Question about Dometic NDR 1292 Refrigerator
Frig does not go below 52 degrees.. Freezer OK
Norcold N821. Frig was defrosted three weeks ago. It would not go below 52 degrees since then. Freezer OK. No error codes noted. Light on elec or gas or Auto OK. what should I check on?
  • rmcphers Jun 18, 2009
    defrosted with heat gun
  • 35 Answers
MAY HAVE PUNCHED HOLE IN EVAPORATOR AND GAS LOW????
Posted on Jun 18, 2009
  • RVREPAIRMAN Jul 14, 2011
    COOLING UNIT COULD HAVE A INTERNAL BLOCKAGE OR COOLING UNIT HAS A LEAK AND ALL THE CHEMICAL HAVE LEAKED OUT, EITHER WAY THE COOLING UNIT HAS TO BE REPLACED., THEY ARE NON SERVICABLE.
My ge GSS22WGMCBB is not getting cold eonough - frig reads 60 degrees, freezer reads 38 degrees. What can be wrong? It's 10 years old...should I get it fixed or replace it?
either the compressor isn't running due to a faulty PTC overload relay on the compressor body or a bad compressor itself,you can test the compressor with an ohmmeter between the 3 terminals on the side of the compressor PTC is mounted,if its ok then it can be a defrost problem where its not melting the evaporator ice and blocking the cold air flow remove the inner rear wall of the freezer and test the defrost heater located below the evaporator coil as G.E. defrost heaters are notorious for failing,if its ok,then the defrost terminator on top of this coil can be bad(open)to test this component it needs to be below 15 degrees temperature to show good(closed) if ok then the mainboard located in the rear back of the unit can be defective because it controls all the units functions
Aug 25, 2012 | GE Refrigerators
Water is slowly dripping from the top of Frig.
The water is coming from the defrost cycle in the top of unit . It drains down at the back of the light cover into a tube at the back. Get a phillips screwdriver and take it down to be sure tube is inserted properly. Get model number and go to.appliancepartspros.com to get a diagram.
May 24, 2010 | Frigidaire FRT18B4A Top Freezer...
I have a whirlpool frig for about 5 years now and as of the last week the freezer is icing up on the left side where the door opens and the refrigerator part doesn't get that cold even with the controls...
Check the following: is the defrost timer cycling. If it is is the heater working, located behind the freezer back panel, defrosts the Evaporator coil that makes cold.
Sep 19, 2009 | Whirlpool Refrigerators
My Norcold DE0051 I have to keep defrosting every 2 weeks
Occasional defrosting is needed on these units. 2 weeks isn't that bad considering the environment that it is in (your boat). Every time that you open the door, moist air enters the fridge, and the moisture eventually collects on the freezer plate, and freezes. Putting foods into the freezer that are uncovered also contribute to this a great deal, as do putting in warm / hot foods before giving chance to cool down.
These freezers do not have automatic defrosters. The target environment typically has limited power available. Automatic defrosters would easily double the power requirements.
You can also check the door seals on your fridge as well. If they are not sealing properly, they can also let in humid air which then causes moisture to collect on freezer plate.
Aug 10, 2009 | Thetford Norcold DE0051 Refrigerator
Frig and freezer wont stay cold,defrosted 2 weeks ago and it was working ok ,but its happening again ice on the coils
change the heating element located in the freezer. It is behind the panel inside the freezer to the bottom. These are known for this.
Jul 09, 2009 | Refrigerators
Frig will not cool
I had a similar problem. One thing that I need to know is is it cooling at all? If everything is operating, but no cooling occurs, you may have a bad board. This controls all of the components. Getting it replaced could be pretty pricey. Good luck, and please rate.
Jun 18, 2009 | Dometic NDR 1292 Refrigerator
PLHS69EGSS1 Freezer not cooling properly but Frig is OK
This is one time you might need gas. Your freezer needs to be 20 degrees or less for the ice maker to work.
May 01, 2009 | Frigidaire PLHS69EGSS Stainless Steel Side...
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Dometic NDR 1292 Refrigerator Logo
534 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
