My Electrolux Front Loader stops mid cycle and then resets back to the start! It cannot finish a load?? There are no error messages being didplayed!
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 13 Answers
This may be a circuit board problem whenever it tries to reverse spin or drain some of the water...
what type and how long a cycle ....or does this happen with all cycle options?
Posted on Apr 16, 2014
  • Kirsty Apr 16, 2014
    It happens with all cycle options
  • ricardo cafolla Apr 16, 2014
    Hi Kirsty, assuming that the load/s u have tried are balanced (ie material of same type) and not overloaded you may require a new board I'm afrid, this is not definite, but sounds likely
huuum
  • 750 Answers
SOURCE: error message E31 on Electrolux I-touch front load washer
Hello kleveille
Welcome,
You said, your machine comes on but will not start
I need the model number to start to help you???????????????????
huuum
Posted on Oct 16, 2008
  • 3 Answers
SOURCE: Hi i have a electrolux ewf 1074 front loader. it
Press and hold the 'Delay' and 'Extra Rinse' buttons together and it will 'unlock' your control panel (this is a tamper proof feature for the kiddies)
Posted on Jun 11, 2009
  • 16 Answers
SOURCE: I have a he2 kenmore front end loader washing
Something is in your pump trap, easy fix. pop open the bottom panel by removing the three screws under it. requires a torx bit or a nut driver. if you can tilt the washer back so the front legs are a foot or 2 off the ground, it will make this a lot easier. once open you will see a twist off cap. before you remove this be prepared for the residual water to eject out when you open it. these can not get all the water out so there is always some, tilting it back will minimise this or putting hose clamps on the pump to tub hose can help but not nesesarry. twist it out and clean it out, also stick your fing into the two holes where the trap is located to see if any coins have gotten stuck. once clean, make sure you line up the trap arrow with the base. then button it back up, good luck
Posted on Dec 04, 2009
Testimonial: "Ffantastic, fixed in under 20 mins!!! Thank you"
  • 3 Answers
SOURCE: kenmore he2 front loader washer won't do rinse spin cycle
kappharmd-
if yours is the same, the drain is hidden behind the lower access panel on the front (how convenient, huh?). I don't understand why they didn't just make a recess hole for it. I've just left one screw loose in the center and it kinda "compression" fits. We clean this out regularly, as my wife and family don't check pockets well. :)
Posted on Apr 02, 2010
  • 1010 Answers
SOURCE: When we start a load it will start then stop. We will have to power down then back up, reset all setting & start over....3x! And sometimes it will stop mid cycle & we have to hit pause then st
Could be a bad connection, the control board is at fault
Posted on Mar 20, 2013
Testimonial: "I will check the board area for connection. Thank you!"
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
No water check supply
keep on pressing the start button for 30 second it should reset
Feb 08, 2014 | Hotpoint Ultima WD72 Front Load...
Frigidaire Front Load Washer stops mid cycle
washer stops as i check to see why, It seem's to be the knob. When i touch it it goes back on somtime (temporaly) fromt loader frig
Jul 28, 2011 | Frigidaire ATF6000ES Front Load Washer
Need to reset washer it is stuck in mid cycle and wont continue nor start over
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
cheers
Jul 24, 2017 | GE WBVH6240F Front Load Washer
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Stops mid cycle
that's the washing machine version of going on a walkabout, no? just kidding.
E9 suggests that the line is getting clogged. the filter pulls out(see user manual for that option) and you might want to consider running it with baking soda solution in warm water or hot, once or twice to get rid of that odor.
Mar 11, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
