Question about Cameras
Touchstone charger does not charge my hp touchpad
Does not charge touchpad hp, adapter works.
    Sergeant:
  • 294 Answers
POS
Posted on Apr 15, 2014
  • 1,511 Answers
The power cells are not accepting a charge and need to be replaced.
How touch pad that has been flashed over to android and at first it would not charge because I did not have the right charger now it will not charge at all and is taking me back to the flash cyanogen
Touchpads are really sensitive to the type of charger and cable that is required to charge them. I have had trouble charging mine in the past, but the best form of charger appears to be a touchstone.
It might me worthwhile getting a specific USB charger for the Touchpad that provides enough output. A normal phone charger does not have sufficient power.
Quote from another source:
If you have connected your HP Touchpad to the charger only to find that a charging symbol is perpetually displayed, you will probably need to reset the tablet.
This is done by holding the power and home buttons at the same time for around 15 seconds. During this time, the tablet should shut down, restart and then boot into the installed operating system - albeit with a very low charge.
Mar 21, 2015 | HP TouchPad
Touchstone does not charge touchpad
Either the docking station has failed, or the pwer cells are bad.
Apr 15, 2014 | HP Dock / Cradle
My HP TouchPad will not charge.
Looks like the internal battery is shot. Contact HP for price for replacement of the internal battery,
Apr 13, 2014 | HP Tablets & eReaders
Touchpad User Manual
while plugin , try holding power and home button for 1 minute.
also try replacing usb cable.
if your not using the original charger (black barrel shape) you will need to charge it for 24hours
May 06, 2013 | HP 9.7 Touchpad Tablet, 1GB Memory, 32GB...
Not chargeing or wont come on can anyone help
Remove the battery and replace it now try charging. If it still does not charge try charging the charger. If it still doesn't charge check in with charger port.
Oct 27, 2012 | HP TouchPad Wi-Fi 32 GB 9.7-Inch Tablet...
While charging my laptop , mouse pointer cant work and while it. why?
Hi avinamit,
I saw your question and I think I can help you with your concern.
you mentioned that when you connect your charger/Adaptor tp you laptop that the touchpad will not respond or move, I believe that your machine may be experiencing a small amount of ground from the adaptor to the touchpad, here is what we need to do,
  • First we need to turn your Laptop OFF
  • Once turned Off, remove the battery from your Laptop and unhook/remove the AC adapter/Charger as well.
  • Once the Battery and the Adapter is remove from the system, press and hold down the power button for 10-15 seconds this will drain any power left in the system, by doing this we will be starting the machine up with a new set of power coming from the Charger.
  • Once the power is drained is done connect the Adapter back to the machine and the battery try to power your system ON and check if the touch pad will work now with the adapter connected to your Laptop.
this may help you with your concern about the touch pad not responding when the charger is conencted, but still if the issue still exists then most probably the machine is grounded from the charger to the motherboard thus causing malfunction to some of your system devices.
thanks I hope this helps.
Apr 08, 2011 | Compaq Presario 700 470024-192 Notebook
Hello My HP G60 549DX touchpad started having problems, while the laptop is charging the touchpad wont work(sometimes, not always) and the touch click wont work, i have to use the right click...
It isn't likely that your laptop charger is the problem and it is more likely that is is just your touch pad. So you shouldn't buy a new laptop charger unless you absolutely think you have to. If you do, make sure that you buy it from HP instead of a third party for a lower chance of problems. It's more likely that it's just your touch pad that is faulty.
Mar 01, 2011 | Computers & Internet
My laptop touchpad doesnt work properly when i charge my laptop.
If your new adapter is not compatible with your Acer Aspire in voltage and current, your laptop maybe can't work well. Check your new adapter and ensure if it is the same with the original adapter.
Apr 17, 2010 | Dell F3534 Touchpad
Laptop wont start without battery. its was working with battery and charger plugged in. then just died. a friend of mine has got the same laptop. if i take his fully charged battery the laptop switches on...
Your AC adapter is dead. Look at the adapter after you plug it in the wall, if it is working, there should be a green LED lit on it. If this is the case and it still isn't working, you need to take a volt meter and read if there is output at the connector that plugs into the computer. Either way it looks like your adapter is defective and needs to be replaced.
Sep 10, 2009 | HP Pavilion DV6500T 15.4" NOTEBOOK LAPTOP...
Cameras Logo
20 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
