Question about Desa International White Wireless Plug In Door Chime
I cannot programme chime for Siemens door chime model JSJS-203
Unit holding battery is ok. Push button door unit will not stay on one chime it changes every time the door push button is used.
5 Suggested Answers
Sec2020
  • 3 Answers
SOURCE: Hello I have now got 2 (two) of these units
This looks like the Heath Zenith SL6162/63
(http://www.1800doorbell.com/db800-wireless-battery-chimes.htm#SL6162)
I have the pdf of install manual if you would like it. This wireless doorbell has over 128 codes that prevent outside interference. Here's part of the manual for changing the code:
Note: Most installations will not require you to change any of the jumpers
on your doorbell.
The doorbell button and chime communicate by using a code that can be
changed by removing and/or adding jumpers on both the doorbell button and
chime. The code is factory set; however, there are 128 selectable codes that
allow you to expand your system and prevent outside interference. Another
wireless doorbell system or other wireless products may cause interference
and the system may not function properly. Follow the instructions below for
setting a new code.
1. Disconnect the power to the doorbell button and chime.
2. Open the cases and locate the jumpers on both the doorbell button and
chime (See illustration).
Attach the back of the
case to the door jamb or
wall. Snap the front of the
button back on.
Holes for
Wall Mounting
595-5611-06 - -
Battery
Battery
Battery
1 2 3 4 5 6 7 8
1 2 3 4 5 6 7 8
Doorbell Button Battery Replacement
Install an alkaline type A23 12 Volt battery. The
positive terminal should be positioned as shown.
* Code Settings 1-7
Must Match Both
Doorbell Button and
Chime
Inside
Doorbell
Button
Inside Chime
3. The doorbell button and chime both have eight different jumper locations.
The jumper positions 1 through 7 are used for setting the code.
4. To change the code, add and/or remove jumpers as needed. There are 128
different combinations. It is recommended to only change one jumper at a
time and then check to see if system is functioning properly. Note: Jumpers
in positions 1 through 7 must be exactly the same for both the doorbell button
and chime for this system to function.
Posted on Jan 13, 2010
  • 4736 Answers
SOURCE: The button you must push
Sounds like the contacts in the button are either dirty or have been bent a little. Try cleaning them and repositioning the contacts if necessary.
Posted on Feb 20, 2011
  • 4736 Answers
SOURCE: I have a desa
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Posted on Mar 09, 2011
  • 100 Answers
SOURCE: I have a door chime
IF its not 1) the battery contact, nor 2) the pin settings (must match in both units and they can come off) if may be broken button unit.
Heath-Zenith (I believe they bought DESA) makes a battery remote push button bell that says its compatible with all Heath Zenith chimes. I bought one at Home Depot and it worked for my SL-6195-RX. (an online doorbell seller and the Home Depot assoc all said it wouldn't work.)
UPC is 16963961975.
Item also shows a code "11G43" on a sticker on the back of the package.
Posted on Jan 22, 2012
Siemens model jsjs-210 door bell manual to chnge radio band
Siemens door chime jsjs-210
Without doubt the worst piece of design I've ever encountered.
The battery housing on the chimer is so large that on closing the lid with the batteries fitted they pop out, nothing holds them in place other than the contact elements - the case snaps shut with quite a jolt and the batteries just pop out...had to use a padded envelope cut to size to keep them in place.
Also the button unit is dreadful - the button isn't actually a button - it's a light, pushing the button just flexes the circuit board and activates a small push sensor on the reverse of the circuit board!?! WHY? A button that isn't a button? The sensor is also too short to touch the rear of the casing and thereby close the circuit - had to pad this out with 2 bits of cardboard...too much it will ring all the time, too little it won't connect.
Please do not buy this product - if you have return it, it is dreadful - and from Siemens it's not even funny.
Apologies for not answering the question directly - I was also searching for a manual for this, to maybe figure out why this device is so badly constructed.
Sep 28, 2013 | Bell Sports Wireless Door Bell with...
Siemens jsjs-208 door bell
Mine keeps doing it. Taking a battery out to force reset on the ringer but mine seems to need this every few weeks. Tried new batteries but still problems.
Mar 19, 2013 | Bell Sports Wireless Door Bell with...
I have a JSJS 203 wireless siemens door bell how do I change the tune?
On my JSJS315 there is a small button (hole) on the back mine is marked S to switch the tunes. When you press it will play the next tune and so on. Hope this helps
Jul 04, 2012 | AT&T Home Security
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
I have a Siemens Wireless Doorbell (Model No. JSJS-204. It started making ringing tones when no one was pushing the doorbell. I replaced the battery thinking that it was wearing out. Now the unit does not...
Hi
To fix the issue you need to remove the batterys from both the bell push and the bell unit for 10 mins, then replace the batterys and then push the bell push so it can switch channels and be different from the house down the road
Sep 17, 2011 | Vacuums
I have a door chime SL-6195-RX with outside door push button. I have changed batteries in both units and still does not work.
The contacts in the outside push button unit may need cleaning. They do get dirty over time. If that doesn't solve your problem you can contact the Zenith Company, who is now is the manufacturer for tech service issues. 800-858-8501.
Hope this helps solve your problem.
Mar 07, 2011 | Desa International White Wireless Plug In...
I have a byron SX85R plug in wireless door bell, i need to change the frequency/ or code, keep false alarming, cant find the instructions , also with the alarm, is a batterie alarm no. SX81R, which came...
From User Guide: Interference from a similar unit operating nearby: a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
Oct 10, 2009 | Bell Cocoon Child Carrier
Desa International White Wireless Plug In Door Chime Logo
Top Desa International Home Security Experts
Steven R
Julian Pearson
Level 1 Expert
Halim Hartono
Halim Hartono
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
