Question about Canon Mp25dv Desktop Calculator 8077a006ab
Broken decimal Key
Decimal key no longer responding. Tried cleaning with compressed air, no effect. Has the key just given out or is there a solution besides replacing the whole machine?
    Sergeant:
  • 294 Answers
The button can be replaced if you can find a tech, but once they start going it'll be one thing after another. Better to just get a new one.
Who the Hell uses a Calculator any more?
Posted on Apr 15, 2014
4 Suggested Answers
SOURCE: decimal places
How many decimal places are in the answer of this problem? 3.7844236 times 456.93874513
Posted on Nov 10, 2008
SOURCE: Canon F-603 Rounds Off At Decimal
press mode then the dot (.)
Posted on Mar 11, 2008
  • 9 Answers
SOURCE: i cant make the decimal mode work (5000=50.00)
At the top of the keypad area, there is a switch with the following above it: +023F. Leave the switch in the + position and it should automatically place the decimal 2 postions, i.e. enter 5000 and the display will show up 50.00.
Posted on Apr 23, 2009
HP 12 C display does not show entire numbers. How do I fix?
If you mean it is not showing everything after the decimal point, you can change that by pressing the [f] key followed by the number of decimal places to display. For example, to restrict it to 2 places, press [f][2]. If you want to see 4 places, press [f][4].
To show all possible decimal places, use the sequence [f][9].
From the manual (http://www.hp.com/ctg/Manual/c00363319.pdf):
"To display a different number of decimal places, press f followed by a digit key (0 through 9) specifying the number of decimal places. In the following examples, notice how the displayed form of the number inside the calculator - 14.87456320 - is rounded to the specified number of digits."
25096057-rvrejqbjq4zuw4cbinsyjvsy-5-0.png "Although nine decimal places were
specified after f, only eight are
displayed since the display can
show a total of only 10 digits. "
The standard display format, plus the specified number of decimal places, remain in effect until you change them; they are not reset each time the calculator is turned on. However, if Continuous Memory is reset, when the calculator is next turned on numbers will be displayed in the standard display format with two decimal places
shown.
If a calculated answer is either too small or too large to be displayed in the standard display format, the display format automatically switches to scientific notation. The display returns to the standard display format for all numbers that can be displayed in that format.
Sep 12, 2014 | HP 12c Calculator
Decimal point
To switch the radix mark between the US and European formats, turn the calculator off. Press and hold the decimal point key, then press and release the ON key, then finally release the decimal point key.
Dec 29, 2011 | Office Equipment & Supplies
I want to set the decimal place without using the decimal key--example: hit the 1234 keys and the shows $12.34
You can select the A (K . A) and then the # of decimal places (F 6 3 2 1 0) you want. So if you want to enter 1234 & it calculates 12.34, this will work.
Jul 22, 2011 | Sharp EL-2630P Calculator
My screen shows no decimal just a comma..help me get my decimal back....thank you
To switch the radix mark between European and US modes, turn the calculator off, press and hold the decimal point key, press and release the ON key, then release the decimal point key.
Feb 21, 2011 | HP 12c Calculator
Simply problems like .07 times 8.92 give fractional answers such as 1561/2500.
To convert a fraction result into a decimal one, press the S-D key.
You can also configure the calculator to give you decimal results only. To effect that, press [Shift][MODE][2: LineIO].
Nov 30, 2010 | Casio fx-300ES Calculator
I would like to replace the comma between the digits with a decimal.
To switch between the European and US modes, turn the calculator off, press and hold the decimal point key, press and release the ON key, then release the decimal point key.
Nov 01, 2010 | HP 12c Calculator
DECIMAL POINT NOW IS A COMMA WHAT CAN BE DONE TO CORRECT THIS?
Turn the calculator off. Press and hold the decimal point key, then press and release the ON key, then release the decimal point key.
Sep 30, 2010 | HP 12c Calculator
I can't get the answer to display in decimals only fractions.
For converting answers in decimal to fraction or fraction to decimal there is a S<->D key above delete key.If the answers is in fractional form press this key and it will be converted to decimal form.
Jun 04, 2010 | Casio FX-115ES Scientific Calculator
I AM HAVING TROUBLE SETTING THE DECIMAL SO WHEN I PUNCH IN 2502 IT COMES OUT AS 25.02
Have you tried messing around with the decimal setting and setting if to F (floating) or somethings besides 2? This should affect your inputting of numbers however. You're not hitting the percent key (%) by any chance, are you. I don't have this calculator but I'm not aware of any function that inserts a decimal point in a number that you enter (other than the percent key). The decimal setting should only affect the number of decimal points in the answer. Good luck and let us know how you make out. I'm curious.
Mar 07, 2010 | Sharp EL-1197P Calculator
How to get answer in decimals instead of fraction
if you do not want to change your settings There are two ways to foecr calculator to display a result in a decimal format.
  1. Before pressing the [=] sign to get the result press [SHIFT] key. thus [SHIFT][=] displays a result in decimal format.
  2. If a result is already displayed and it is not in decimal format (fraction or radical) press the [S<=>D] key to convert it to decimal.
  3. The [S<=>D] key toggles between formats (fraction/radical to decimal and from decimal to fraction or radical depending on the format used in calculation.)
  4. That does not mean that every decimal number can be converted to fractions/radical.
If you want to have all results in decimal format you can configue your calculator to always do so. All it takes is to set LineIO as the default Input/output format.
Press [SHIFT][MODE] to access (Setup) and select [2:LineIO].
Just in case you want to revert to the other IO mode (MthIO)
Press [Shift][MODE][1:MthIO]
Feb 15, 2010 | Casio FX-115ES Scientific Calculator
Canon Mp25dv Desktop Calculator 8077a006ab Logo
old marine
old marine
