Question about Kyocera FS-2020D ECOSYS Monochrome Laser - 35ppm, USB2.0 & Parallel Interfaces, 500 Sheet p... Printer
Kyocera error:6000:0032718 Receive error:6000:0032718 when unit is powered up. Can someone assist with what may be the issue? Thanks!
  • 78 Answers
Sounds like a fusing unit error.Does it print at all?If so does the print on the page rub off/This is a sure sign of a fuser issue.
Posted on Apr 16, 2014
Hi, I have an error code C7990 on a Kyocera FS-1028 MFP. Can someone help me on translation and fix of this error?
empty drum unit its full of waste toner each side of drum unit has plastic covers that pop off empty out the unit thoroughly and vacuum inside
Mar 11, 2017 | Kyocera FS-1028MFP Mono Multifunction...
Kyocera fs-4020dn; Error code 6000
Be sure to power down and disconnect the power first.
A fuse it is blown within the fuser unit - replace that fuse or call a technician to do it for you.
Nov 25, 2013 | Kyocera FS Office Equipment & Supplies
I receive the following error message, when I power on my Copystar CS 300ci: Machine Failure C1950 Any suggestions
Transfer belt unit EEPROM error No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively. Mismatch of reading data from two locations occurs eight times successively.
Mismatch between writing data and reading data occurs eight times successively
1. Poor contact in the connector terminals.
- Check the connection of connector YC28 on the engine PWB and the connector of the transfer belt unit, and the continuity across the connector terminals. Repair or replace if necessary.
2. Defective transfer belt speed PWB (inner transfer belt unit).
- Replace the transfer belt unit.
I hope this is helpful,
Shawn
Mar 14, 2011 | Kyocera Copystar CS2540 Copier
My Kyocera KM-5035 receive error code 4200 in PC printing and in photocopy
Hello, This error C4200 indicates a problem with the main Laser Scanner Unit. The laser scanner functions to image onto the drum in the copier. It scans at a high rate of spped, the error indicates it is in trouble.
The Laser scanner would need to be changed.
It is also possible the main PCB is failing (remote chance)
Find a Kyocera Repair Facilty.
Dec 10, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
FAULT 7410:0147661 CONTACT SERVICE IS ON MY PRINTER KYOCERA FS2000-D
The error is for the drum not being set in place remove the process unit and open the left side cover where the drum is located. Remove the toner waste bottle and make sure the drum is pushed in all the way if it is you may need to replace the drum.
On a printer error code, the first 4 numbers are the actual error. the numbers after that is the page count for the machine.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 20, 2010 | Kyocera Office Equipment & Supplies
Getting a E2 error on Kyocera FS-1700+. Any ideas?
this service code belongs to Laser scanner unit (Polygon motor) error
check the connection between scanner unit and engine board .....
Oct 06, 2009 | Office Equipment & Supplies
C6000 error code
Hi
Error C6000 is displayed when your machine fails to reach the correct temparature at a specific time.
This is a Fuser Unit Problem, try to reset it by--
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
If the reset doesn't work then get your unit checked for fuser unit and fuser unit heat issues.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Call service engineer Kyocera
power down unit and power on... if same error get a surge protector or power conditioner... plug unit into it and then power down and power up... if same error replace the memory card in the unit... if same error replace memory board...
Apr 10, 2009 | Kyocera Mita FS-C5016N Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-2020D ECOSYS Monochrome Laser - 35ppm, USB2.0 & Parallel Interfaces, 500 Sheet p... Printer Logo
198 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
