SOURCE: re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. [email protected]
SOURCE: I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
SOURCE: pulsar chrono model pf 3347
Go here and follow the instructions. The link is a pdf of the manual.
SOURCE: Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
SOURCE: sweep second hand does not return to 12 o clock
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to TAG HEUER watch manuals.Rate me, please..
