Question about Yamaha Remote Control RXV2500 p/n:WD108500
Replacement remote will not bring up menu on unit.
Everything else seems to work, but the button that brought up the menu on the original remote does not bring it up, nor does any other button. As a workaround is there a way to bring up the menu without the remote?
    Sergeant:
  • 294 Answers
Buy a decent Universal
Posted on Apr 15, 2014
I have a Sanyo Flatscreen, the original remote was lost. Now when I turn on the TV the picture is to big to fit. HOW do I adjust it without the remote?
use the menu button on the side of the tv
that brings up the screen menu
using the channel and volume buttons move around until you find aspect ratio
find the one that fits the screen and press the menu button to save and exit
it could be a pixel setting so find pixel settings while the menu is on the scree and adjust to the correct pixel setting
there are plenty of remotes for tv units on e-bay
all you have to do is select one that is for sanyo led/lcd tv's and read the details to see it it works your model tv
Oct 01, 2016 | Sanyo Televison & Video
Tip
You state, "You need the original remote or an original replacement to use this...
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works: Hold down MENU on the remote and VOLUME DOWN on the TV it?s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
on Jul 27, 2008 | RCA F27664 27" TV
No buttons work on LG 47LG5000. Neither remote nor the TV side buttons work but I can access all features by holding down 2 buttons for 15 seconds (eg. MENU and INPUT held together first brings up the...
check to make sure you have power to unit. If you do you may have a internal power problem. Have you gone thru a recent lighting storm? If so see your home insurance co. For coverage to repair or replace unit.
Feb 07, 2014 | LG Televison & Video
I have a Technika 24in tv / dvd. The remote works fine except some of the buttons do not perform the desired function. i.e. the dvd menu button does not bring up the dvd main menu but a system screen. I...
Hi
The software version decides the function that coincide with remote signal. If the remotes' infrared signal frequency differ to the receiving spctrrum of the software, it won't work well. You must have the remote of the present TV itsef to work in coincide with the button actions. Just get it. There is no other way. OK.
Jul 15, 2011 | Televison & Video
Do I need the orignal remote to bring up the internal menu so that I can program it for all the channels.
no you dont need original remote to bring up menu but there are several replacement remotes you can buy at like wal mart but make sure the new remote carries a menu button on it just read or ask for help on remotes ,,some of them remotes can be almost expensive as a replacement remote ..mat electronicts has a wide sort of replacements remotes for your tv.can find them on line
Apr 17, 2009 | Emerson Televison & Video
Philips Matchline
Under the flap on the remote control, there are two buttons with a line and two arrows drawn between them, press both of these buttons together and the instalation menu will appear, choose automatic installation and in about 5 minutes the TV will set istelf up.
Jun 20, 2008 | Philips 30PW633R 32" TV
Cinego replacement factory remote control will not operate the projector
Go and buy a universal remote with button memory capability. (able to learn any remote function). That works great for me.
Apr 28, 2008 | Radio Shack Cinego D-1000 Multimedia...
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
Remote not connecting
If you still have the original remote for the DMR-E80H, you can switch it back to operate with "1 CHK REMOTE" codes by holding down the "Enter" button on the remote and then press the "1" key.
If you don't still have the original remote, you can try the same steps on your universal remote (assuming it also has an "enter" key that worked with your recorder) and it could work.
Oct 02, 2007 | Panasonic DMR-E80H DVD Recorder
Yamaha Remote Control RXV2500 p/n:WD108500 Logo
55 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
