been deleted, or simply came loose over time. You may be able to fix this yourself. The easiest solution is to reformat your computer using the original disks your computer came with. You can also use a licensed copy of Windows disk.
If you have information to recover, I would look into Bart's PE Builder (google it), although that requires another computer. If you have access to another computer there are many boot disks that you can download or buy.
If none of these work, try getting your computer into DOS mode. It's much harder with XP and Vista, but Windows ME and earlier it should be an option. simply type C:\ at the prompt, cd windows, dir/w. This will tell you if windows is still there. At least then you'll know your options. If windows is gone, the only way to get it back is to reinstall it. I hope something in here helps someone.
Posted on Jul 14, 2009
parrotheadpc
  • 2600 Answers
SOURCE: no bootable device message, says insert boot disk what is that
Usually this is idicative of a hard drive failure, try to boot with the windows cd and see if it will boot up. Try this below......
Windows Start-up Errors
First, The basics. You will need a Windows CD. If you only have a recovery disk set like the ones from a HP or Compaq, they will not do what you want. You can normally use a Dell disk, also retail box disks (Windows Purchased from the store), or some OEM versions of Windows will work (most of these will have the Microsoft hologram on them).
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
Posted on Nov 21, 2009
SOURCE: my acer aspire one says no bootable device
This sounds awful, but a friend just had the same problem - no bootable device. He had dropped it, hitting keyboard first. Now he thumped it on the opposite side and IT WORKED! Must have been a loose connector
Posted on Jan 16, 2010
paul7of9
  • 1189 Answers
SOURCE: I AM GETTING A
Hi, in BIOS; do the following: "restart the Computer, and just before the Computer start to load the OS. You must "Press the [F12] button when you here the "Fan" startup, you will also see for a brief moment in the {lower left corner of the screen}. *Press F12 Button to open the {BOOT Setup}. Once the "Boot Manager / Setup / Options" window open, go to the "Boot Device Option," next choose device by [Boot Priority] using the (arrows: Up, Down...) "choose the known booting device," ie: "SATA" Drive. After you have made all the changes; {Press F10 to Save and Exit}. To finalize the configuration change, the Computer will "Reboot." "I hope this information help, give a "Rating" if so, this is the way Fix' Ya work; I help, my reward is a rating on how helpful the "solution is / was," thanks!"
Posted on Jul 11, 2010
Toshiba locked with system boot error
Check, in the bios, the boot order is pointed at the correct bootable sector of the hdd.
Mar 21, 2016 | Toshiba Satellite Computers & Internet
What do I do when I turn my Toshiba satellite c855d-s5103 and it says no bootable device restart system
its sounds like it has lost its boot up from the hard drive.or its not picking up the hard drive,have you tryed starting in safe mode?
Mar 31, 2015 | Toshiba Computers & Internet
My toshiba is saying no bootable device?
Hmm.. This seems to be an issue with the Hard drive. If you have a restore CD/DVD you could try to restore your system to the factory settings just and check if the problem goes away. If not, you need to get the systems hard drive replaced. You will loose all your data stored in the laptop. Please visit your nearest laptop service center and get the hard drive fixed.
Aug 31, 2014 | Toshiba Satellite Computers & Internet
My toshiba windows 8 its says no bootable device please restart system what do i do
Try pressing F8 just before it tries to boot. Then use safe mode or repair system.
Jul 31, 2014 | Computers & Internet
How do i fi no bootable devices on my Toshiba Satellite laptop
.- what kind of toshiba you have?
Normally, if you have a bootable USB stick (and your BIOS recognize this kind of device) insert it and give it a try.
Or, insert a bootable CD/DVD into your CD/DVD tray and boot.
Once the operating system was booted from any of those devices, proceed with installation of the operating system on your HDD. Good Luck!
Jul 20, 2014 | Computers & Internet
No bootable device please restart system on toshiba netbook
It could be that your harddrive is defective or the boot sequence was set to boot to CD or other bootable device. Go to Bios and reset the settings.
David
Jun 07, 2013 | Toshiba mini NB305-N600 Netbook
How do I get my Toshiba Tecra to boot from CD
Please restart the computer and press the F2 Key to enter BIOS Setup. Then follow the onscreen instructions to locate the Menu for Boot Configuration to select First Boot Device as the CD-ROM Drive or DVD-ROM Drive. Then select F10 Key to save the changes and Exit. Now insert any bootable Operating System Disc and restart the computer to boot from the CD.
Mar 27, 2011 | Computers & Internet
How to boot from windows CD / boot property changes
Hi there.
Restart the laptop and hit F2 as it starts, that will take you into the bios, in the bios look for the boot order and set the CD/DVD as first boot device, hit F10 and exit the bios, the computer will restart and allow you to boot from CD.
Please post back with the results and thanks for using FixYa!!
May 23, 2009 | Toshiba Satellite A10-S100 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
