My Electrolux Front Loader drain light is not lit up?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 13 Answers
Hi there, can you.clarify it it is still draining or is it just that the light is not coming on..
Posted on Apr 16, 2014
  • 3 more comments
  • Kirsty Apr 16, 2014
    It starts off as normal then stops mid cycle and then goes back to the start again! I then need to drain the water out manually! I have cleaned the filter and there wasnt anything in it! Now there appears to be a fair bit of water under my machine!
  • ricardo cafolla Apr 16, 2014
    The water I likely to be from you draining it...could it have escaped to under your machine? ...if the board is not the issue the machin may be thinking I just cannot drin, this should be bringing up a error message but in your case may not be.
    To be sure ensure there is no kink in the flexy drainage hose at the back of your machine
    Add a CommentFailing that it could be a draining pump or if that failed very likely to be a heater problem in the washing machine ( that last solution is often overlooked by engineers)
    Also reference the water before looking at possible machine problems ensure the water from the flex hose is able to drain and that your household drainage is not backing up, once your machine empties some water, if that were the case the machine would assume that it cannot drain and could go back to the start to try again....
  • 375 Answers
SOURCE: gray front loader washing machine
Check the drain pump filter for a foreign object and check your hoses for clogging or obstructions.
If there is nothing wrong with either of those, you will need to replace the drain pump.
Posted on Jul 25, 2009
torres No9
  • 27 Answers
SOURCE: My 7.5kg Electrolux Washing Machine whent bang and
your door lock has blown/short circuit turn power of disconnect plug take top of machine look down inside machine toward door lock and you shoud see the catch push hard with your finger and door will open be careful as there are some sharp edges in there.
Posted on Jun 25, 2010
rickead1
  • 1998 Answers
SOURCE: Hi, I have an Electrolux EWF 1074 front loader.
Go back and check your connections. If you had the machine working previously and none of these issues were there before you cleaned out the drain area of the unit then your first step would be to check the connection to the pump as well as your connections going from the control to the door area as well. If after you have checked all your connections to the pump the door lock assembly, the control and the touch pad the unit is still doing the same thing then message me back. Before you do any of the checking of connections in the unit first hold down delay and extra rinse buttons together for 3-5 seconds. This usually will unlock the control if the control is locked on the unit. Also if the delay and extra rinse and the checking of your connections does not solve your issue then also message me back with the number of times the pause button is flashing and how often it flashes as well. If you have any further questions message me those back as well. I await your reply Thanks again Rick
Posted on Jul 18, 2011
  • 154 Answers
SOURCE: program lights not showing on front loader
You most likely have had the main control board blow on your Electrolux washing machine.
It is quite common for the main boards to blow on these machines. The main board is located on top of the machine towards the front right hand corner.
You need to remove the top panel via two screws on the back. Then slide and lift to remove top cover.
You will notice a white plastic casing fitted on the right hand side towards the front. This plastic cover holds the main PCB and is vertically fitted on a cross beam and has many wires going into it.
Get a quote for the part as they are expensive. Best to get a qualified repairer if you are going to replace this part, as there may be a problem elsewhere in your machine, causing the board to blow.
Electrical storms and power-surges also cause the boards to blow. Other time an electical short circuit or leaking water on electical components can cause this. Another item to watch out for are cocroaches. They can nest in the boards and short things out.
Ash
Posted on Sep 18, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: how do i reset an electrolux 1080
    E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
    Posted on Jul 19, 2012
    Why is water pouring out the soap dispenser of my Electrolux front loader washing machine
    Possibly a part blocked water feed pipe from bespencer to drum check that it's free
    Jan 02, 2018 | Electrolux Washing Machines
    How do i reset an electrolux 1080
    Jul 19, 2012 | Electrolux EIFLW55HIW Front Load Washer...
    My Electrolux ewf1090 front loader door wont open
    Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
    Apr 25, 2010 | Electrolux Washing Machines
    My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
    front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
    Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
    Broken front loader washing machine
    take the back off and see if the belt has come off. is it draining water? if not make sure nothing is blocking drain pump
    Apr 23, 2009 | Electrolux Washing Machines
    Electrolux Front Loader 7 Kg Error Message E20
    From the manual E20W Problem with water draining
    Sep 14, 2008 | Electrolux Washing Machines
    Washing Machines Logo
    Top Washing Machines Experts
