Robertshaw Thermostat 9401 display empty when cool cycle
When Cool cycle is selected, Cycle works ok, the issue is that never stop and I can see the room temperature, 24 volts is ok, equpment is working ok.
    New Friend:
  • 84 Answers
REPLACE THE BOARD OR SYSTEM CONTROL CIRCUIT
Posted on Apr 23, 2014
  • 619 Answers
SOURCE: thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Posted on Jan 08, 2008
SOURCE: The Honeywell Programmable Heat Pump
if your problem has existed since the begining of installment it could be a return/ thermostat placement problem. if the return is to close to any supply vents it will run like that and your thhermostat will read like that
Posted on Apr 25, 2008
  • 143 Answers
I'm thinking the bi-metal is working, that's why you can hear a click, but the contacts are welded together. The bi-metal doesn't have enough strength to break the weld. Time for a new thermostat.
Posted on Jul 23, 2008
  • 45 Answers
SOURCE: Robertshaw 9420 thermostat engages inside fan in OFF position
check with the company u brought it from and check if you have not put the correct conector to the right temals on the back of the switch.
Posted on Jun 09, 2009
t1m130
  • 86 Answers
SOURCE: Blown Transformer heat pump
blown transformers are usually from a low voltage short the first thing i would do is wire a automotive or resetable 3amp fuse in line with the transformer so you dont blow transformer after transformer the wire coming off the transformer that say 24v take that wire a couple of inches down and cut it and install the fuse in series there
24v----------------
24v----------x----------
24v--------{3ampfuse}----------
now you can go through your low voltage wires one by one and test them unhook all the wires to your outdoor condenser at your indoor unit(furnace or airhandler) and try turning it to cool now if you blow the fuse the short is between the tstat and the indoor unit if the fuse is still good leave it on cool and hook up one wire at a time to your outdoor unit starting with R a lot of times your contactor or your defrost board will short out on you also look for pinches in wires wires with cracks in the insulation and wires touching metal this situation can be a real pain sometimes i would recommend calling a hvac company if you start to get stumped
hope this will help you
Posted on Jul 26, 2009
Brew group/thermostat ?
Definitely sounds like an overheating issue. Especially if you have to wait a half hour for it to cool down and then it brews again. If it is under warranty I recommend replacing it.
Jan 24, 2014 | Saeco Vienna De Luxe Espresso Machine
Trane xr12 blower stays on after first cool cycle run
Hello, this is usually caused by a sticking fan relay on the intergrated comtrol board. You may be able to tap on it to shut it off but eventually the control board will need to be replaced.
Jun 02, 2012 | Heating & Cooling
Washing cycle stops
Thermostat or heater faulty. Can get over temporarily by connecting fill hose to hot tap only but then doesn't allow cool rinses!. Check thermostat continuity and power to heater to trace faulty part
May 09, 2012 | Washing Machines
Freezer goes through a cycle and get warm. The ice will start melting and create a mess when the freezer start to cool agian. Temperture in frig and freezer does not hold cool.
Unplug, empty, clean and let set for 24 hours to defrost the cooling coil that is froze solid overwhelming the heater and not letting it work. if the air can't circulate it will not cool. Check door gasket, or tell kids to stop holding the door open as this will cause it to frost up and cause the problem you're having.. Trust me, It works.
Jun 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Jun 09, 2009 | Heating & Cooling
Thermostat ?
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
