Question about Estate EED4400WQ Dryer
Whirlpool model yleq5000pwo
Hi! How do I open the front panel? Thanks, Raymond
    Sergeant:
  • 294 Answers
You don't, unless you use a cutting torch.
Posted on Apr 15, 2014
  • Raymond
    Raymond Apr 15, 2014
    Thanks! I did'nt start!!! :)
  • Daryl Buck Apr 15, 2014
    Everything on those things are either accessible from the back or up through the bottom. Be organized, they can be a bit of a pain. Belt issues?
Dryer wont start
Part# 3392519 is most likely suspect as needing replacement. Located behind the main panel in the back of the dryer and mounted to the blower housing, long white/slightly oval. These thermostats can burn out for various reasons, it's best to have the home venting system checked by an accredited company to ensure it's properly functioning. Additionally Part# 3387134 should be replaced too.
Apr 11, 2014 | Whirlpool Dryers
Whirlpool dryer mod.yleq5000pwo runs but won't heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 21, 2010 | Whirlpool Dryers
Elite 45986 Front Load Washer: HI My lchild lock was activated on my kenmore elit...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool model leq8858jq1 manual need to
Download this generic manual and use it to re-assemble your dryer:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Pages 24, 20 and 19 cover the front panel, toe panel and top panel.
This should be what you need.
Thanks for using FixYa!
Kelly
Mar 06, 2010 | Whirlpool Dryers
Whirlpool model #WGD5500SQ0 heats up, then goes cold and doesn't heat up again.
Hi, You will need to change the coils on top of the gas valve. They overheat and will not open the gas valve.
Here is instructions on get to the coil.
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jul 10, 2009 | Whirlpool LGB6300 Gas Dryer
Changing my door panel for another colors
Well you can get a stainless steel panel cusot-made at www.applianceart.com. They have a lot of options. One of them is stainless. The options are a vinyl sticker, a magnet, static cling or the actual stainless panel. Most are $39 and the metal is $99 I think. Good luck.
May 27, 2009 | Kenmore 14249 Dishwasher
I'm trying to replace the door catch on the front panel of a Whirlpool Dryer model GEW9868KQ1. I've replace the piece on the door but can't figure out how to get the front panel off.
Hi, You shouldn't have to remove the front panel. Just squeeze the latch hard enough to remove it. I hope this helps. Please let me know if I can be of any more assistance.
Thanks
Vic
May 16, 2009 | Dryers
Whirlpool dryer not blowing hot air
The element is at the bottom of the unit. Usually they are located on the right bottom but when you take the housing off, you will be able to see it.
Apr 11, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool front loader error code f-h ? front loader will not spin
hi thanks for your question. i would check the pump remove the front panel 2 screws on the front panel at bottom remove you will see a big plastic nut in middle un screw but you will get water put a bucket under this nut pull out and clean . this will solve your problem thanks the appliance doc
Sep 24, 2008 | Whirlpool Washing Machines
Estate EED4400WQ Dryer Logo
55 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
