Question about Magic Chef MCWC30MCG Compact Wine Cooler
Cooling fans not running
I have 16.2 volts output to the fans. Run the fans with a dc power supply and they work but won't run off the control board
  • Bart Falzarano
    Bart Falzarano Apr 15, 2014
    A couple things you can check: 1) make sure the wiring is not crossed. correct polarity to the fans. 2) check to make sure the 16.2 output voltage is DC and not AC. If one of the electrolytic capacitors failed you can AC voltage present and fans operate of DC voltage. 3) sometimes the connectors to the fan corrodes and not visible looking at the connector. This happens to the pins inside the plastic connector housing. Hope this info helps you. Best regards,
Electrograph 47-in monitor. Why does it have a multicolored vertical line running down it?
The cooling fans not running would definitely cause a problem with overheating. But the question is, did the fans fail or is there a problem with the power supply that is causing the fans not to work and also interrupting proper operation of the video boards. It is more likely a power issue than 2 failed fans. If you have a multimeter you can check the power coming into the fans. Most will be 12 volts, some might be 5 volts, usually stamped right on the fan.
May 24, 2015 | Computers & Internet
24v dc motors can it run at all with 12vdc
Sure. Just slower.
If you remove the motor from a power wheelchair to use in other applications keep this in mind; these motors are designed for PulseWidthModulation Speed Control (apx. 10kHz) with a feedback control to keep the speed more consistent. Feedback and pulsing is key to power and efficiency. If you run them at 12 volts without a pulse control the current to power output is much higher and the I*I*R (I squared times R) losses are higher - dissipated as heat. The motors will run very hot under a load with DC that isnt PWM'ed.
If the use/cool down duration is short you should not have issues.
Feb 07, 2014 | Invacare Supply Group Health & Beauty
Motor tripping out power supply
The input to your treadmill is about 120 volts Ac. The output from the board will be about 30 Ac. Almost nothing on there will be measured in DC. Your particular issue is your motor controller. It needs to be replaced.
Jul 27, 2017 | Reebok treadmill i-run s
2003 gulf stream prairie schooner 5th wheel computer box/electrical problem
ac runs off 120 volts refrigerator 120 volts heater element 12 volt heater element and control board outside lights 12 volt ceiling fan 12 volts wires that go to box 2 blue furnace 12 volt wires from thermostat 12 volt
May 10, 2017 | RVs
I have a ge sbs model pcp23shmffbs. the condenser fan motor is running slow, but turning freely. the fan motor is rated at 11.3 volts dc and supply to fan motor is only 6.7 volts. is the condenser fan...
If the motor is running, but running slowly, you will need to replace the motor. If there was a problem with the PCB, (control board) the motor would not run at all and you would see other problems with the refrigerator.
Here is a link to the motor.
Jan 28, 2011 | GE Refrigerators
Wont cool down fans in the back of the unit constantly run
Remove the back.
Remove the fans. See of the heat sink is not plugged up with dust. If so vacuum it out.
Get a dc voltmeter. Fire up the fridge. Set it to cool. With the fans running, check for 12 volts on the connector that's on the lower left of the circuit board. This connector powers the Peltier cooling chip. If you have 12 volts, and no cooling the Peltier cooling chip is bad, ir the second fuse is out. There is a small cylindrical fuse near the lower left corner of the circuit board. Carefully check for voltage across it. If the fuse is good, and the fans running, you will not sense voltage across this fuse. Bad, you will read ~12-16 volts.
If your Peltier Chip is bad, it's usually caused by over heating from a plugged up heat sink or fan stoppage. These chips are available off E-bay for ~$13, but require nearly a total tear down of the fridge to change it. 95% of these cooler chips are single layer, square, and vary in thickness. You should find one that is drop-in should you choose to 'Go for it'. Look for a 60-80 watt unit that is the same or slightly thicker, and the same size square.
Oct 22, 2010 | Cuisinart Private Reserve CWC-600 Wine...
How can i use this power supply in a stand alone situation to DC cooling fans only? if i just plug it in i get no output voltage.
look at the ATX connector.
http://www.smps.us/atx-connector-20-24pin.jpeg
Now you need to connect pins 15 and 16. They are normally Green and Black. All you are doing is connecting the signal the PSU looks to turn on into a ground.
So the best way and cheapest way it to bend a paperclip and put one end in the green wire and another in the black one.
I use this trick almost every time I am fixing computers. It specially awesome when you want to run a water cooling system without turning on the computer.
Apr 24, 2010 | Dell (PS-5251-2DS) (M0148) 250-Watt Power...
Dimension 3100 Won't POST, getting amber flashing amber light at front panel and on the mother board getting steady light near the cmos battery note under the light says cr3h1 re-seated cpu and cards,...
I concur with your diagnoses.
Weak power supply due to a weak, or failed, voltage power rail.
There are three main voltage power rails for your Dell Dimension 3100 power supply.
1.The 3.3 Volt rail
2.The 5 Volt rail
3.The 12 Volt rail
Newer computer power supply's are doing away with the 3.3 Volt rail.
Your power supply has,
16 Amps on the 3.3 Volt rail,
21 Amps on the 5 Volt rail, and
21 Amps on the 12 Volt rail.
These are the main power voltage rails.
Voltage times Amperage = Wattage.
You have a power supply, that is rated at a maximum output of 400 Watts.
1) ALL the lights use less than 1 Watt.
2) EACH fan uses 2 to 3 Watts
3) A typical processor uses 55 to 125 Watts.
(A typical Intel Pentium 4 HT processor, Model 640, (3.2GHz), uses a maximum of 84 Watts,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_2M_.2890.C2.A0nm.29
With a weak, or failed voltage power rail you don't have enough power to turn on the processor.
No processor running there is nothing to run the operating system. (Windows XP is an example of an O/S)
The harddrive just sits there, and spins, or will spin a few times, and stop.
What causes this?
1) Cheap quality power supply, (SMPS), installed by computer manufacturer. Cheap components are used in the power supply. (Electrolytic Capacitors, gauge of wiring, rectifier bridge, and so on)
2) Inside of computer, and power supply hasn't been cleaned on a regular basis.
Causes havoc inside the computer.
The processor fan builds up with dust, dirt, hair, etc, and the cooling capacity drops tremendously. Eventually the processor turns off. (BIOS turns it off)
It's a Fail safe feature that is built-in, to keep the processor from burning up.
Before it get's to the stage of overheating, and turning off, it calls for more power from the power supply.
The power supply works overtime to keep up.
When the inside of a power supply, and it's cooling fan are clogged with the above mentioned gunk, the cooling capacity of the power supply also drops tremendously.
The heatsink's inside the power supply cannot get rid of the heat. The fins are clogged, and air cannot rush through them to disperse the heat.
When the blades of the fan, and it's center hub become clogged, the cooling capacity drops due to not enough air is passed.
Heat = Wasted Energy, and the power supply strains to keep up. Eventually components inside the power supply start to fail, or fail.
(Electrolytic Capacitors are usually the first to go. They are the weakest link)
Questions?
Dec 26, 2009 | Dell Dimension 3100 PC Desktop
How much additional track can I run with the Tyco nascar super sound set and still have the pits work correctly
Check the voltage output of your current power pack. If the output is anywhere between 12-16 Volts DC, you can use a Automative battery charger, preferably a 10 AMP model and it will supply more current to reach additional track. You just have to try it to see what works.
Dec 12, 2009 | 2003 Ford Focus
B&D 400W Inverter won`t run my laptop
even the smallest inverter can run a laptop, something is wrong with this unit
Jul 25, 2009 | Black & Decker 1000w Power Inverter
Magic Chef MCWC30MCG Compact Wine Cooler Logo
Top Magic Chef Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
