Tv. kenix kxtv1408 no tuning chanells
When i change it chanells no appear nathing and tv. and video is ok.
3 Suggested Answers
  • 89 Answers
SOURCE: toshiba that uses CT-90040 remote
if this is a time warner cable remote. the toshiba code is 015. sometimes a tv has several codes but only one controls everything. dont understand tuning video into tv. sounds like u need to plug rca wire into input plugs on the front or rear and then move switch to video but dont know what wires u r using.
Posted on Dec 27, 2008
gopakumarg43
  • 75311 Answers
SOURCE: tv won't change from chanel to chanel
Do a hard reset to this set and check first. To make it hard reset, unplug the set from AC mains wall socket, and re-plug it back after 10 minutes or so.If this do not help you, check and replace its main system memory IC.
Posted on Sep 30, 2012
How do I run a Chanel auto scan?
use the remote to get the onscreen menu up
move around till you get auto tune then press ok and let it run
Mar 25, 2018 | Dynex Televison & Video
My panasonic flat screen plasma tv is stuck on chanel 60
Appears that tuner is fubar. Try a hard reset to factory conditions and see if that restores operation. If not, then the board responsible for tuning is at fault.
Feb 05, 2017 | Panasonic Televison & Video
Cannot auro tune the new chanels on my chang hong tv. The audio works but tge picture format is invalid. What do i need to do ro get the picture.
Have not got 1 of these so this is an educated guess:
Go to settings, select tuning or chanel tuning, opt for the auto tune, follow all directions give to complete.
Mar 04, 2016 | Televison & Video
HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN THE CHANEL TO THE VIDEO CHANEL
Hello
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
Jan 06, 2011 | Philips 20PT633R 20" TV
I need a user manual for a Techwood LVD2263D flatscreen tv. I cannot install & re-tune to view TV channels
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 23, 2010 | Televison & Video
Just got a n64 off ebay power cable and an antenna cable came with it. no idea how to tune the tv so i can play it!!!!!! i have tried manually and automatically searching through all the components and...
It has been a long time since I have used one but I believe you can hook it directly to the rca jacks in the back of the tv... then I believe you need to be tuned into the AUX chanel on your tv set ... some tv's if you hit 00 this puts you to it ..others start from chanel two and go down ... hope it helps .. have fun playing the 64
Oct 16, 2009 | Nintendo 64 Console
PURCHASED 52" LG LCD HAD A GREAT PICTURE.ALSO HAVE DIRECTV. TOUCHED THE MENU BOTTON SAW THE AUTO TUNING, THOUGHT THAT WOULD BE A GOOD FEATURE. WENT AHEAD AND LET IT RUN THROUGH ALL THE CHANELS. NOW IT...
Because you have DirecTV there is no need to use auto tuning. You simply changed inputs on the TV when you started auto tuning. Just use the input button on the remote to go back to the Direct TV receiver. Most likely it will be under Component (Color Stream) or HDMI input.
Dec 31, 2008 | LG RU-27LZ50C 27 in. HD-Ready LCD...
Tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Apr 01, 2008 | Televison & Video
Toshiba that uses CT-90040 remote
Is the cable remote a programmable universal? If so, just a matter of finding the codes to reprogram functions.
Concerning the "tuning video", are you saying that you can't get to different input sources?
Oct 15, 2007 | Toshiba 36AF42 36" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
