Question about Samsung Heating & Cooling
Red lite on green lite yellow flashing mod #uh 070cav
Unit had a refrigerant leak we fixed can't get it to reset this the error code I'm getting it's not on the code sheet
  • Samsung Master
  • 1,511 Answers
Once you VACUUM the system and refill with Freon and do a gauge test, all systems should go. If you have a strange code, the only source is the factory service personnel.
Posted on Apr 15, 2014
  • Matt Brawner
    Matt Brawner Apr 15, 2014
    Is there a reset switch the code it is giving me now says normal operation however the fan nor compressor come on it's calling for cool the in door unit is running
5 Suggested Answers
SOURCE: indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Posted on May 10, 2009
SOURCE: My Fujitsu a/c unit is not cooling, the error code
I am having the same issue. Can someone help?
Posted on May 23, 2010
hvac1960
  • 2133 Answers
SOURCE: fujitsu asta24jcc error code is 4 x grenn and red
Indoor pipe sensor faulty..Replace it.
Posted on Jan 19, 2011
bugoy31
  • 1238 Answers
SOURCE: MY FUJITSU A/C indoor model# ASU36CLX
Good day!!!!
the manual said that error code is cause of discharged thermistor..
-The detection value of the discharge thermistor is either open or shorted > Compressor, outdoor fan: OFF (automatically
releases when the value is returned to normal)
-Check the thermistor resistance values (refer to thermistor value chart)
-controller pcb defective...
Or try to click this link to see the diagnosis:
http://www.e-comfortusa.com/PDF_files/Fujitsu/12RLQ/Fujitsu_12RLQ_Halcyon_System_2008_Troubleshooting_Guide.pdf
Hope it helps..
Thanks for using fixya..
Posted on Aug 12, 2011
Unit has power bur will not turn on
You need to be specific to get help. Just what is happening? What is not turning on? The compressor? The fan(s).
Is thermostat properly set?
Jun 19, 2016 | Heating & Cooling
What does it mean when your lights flash yellow on my on board charger
yellow means its charging most the time green means charged and red means uh oh unplug it
Jun 16, 2013 | Boating
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
Green "ice size" light is
try to reset your unit to unplug the unit then after a several minutes plug it on then observe the unit.
Mar 06, 2011 | Refrigerators
My ps3 comes on big no green or yellow lite an also black screen
Welcome to Fixya
YLOD or yellow light of death (indicated by the flashing yellow light). When you are Experiencing Problems with the PS3 like this you mainly have 2 options to take.
Option 1
Send The PS3 to Sony
Almost all problems with the PS3 Sony can fix easily if not they will send you a refurbished model.
Price:
If your in warranty they will not charge you for this repair/replace.
If your out of warranty the Charge will be $150
Waiting Time:
4-6 weeks
Sony Contacts right here
Option 2
The PS3 Repair guide
When your suffering problems with the PS3 its often easy enough to fix it at home with a good ps3 repair guide. There famous for fixing major problems like:
The YLOD - Yellow light of death/ Red light error
The Disk Read error
The Hard disk Corruption error
The Red Screen of death - Serious error
PS3 Freeze up Error
PS3 No Signal Error - no display
FIX All error messages
But not everyone knows they can fix simple settings problems like all error messages and the no display error, av and hdmi screen problems and more.
Price: averages between $40 - $60
Wait time: instant download and repair within 2 hours
I really hope I provided you information to fix your problems with the PS3 and get back to gaming soon as possible.
Dec 29, 2010 | Sony Playstation 3 (PS3) Console
At start up the green light turns yellow red light flashes and system powers down. What should I do?
Hi,In order to fix PS3 green light flashing problem you're going to have to do some troubleshooting on your machine. The usual steps of unplugging everything and doing a hard reset apply. These are universal and advisable for any error on any console. If this doesn't work then you're going to have to go a bit deeper into your PlayStation.
Typically you get this error when something is not operating correctly inside the unit. This is different from a display or hardware errors, these still allow the console to be turned on. In the event you need to fix PS3 green light flashing problem chances are something is not working with your power supply.
If the PlayStation 3 detects a problem in the power supply or any other components that might cause severe damage it will not boot. If you want to fix PS3 green flashing light error you need to track down the faulty component and replace it. Do note that this is a safety feature designed to keep the console from overloading and requires some dis-assembly to fix. If you are uncomfortable disassembling your unit to fix PS3 green light flashing problem then you should send it in to get it fixed.
Have a nice day.
Sep 15, 2010 | Sony Playstation 3 (PS3) Console
E11 error. I purchased this camera used and can not get the camera to start. A indicator lite flashes green for a few seconds then red/yellow and shuts down. I have removed the flash memory card and...
Error Code "E11" on Kodak Digital camera means that the battery needs replacement. If replacing the camera recommended battery AA 1.5 volt alkaline or AA 1.2 Ni-MH rechargeable battery still error "E11" the camera needed to be service.
Nov 20, 2009 | Kodak DC290 Zoom Digital Camera
XBOX has flashing red light, need to know how to fix the problem
You should be getting an error code on the screen. Depending on that code, you will need to fix it in different ways. If you're getting a hard drive error, you will need to mod the system with a mod chip and replace the hard drive. if it's an other error, you will need to replace the system. The easiest thing it to buy a mod chip. There are many solderless chips out there for under $40. If the lights are flashing yellow and red, then that means the av cable isn't connected.
Aug 25, 2009 | Microsoft Xbox Console
How to reset red lite on water filter,on front offrig
Press and hold the lock and water buttons at the same time for 5 seconds the green light will flash 3 times when it is reset. Good luck
Apr 23, 2009 | Amana ARSE66MB Side by Side Refrigerator
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Heating & Cooling Logo
111 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
