Samsung Eco bubble 8kg is not spinning
Stays on 9 minutes for ages but still doesn't spin
  • 1,511 Answers
Did you check the belts?
Posted on Apr 15, 2014
  • John Rowell
    John Rowell Apr 16, 2014
    The drum turns normally during its full cycle
SOURCE: Kenmore Energy Eco care system won't spin at all
Kenmore ECO Care system front load washer final spinal cycle
won't shut off. Machine shakes violently.
Posted on Jul 07, 2009
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
milten1
  • 1304 Answers
SOURCE: Neptune MAH5500B waon't spin - clothes very wet at
turn back to spin,
and see if you get a lock light,
if your lock is working you will need a new motor control,, and maybe a new motor
Posted on Oct 15, 2009
  • 744 Answers
SOURCE: In the Spin cycle, after 9 minuts, it will stop with a "UL".
"UL" means "Unbalanced Load" - make sure the washer isn't overloaded first or if you are doing rugs, blankets, or lots of jeans, split the load. You can also try running an empty or light load and see how the machine behaves.
If you still have the problem, you may have some issues with the drum bumpers, etc., but try the easy things first.
Posted on Jul 12, 2010
  • 490 Answers
SOURCE: washing machine not spinning or draining water
its your drain pump if you can hear it humming but no water is draining it is blocked or jammed by a foriegn object (most probably a 20 cent coin or bobby pin/s), if you can hear it working as normal but still no water it may have a blockage sumwhere along the drain pipe either that or the impellor has snapped off the shaft and is ratteling around and not actually turning, and with the spin that is directly related to yor drain pump issue as the washer will not even attempt to spin if water remains in the tub, incredibly easy to do hit me back if you want detailed instructions
Posted on Oct 14, 2011
Aquasmart 8Kg washer- spin cycle short
my problem is I did two wash and then I put two thin curtain in to wash and that is when I had this problem
Jul 07, 2013 | Fisher and Paykel Aquasmart wl80t65c
711 Lid lock issues
see this causes:
t doesn't pump or spin
frozen puller, or broken belt, lid switch defective or open replace
It pumps, but doesn't spin
lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, basket worn,
It spins only with the lid closed
for security reason, only spin with the lid closed
Jun 19, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
I Have a Samsung Washing machine model number WF218anb. I can't get it to go through the complete spin cycle. I have taken all the clothes out and put it on spin only and it stays on 9 minutes for a very...
Wow, I have the exact same problem. I reported it under my extended warranty, and the repair shop replaced the drum/bearings without fixing the problem.
I was looking at Consumer Reports today, and some of the people there reported the same thing. Interestingly, some also reported that Samsung told them they couldn't use this washer in places where the temperature got below 60 degrees because it's temperature sensitive, somehow.
But the overwhelming reports on this model are good. I got the whole sequence to run by putting it on perm press -- it spun OK!
Jan 31, 2011 | Samsung WF337AA Front Load Washer
Candy GrandO 8kg Erratic Cycle Selection and Flashing Lights
I can't solve this problem but have exactly same problem with erratic lights. I 'm starting to worry about possible explosion.
Mar 12, 2010 | Candy Washing Machines
I have just purchased an 8KG Siemens front loader
Time to call the selling dealer for warranty service.
Aug 01, 2009 | Dryers
Washing Machines Logo
825 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
