Question about Mitsubishi WS-65869 65" Rear Projection Television
Mutsubishi Model WD-65733 DLP projection TV- green timer light keps blinking and TV will not turn on
Troubleshooting guide says to push the "system reset" button and light will flash for 1 minute then go out. This has not solved the problem.
ctf1800
  • 4402 Answers
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
  • 1153 Answers
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Posted on Dec 17, 2007
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: i have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blin
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Posted on Sep 26, 2008
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Posted on Nov 29, 2008
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd-65733 Mitsubishi Tv green blinking light and TV will not come on
You need a new projector bulb. Google up your model and buy the best warranteed one you cAN FIND. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!
Aug 13, 2010 | Mitsubishi WD-65733 65" HDTV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
''Mits'' WD-65733 blinking timer light
The green LED is blinking because there is fault in the TV you will have to take to a technician to determine the cause.
SUPER8
Nov 24, 2008 | Mitsubishi WD-65733 65" HDTV
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
