Question about Toshiba E-studio 550 Copier - Fast, Reliable, Works Great
C41 Error on Toshiba E-Studio 550
My model was manufactured in 2005 (after Toshiba fixed the fuser contact issue) ... I have replaced the following: - PWA-F-LGC-340 - All thermisters - All fuser harnesses - Transport harness & sensor - Fuser thermoswitch And reset fuser error via 0+8, 400, 0 (with door open) Please, does anybody have any suggestions, thank you.
  • Mark Moskowitz
    Mark Moskowitz Apr 15, 2014
    And I also confirmed that J611 is connected
    Sergeant:
  • 294 Answers
Get a decent piece of equipment. WHY would you throw money away on a bad copier?
Posted on Apr 15, 2014
How to remove c41 error toshiba estudio 225
C41Fuser theWhat does c41 mean C41 is fuser error...u can clear it using 08-400, reset any value to "0" ...If occur again, u need to check the fuser unit, especially themistor.
Jan 02, 2017 | Toshiba E-Studio 225 Multifunction Copier
I have atoshiba e-studio 167 machine wich shows error code C41
Hi
The error means that the thermistor or heater abnormality at power-ON.
i think you should contact the provider.
Error Codes Toshiba Studio 167 Code C41
May 23, 2016 | Toshiba E-studio 167 B & W Copier....
Toshiba e studio 225 c41 error comes
C41 is fuser error, enter 08-400 to clear the error, if still persist, check the fuser unit especially thermistor, heater lamp...
Jul 15, 2015 | Toshiba Office Equipment & Supplies
How to fix error c41 toshiba e-sdtudio 18
I am unfamiliar with the e-studio 18 but on other Toshiba e-studio models C41 is a fuser (hot roller) error and it will clear itself when the problem is corrected, there is no reset procedure. I would go back and be sure that the replacement was done correctly.
May 17, 2014 | Toshiba Office Equipment & Supplies
E studio 520 code c447
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0." also 447
Jan 17, 2014 | Toshiba Office Equipment & Supplies
TOSHIBA E STUDIO 207 ERROR C 44
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jul 08, 2012 | Toshiba E Studio 207
Hello, I turn on my Toshiba E-Studio 166 Photocopy Machine and it shows an Error Code C 41, please how can I fix this problem?
Poor contact of the fuser drawer connector may cause the following
error codes: C41~C46, C4A, CD5, E01, E03. To correct this issue, a
spacer (see SPL p25 item 1 attached) has been added between the
fuser connector and the frame; also the springs (see SPL p24 item 8
attached) have been changed to provide more tension.
This change has been applied since January 2003 production:
e-Studio 550 TA314824
e-Studio 650 WA312627
e-Studio 810 XA311627
Model P-I Before Change After Change
e-ST550 25-1 --- 6LA14365000
e-ST650 SPACER-DRW-CNCT
e-ST810 24-8 6LA08946000 6LA14468000
SPC067-070-140 SPC068-080-160
Jan 26, 2011 | Toshiba e-Studio163 Copier
I have a Toshiba studio 45 with error code c44, what can I do ?
You should apply to service Toshiba.
The Possible faults in lamp of the heating, thermistor, contact of the elements of fuzer or in signal of the controller of the direct current.
C41 Fuser thermistor, or no heat C43 Fuser thermistor problem or other fuser problem, after machine goes into ready C44 Heater problem
Oct 07, 2009 | Office Equipment & Supplies
ERROR C41
Well I Have BAD NEWS !!!!!!!!!!!
this error code indicates the your fuser is no good
and needs to be rebuilt - or this is what we would do , and this error indicates that your fuser isn't warming up to it could be a thermistor ,lamp or a thermo fuse. I would have the fuser rebuilt entirely this problem just doesn't happen with out Fuser wear and tear.
your welcome to call us if your in the Ct area. Make sure you tell the Service Company
( Toshiba independant or authorized like our self doesn't matter make sure he rebuilts the fuser assembly.
Jul 24, 2009 | Toshiba e-STUDIO 16 Printer
Toshiba E Studio 35 error code C41
 C41 refers to Poor contact of the fuser drawer connector.
 Fix it!!!!
Apr 16, 2009 | Office Equipment & Supplies
Toshiba E-studio 550 Copier - Fast, Reliable, Works Great Logo
106 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
