Question about Murray Garden
Briggs 5bsxs 5012vp
No fire. Need a coil. what is the part number for this coil.
    Scholar:
    New Friend:
  • 92 Answers
2 Suggested Answers
jdlipscomb41
  • 157 Answers
SOURCE: MTD Riding Mower with 21 hp OHV 1/C
the valves need adjusting
Posted on Sep 18, 2009
B&S 5BSXS.5012VP 18hp, runs well for approx. 15 minutes then dies as if out of fuel, spray fuel into carb opening starts and runs for few minutes before quitting again. Any suggestions?
check for fuel flow to the carby
the fuel line /tap has a small filter in the tank or the tap corrodes internally blocking fuel flow
check that the tank cap is vented properly
May 27, 2017 | Garden
Only firing one cylinder, replaced both plugs and one coil? What else could be causing this?
Justin, Did you replace the right coil, are the leads good,
Are both the triggering magnets still in the fly wheel,are they clean? Touch any piece of metal to both of them and make sure they are equal strength or close to it. If one magnet weak replace.
Twin cylinder briggs and stratton not firing on 1 side
22hp twin Briggs running on one cylinder at idle MyTractorForum com The...
Lawn tractor 1 cylinder not firing General Discussion Forum In Depth...
Briggs 422707 Firing one cylinder
Feb 09, 2016 | Garden
I am putting a briggs 5bsxs.7242vf in another mower and need wiring
Get a wiring diagram from mowers and compere
Jun 13, 2015 | Garden
I have a brings 20hp 5sxs.5012vp and i can't find intake an exhaust valve lash spec can u help please
hard to say without the engine seril number but its going to be approx 0.06" on both
Apr 25, 2015 | Briggs & Stratton Garden
Dear Sir, I noticed that you may help me with a diagram. I need the governor linkage diagram if possible for a Briggs & Stratton 18 Hp OHV Family: YBSXS.5012VP 274826 This is all I found on...
If you do not get any help here, try:
mytractorforum.com
You will have to register to post your question, but it is a free site and you may be able to find your answer without registering.
Aug 15, 2010 | Garden
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Craftsman lawn tractor briggs 19hp engine, no fire to the plugs, has new coil, new plugs, seat switch, could it possibly be in the stator?
try disconnecting the black ground wire from the coil,if it starts or fires then it is a saftey switch,then it is a process of eliminating the bad switch.
Apr 22, 2010 | Briggs & Stratton Garden
Briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Oct 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
128 people viewed this question
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
