Question about Jet Saws
Thermal Overload Switch for Jet JWCS-1o Cabinet Saw
The saw run about 15 to 20 minutes under no load and shuts off. I go in and hit the red button on the On?off switch and it fires back up. Tech thought it was propably the overload switch. Thanks,Pete
    Sergeant:
  • 294 Answers
If the motor isn't HOT when it kicks out you need to replace the thermal sensor is all. If it IS, then the motor needs replacing.
Posted on Apr 15, 2014
Testimonial: "I will test it tonight after work to see if the motor is hot when it shuts down. Thanks for the helpful hint."
    Sergeant:
  • 462 Answers
Could be the distance you are from your plug and the gauge of wire short runs for 14/2 cords draw to many amp try plugging in direct or to a 20 amp plug see if any change
Posted on Apr 21, 2014
  • 1,511 Answers
The safety switch is trying to tell you something. When the protection disconnects it is due to a faulty motor. Many things can be at fault, wires breaking down and shorting, windings going bad, insulation problems, stator and rotor problems, simple over heating and lastly the over-load protection itself can be defective.
Testimonial: "Thanks for the quick response. No easy fix I guess."
rockitman187
  • 2559 Answers
SOURCE: Hitachi c10fr table saw wiring diagram
Here is a hand drawn diagram
Please rate this a fixya
Posted on Feb 13, 2009
SOURCE: I own a Jet Left Tilt Cabinet Saw Mdl 708663PK.
I took the front cover off of the switch and noticed the portion of the switch the off button contacts was fully depressed and would not slide back to its proper position. I lubed (silicone) the slide portion of the off switch and cycled it manually to free it up and distribute the lubrication.
Posted on Feb 19, 2009
RonPark
  • 855 Answers
SOURCE: PM2000 tablet saw won't spin up with 3/4
Check your alignment of the blades, sounds like they are hitting something and will not turn. To check unplug saw and try to turn blades by hand. If they don't turn thats the problem, if they turn check and make sure that the blade is the right type for saw. But if the regular blade works fine you have a binding problem with the dado blades.
Posted on Sep 25, 2009
  • 520 Answers
SOURCE: The belt on my 10"
you need to check your brushes again. something is making contact or shorting out. look at everything carefully
Posted on Jan 03, 2011
  • 38 Answers
SOURCE: Hello. We have a Jet
First things first: Does the blade turn freely? I assume so, since it was in use at the time it shut down.
Second, if the reset is fixing the problem, you may have a shorted winding in the motor. Was there any smell connected with the shut down? Any noise at all?
Here's the best explanation I've found for checking that:
http://www.ehow.com/how_4464121_test-troubleshoot-electric-motors.html
Follow the steps to determine if you have a shorted winding. If you're not comfortable doing this, perhaps you can call on the services of an electric motor repair service in your area.
Posted on Mar 07, 2011
Therma Overload Switch
If you have not supplied enough power (like using an extension cord) the motor sees a big voltage drop, starts drawing a lot of current and eventually overheats. Make certain to use a good supply. JET Tools
Apr 15, 2014 | Jet Saws
Overload reset button on porter cable 10 in table saw
Why this is in sewing machines I will never know.
But this is an example of pushing a saw beyond it's limits. At best you should have cut one post, shut the machine off and let it cool... then go for the next. (Better yet get a friend with a saw mill saw the thing down for you)
I believe you have burned out your motor. Off the store you go....for a new one.
Oct 25, 2013 | Sewing Machines
Older model SI16Wa sliding table saw. Turns off after a few minutes running.
sounds like this has a thermal switch that might be faulty. What is the brand and I will try and find a breakdown, Let me know.
Mar 09, 2012 | Saws
My very old Craftsman 10" Table Saw does not power on. While rip cutting some plywood, I errored and caused the blade to bind. Before I was able to power off the saw, the motor stopped. I thought I had...
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Aug 13, 2010 | Craftsman 10" Table Saw
Table saw cuts off
Probably the overload trip is set to too low a current. Either this or it is faulty.
It is just possible that there is dust in the contacts which causes a bad contact but it is more likely to be the overload trip.
Jun 02, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Saw kicked out on overload,reset buttion will not reset
did it trip your outlet breaker? check breaker with volt ohm meter. hope the motor didn't go to ground.
Jan 19, 2010 | Jet 708663PK JTAS-10XL50-W1 10-Inch Left...
8amp Super Saws all-shuts off after a minute of use-no power
It's probably tripping the thermal overload. You may try blowing it out good, might be full of saw dust if your cutting lots of wood.
Jul 12, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Motor stops after about 5 minutes of running
What are you cutting? What type of blade, power supply, etc are you using. It sounds like the thermal overload is cutting out.
Try looking for a little (red) button on the motor itself that pops out slightly when the motor cuts off.(due to overheating). If you push that in, will the saw start running again?
Mar 23, 2009 | Delta Saws
I own a Jet Left Tilt Cabinet Saw Mdl 708663PK. The on-off switch seems to stick and does not always start the saw. The saw runs normally when it starts. When it does not start, the on switch depresses and...
Feb 17, 2009 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
Saws Logo
153 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
