Question about Canon imageCLASS Office Equipment & Supplies
Prepare toner cartridge error - imageCLASS Canon Office Equipment & Supplies
spinal
  • 287 Answers
SOURCE: Clear Error Message
Hello Bruce,
I want to help but I am a bit confused. First of all just to provide you with additional info, there are basically three criteria that cause a need to replace the drum. One ,as in your case,is when the waste toner level reaches a level that the waste toner sensor gets covered with toner and it gives you the prompt you received. What happens is that despite the fact that in an ideal world ALL of the the image that is formed on the drum to be transferred to the paper actually does transfer completely and therefore no waste. Real world is that a small portion of the image remains on the drum and is cleaned off and deposited "into" the cavity of the drum where the waste toner receptacle resides and the waste toner sensor does as well. Once the waste toner sensor sees an excessive level it generates the prompt you received and the cpu begins to count pages (and I'll be d$%&ED if I can find the exact number) and if the drum is not replaced the device will give an error code and shut down. We will return to this topic in a moment as it is truly the source of our dillema. The second reason to replace the drum is that copy quality has turned to ****. The 1023 drum is good for........laugh with me as to how they determined this number, 26,900 copies. Not 26k. not 27k. Collective ROFL. This second criteria manifests itself in just crappy looking copies, and the end user calls for copy quality problems. The third reason is the abstract. For example a foreign object damages the drum. This includes the human hand.LOL.
So, after all that hot air I just expelled I am at a loss as to why you are still getting an error message. The new drum should have satisfied all the requirements as the waste toner sensor is happy now, and there is no counter that needs to be reset. I am sorry that I could not be of more help. I know you will cuss me for saying this, but, power off and power on and see if that helps. And we cannot eliminate the fact that the waste toner sensor that resides in the drum unit is bad. Entirely possible.AND...remember that the cpu is counting only sheets of paper not toner usage. So if the copier thinks the waste toner is full, and it does not "see" that everything is ok now, it will give you an E-19 error code after so many sheets of paper pass by. I looked in the service manual and could not find a finite number of copies after the waste toner sensor gets pissed. Then the machine goes wheels up. If I can help further(like I helped alot this time) let me know. ...........SPINAL.......
Posted on Jul 19, 2008
rajdeepdutta
  • 2517 Answers
SOURCE: Put in a brand new
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Aug 22, 2010
SOURCE: Canon ImageClass MF 6550 Error Toner Low- Prepare New Toner
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
Posted on Apr 26, 2011
prashant2012
  • 1127 Answers
SOURCE: Error: "Toner Low prepare new
Hi
May be u can;t use the original cartridge please buy the Canon Center and try again
Posted on May 05, 2011
  • 49 Answers
SOURCE: Cannon ImageClass mf6590 toner cartridge issue
this may clarify when you do and don't need to change toner:
http://www.quikshiptoner.com/catalog/canon-mf6590-toner.html#When_to_Replace_the_Toner_Cartridge_in_a_Canon_imageCLASS_MF6590_Printer
Posted on May 26, 2012
Error message says "prepare toner cartridge" not sure why
This tells you that it is about to run out of toner so if you dont have an extra, you need to get one.
Oct 08, 2014 | Office Equipment & Supplies
What does prepare toner mean
If the printer is a Samsung, then it means the toner cartridge is reaching its end of life, you need to have a new toner cartridge ready to replace the empty cartridge.
Featured products
Sep 30, 2014 | Office Equipment & Supplies
Prepare toner cartridge message
I believe it's a counting sensor ( or something like that) look up your model on google, and 'reset counter', should have instructions might be as simple as taping over a lever inside printer
Oct 31, 2013 | Canon Laser imageCLASS MF4880dw Wireless...
Black cartridge error
First, check to see that a toner cartridge is in fact installed.
Open the toner access panel and remove the cartridge.
Check to see if it is indicating that it is empty. If so, replace the toner cartridge and wait for the error message to clear as the machine prepares the new cartridge for printing.
Dec 20, 2012 | Lexmark X4650 InkJet Printer
Hi
May 05, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Display fax gives a warning "received in memory" we also have a warning "prepare black toner" We can not print the fax! What can we do?
Generally the "received in memory" message is a result of the machines inability to print. I.E. It received a fax, attempted to print it, failed, and then stored it in memory to print once the issue has been corrected.
The Prepare Black Toner error is likely directly related. If the toner cartridge is empty, inserted incorrectly, or damaged it could be causing this error. Try reseating the cartridge by removing and reinserting. If that doesn't clear the error try replacing it with a new Canon branded cartridge.
As soon as you correct the printing issue the stored faxes will print.
May 03, 2011 | Canon MF8180C Color Laser MFC Printer
I own a ML-2525/XAA and have a blinking light on the right hand side of the unit. It looks like: <--->/(a triangle with an explanation mark inside it.
Per your user manual, here is a list of all the LED status':
Jam (b-error.png)
Orange
On
A paper jam has occurred. (See Clearing paper jams.)
Online/Error (b-online.png)
Off
  • The machine is off-line.
Green
On
  • The machine is in power saver mode.
  • The machine is on-line and can receive data from the computer.
Blinking
  • When the LED slowly bilnks, the machine is receiving data from the computer.
  • When the LED rapidly blinks, the machine is printing data.
Red
On
  • The cover is opened. Close the cover.
  • There is no paper in the tray. Load paper in the tray.
  • The machine has stopped due to a major error.
  • Your system has some problems. If this problem occurs, contact your service representative.
  • A toner cartridge has almost reached its estimated cartridge life[a]. It is recommended to replace the toner cartridge. (SeeReplacing the toner cartridge.)
Blinking
  • A minor error has occurred and the machine is waiting for the error to be cleared. When the problem is cleared, the machine resumes.
  • Small amount of toner is left in the cartridge. The estimated cartridge life[a] of toner is close. Prepare a new cartridge for replacement. You may temporarily increase the printing quality by redistributing the toner. (See Redistributing toner.)
Feb 28, 2011 | Samsung ML 2525 BW laser Printer
Samsung 1915 printer: the red light with the double artrows and the exclamation in a triangle is flashing. What's up? John
1. A minor error has occurred and the machine is waiting for the error to be cleared. When the problem is cleared, the machine resumes.
or
2.Small amount of toner is left in the cartridge. The estimated cartridge life[a] of toner is close. Prepare a new cartridge for replacement. You may temporarily increase the printing quality by redistributing the toner.
Nov 01, 2010 | Samsung LASER Printer
I have the same question. If you get an answer please send me a reply. aste2426@aol.com Thanks!
Sep 22, 2009 | Canon ImageClass MF5770 Laser Copier...
Dec 17, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
26 people viewed this question
old marine
old marine
