Question about APC Back-UPS ES 725 Broadband (BE725BB-TU) UPS System
Is there anything that can be done to fix the front outlets? They don't work. Back ones do.
The 3 + 1 outlets in the rear have power and work fine, but none of the front outlets have power. Is there a fix or fuses that need changing? Thank you.
  • 1,511 Answers
If you replaced the battery, then the power transformer is damaged. The Transformer is the device that changes 100VAC to 12 Volts DC to charge the battery. If at any time the Protection (usually a red button fuse on the side) cannot be rest and the new battery fails to charge, and the entire outlets are null, then the transformer has fried. This happens when too much AC power (Surge) exceeds the limits whereby the resistors/capacitors/ and diodes pop.
Posted on Apr 17, 2014
  • 1,511 Answers
The outlets that are used for Battery Back Up need a power cell that is recharged and ready to take over when a power situation requires action. If the battery no longer charges it must be replaced as the outlets will not have any power connection.
Posted on Apr 15, 2014
Testimonial: "We just replaced the battery within the last 2 weeks. And why would the back 4 outlets work and not the front 3? Thanks."
  • Gary R Knuth
    Gary R Knuth Apr 15, 2014
    I meant the front 4
  • Dayton Computer
    Dayton Computer Apr 17, 2014
    The cost is $39 for a new UPS, better purchasing a new system with a year warranty, than messing with an older unit that needs repairs.
Which is the cigarette lighter fuse located on 2014 jeep wrangler
new car, USA car, not export.? mine dont have cig lighters so....
aka, new POWER PORT.
wow books are hard to find on new cars.
real hard or very expensive at techauthority.com
there are 2 way to reach that end.
1: read the FSM , its there.
2: test all fuses.
one is 5min work the test. why fool about , just test them....
a: FSM real expensive
b: hope alldata.com has it.
which one, there are up to 3?
quotes from FSM
located near the bottom of the instrument panel center stack area, below the radio.
or
A front console mounted power outlet is standard equipment and a rear cargo area power outlet is optional equipment on this model. The front console mounted power outlet is mounted inside the center console. This outlet can be used as a cigar lighter or power outlet, but only has 12 volt battery voltage when the ignition is in the ON or ACC positions. The rear power outlet is installed in the right rear quarter trim panel, near the spare tire jack.
amazing huh? and ive not a clue which one fails or what you wish to do with it, (No problem stated, no job stated, or anything)
2007 and newer the wiring is tricky. I have 08 , and with full docs.
here it is in the TIPM under hood, 3 fuses like the book said
m6,7, an dm36.
the lid opens , under lid it tell you same as below.
Feb 24, 2015 | 2014 Jeep Wrangler
My 51" Panasonic CinemaVision rear-projection HDTV
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Aug 12, 2013 | Televison & Video
2000 Isuzu Rodeo aux power outlet on the front dash cooks anything that gets plugged into it
Sounds like a short in the socket. Often times dirt and junk get into the socket and can short out the connection.
Sep 09, 2012 | 2000 Isuzu Rodeo
2005 Honda Odyssey left front power outlet doesn't work.Right one works fine.How do I fix
using a test light check the fuses in the fuse panel then check for power and ground at the socket. if one is missing remove the socket and check for power and ground at the electrical connector. if you have both the socket is bad and needs replacing. if you missing one you will have to check that wire to find were the problem is and repair it.
May 14, 2012 | 2005 Honda Odyssey
My Bernina Activa 240 won't turn on. I checked the outlets and they are fine. I even plugged it into different outlets hoping for something to work and it didn't. Can I take it apart and fix it...
Likely the problem is a blown fuse in the S-Print (power supply). You must have a grounding wrist strap when working with a Bernina Activa. They are extremely sensitive and can easily destroy the main circuit board if you don't use a wrist strap. You can get one at Radio Shack for less than $5. The power supply is the square 1/3 of the machine on the back on the handwheel side. You can remove the power supply by removing the long torx screw on the rear of the machine and tilting out enough to unplug the connector. Then dismantle the power supply until you can get to the fuse. Test the fuse with a continuity tester. If the fuse is blown, buy an exact fuse. Don not deviate. If the fuse is not blown, you may need a new power supply.
Jun 02, 2011 | Bernina Activa 140
Acer x1300, front sound jack is not working, back one works fine, all the usb ports work fine on the front, its only the audio port... any idea's?
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
orbe sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Mar 01, 2011 | Acer (54.AA806.001) Sound Card
Yamaha Amp DSP A-3090 Power/function/Remote
These issues can only be fixed by an audio-tech.
Do a websearch around your area for a repair person
Sep 30, 2009 | Yamaha DSP-A3090 7-Channel Amplifier
Power outlets not working in my 99 Dodge Caravan
check the fuse box then find the fuse of it. it has a label on the box.
Apr 29, 2009 | 2000 Dodge Caravan
Rear wiper does not work at all. front wipers work fine. rear washer works
1. check the fuse to the rear wiper motor
2. check for power to rear wiper motor at the motor (power wire going in to the wiper motor with rear wiper switch on)
If you have good fuses & have power going in to the rear wiper motor...
3. Pull old rear wiper motor and install a new rear wiper motor.
Thank you please drive thru......
Feb 26, 2009 | 2001 Ford Expedition
APC Back-UPS ES 725 Broadband (BE725BB-TU) UPS System Logo
113 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
