Question about Philips Televison & Video
I have the 42 in philips 107 model it wont respond
I have the 42 in philips 107 model it wont respond to my ps3 i tried the hdmi and the rca cables seperetly and no luck
  • Philips Master
  • 1,527 Answers
Hi have you tried resetting the ps3, press and hold the power button, you will hear one beep then 2 short beeps release the power button after the short beeps then ps3 should reset hope it helps
regards
shaun
Posted on May 18, 2014
SOURCE: Hooking up a PS3 through HDMI
what you have to to is hold the start button till the TV shows 480i then you will have what you need, it will set up for your tv
Posted on May 03, 2008
SOURCE: I just bought my Philips 32" lcd tv and tried to hook up the ps3
you have to first plug in the s-video before you use hdmi so you can set it to HDMI on your ps3 when you go to your setting. Then it should work. If you already did that and it still doesnt work its probably the HDMI cord
Posted on Jul 29, 2009
SOURCE: hdmi port not working for ps3
believe it or not it might be your tv. mine did the exact same thing and i thought it was my ps3 but who wlda guessed its the tv lol. soo heres what you do. leave ur ps3 plugged in to your tv through hdmi, then all you do is unplug your tv from the wall, and wait for about 20 mins then volia!!!!! hmdi at its best. i do not know how it works but it does and i hav not had a problem since.
Posted on Sep 15, 2010
SOURCE: no sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Posted on Jun 03, 2011
jerrysland
SOURCE: No sound from my AVOL tv
U have to use the Connector labeled RF-1 U have to screw the connector on. I had the same problem
Posted on Aug 28, 2012
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
How do you hook up a playstation to my vizio tv
depending on the age of your play station you may or may not have an hdmi output on the playstation. if youi do then its simple. one hdmi cable from the tv to the playstation and yoiur done. if not, you should have some round color coded plugs on the back of the tv and the same ones at the playstation. they should be just larger than a pencil eraser. these are called RCA plugs or phono plugs. the cables will have the opposite end with pin sticking out. you can go to google images and type rca plug to see a picture.
Dec 24, 2010 | LG 42LC2D 42 in. LCD HDTV
When i go to hook up a hdmi cable to my philips flat screen it wont recognize that i have a hdmi plugged into it. so what could that be the tv? the hdmi works with my other tv though
This model has 4 HDMI inputs, do you get same problem in each HDMI input?
Did you checked HDMI input with any other video source like dvd player or PS3 etc instead of cable box?
Below are few helpful tips to connect HDMI input..
1. Ensure that your HDMI cable is certified.
2. Press SOURCE on the remote control to switch to another source and then switch back to the HDMI source.
3. Reset the accessory device and the TV.
• Turn on the TV
• Select the HDMI channel
• Turn on the accessory device
4. While the TV and the accessory device are powered on, unplug either end of the HDMI cable and then reinsert the cable.
Try above options and if tv still does not show picture of any video source through HDMI then it seems problem of HDMI processor located on main board, visual check is needed by qualified tech or call Philips if tv is under warranty.
Hope these info will help you.
Thanks.
Nov 26, 2010 | Philips 42PFL7403D/27 42 in. LCD TV
Used hdmi on another tv, wont work at home
what kind of cable, is it RCA plug that wont work.
if your TV support HDMI Cable since use the cable for your connection of your PS3 console to your TV at home...
May 30, 2010 | Sony Playstation 3 (PS3) Console
MX 3950D Philips - PS3 no sound
Aside from the xbox360 working via the coaxial digital cable. I got the PS3 to work this way.
I had to use the supplied SCART > (Y-video) (Red-Audio) (White-Audio) cable. Basically plugged this in from the PS3 directly to the MX 3950D Aux (Auxiliary) audio input.
On the PS3 audio settings menu, switched from HDMI to the 3rd option SCART.
Turn on the MX 3950D and set to Aux. Bang, got sound again.
I missed this cause I "assumed" the video/audio cable that came with the PS3 was a HDMI to Audio/Video cable, and didn't even see the SCART port in the back of the PS3. So I thought I didn't want to lose 1080p ..etc etc. Anyways. MX 3950D still good =)
May 18, 2009 | Philips MX3950 System
Mar 30, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
HDMI input
do you have audio out on the tv? if so then yes it will but if you dont then it wont
Dec 21, 2008 | Sanyo DP42746 42 in. Plasma Television
Hdmi connection doesnt work on ps3
By you saying that you have a new cable & tv, I assume you had the console conected tru composite before (red, white & yellow rca cable). This is what you need to do: Connect the PS3 to the tv with HDMI cable only, do not use the composite cable at the same time, reset your PS3 by pressing and holding the power button, when the power is off, for about 7 to 10 secconds, it would cicle from power off, on, then off again, it would also give you 2 sets of beeps, after the power is off, turn your tv on, make sure you select HDMI input on it, then turn your PS3 on, the console would set itself to the best resolution available on your tv. Give it a try!
May 22, 2008 | Sony Playstation 3 (PS3) Console
Cant change my display settings from the 480i input
Whay kind of cable are you hooking it to your TV with...?
The one that comes with the ps3 is only capable of NTSC, or 480. If that is the cable you are trying to use, you will have to get an HDMI cable, or the component cable (the one with 5 rca's plugs, 3 vid 2 audio), as these cables are capable of the full 720 and 1080 resolutions.
Dec 28, 2007 | Sony Playstation 3 (PS3) Console
HDMI PROBLEMS
Ive got a similar problem. My HDTV has a compatibility issue with the ps3 and whenever I enter a game or switch resolutions TV starts flashing between dotted white screen and ps3 screen. I have to remove the HDMI cable and then put it in again in order to fix it. (Or if you are rich just get another HDTV :D)
I would try it in another HDTV (different model and brand) to discard it being a problem with the HDMI port.
Dec 21, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
