Question about Viking Kitchen Ranges
New ignitors in Viking range oven do not heat up
Old Viking VGSC 305 range. Oven ignitors stopped working and I opened it up to find large holes in the burner tubes next to each ignitor. I installed new burner tubes and ignitors. Problem is that new ignitors do not heat up at all. The broiler ignitor works fine. Any ideas on what might keep the oven burner ignitors from heating up? I have replaced ignitors several times before without any issues. Thanks.
    New Friend:
  • 47 Answers
Serial number break will help if it's ooen or sealed burner. Go from there. Or distribution at 800.488.9868
Posted on Jan 16, 2015
    Novelist:
  • 150 Answers
You will need to measure for 110 VAC at the control switch located on the thermostat. Pleazer Appliance...
Posted on Apr 21, 2014
Testimonial: "Thanks. I have a voltmeter and if I understand you I need to check the 2 wires on the right side of the oven that lead into the wall and up to the thermostat. So positive lead of voltmeter to one of these wires but is other lead on voltmeter to wire from left side (leading to safety valve) or to oven wall itself. Thanks for the help."
Raphael11
  • 54 Answers
SOURCE: The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Posted on Jul 14, 2009
MNTECH
  • 1543 Answers
SOURCE: JGBP33 BAKE IGNITOR
You did not post a complete model number, but this should help:
Take racks out of oven. Remove two screws at the very back of the oven bottom. Lift back side of bottom up and back a bit to remove oven floor. Remove flame spreader (one nut at center). ignitor is at the back left of burner, most likely a WB2X9154 (round style) ignitor. The entire burner can be removed rather easily at this point if you remove the two screws at the front and disconnect the ignitor wire (if you wish to have easier access to ignitor mounting screws.)
Posted on Nov 23, 2008
catriver
  • 878 Answers
SOURCE: Oven will not heat up.
eerb, most likley your ignitor failed. When you turn the oven on to bake you should hear a relay click on the electronic control (clock). You can do a couple of things here. If you have a ohmmeter the ignitor should ohm out at between 50 and 150 ohms. You can physically swap out the bake and broil ignitors to see if the ignitor comes on in bake. Or you can swap the bake and broil wires on the board. They should be marked BA and BR. This way when you turn on bake, the broil ignitor should glow and verify you have power going to it. Carefull when testing, be sure to kill power to the range before any changes. Catriver...post back
Posted on Dec 12, 2006
SOURCE: viking oven won't heat
Igniters need to be replaced
Posted on Aug 26, 2008
SOURCE: burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Posted on Dec 14, 2008
Calibrate oven
i couldn't find your model on the sears site,every viking stove i've worked on had two ignitors,if one of the ignitors isn't working correctly could cause heat changes in the oven.if you pull out the racks,then remove the side rack holders,lift up the floor so you can see the ignitors,start the oven,as soon as the ignitors start to glow time them,if they don't ignite the flame within 40 seconds the ignitor is bad.if this is the problem you don't have to calibrate the oven.also if the ignitor or both are bad check the burner tube to see if there's a hole in it.my friend john had trouble with his oven,i went over,had to change out both ignitors and both burner tubes,the ignitors weren't working correctly and burnt a hole through the tube.so check the ignitors first,if you want to calibrate it look at your manual and it should tell you how to do it,or oull off the thermostat knob,look on the back there might be screws there to calibrate it or if there's a hole in the shaft in the shaft that you pulled the knob off of you might need a small screw driver to stick in there,turn it slowly and not to much to the right to increase the temp.hope this helps but start with the ignitors,they are usually the problem.
Dec 18, 2011 | Viking 30" Dual-Fuel Range, VDSC3054B...
Oven will not heat
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 06, 2011 | Viking VGSC366-6B Gas Kitchen Range
Viking gas oven model # VGIC3656BSS, serial #022404-2919 takes FOREVER to preheat up. Sometimes in excess of 40 minutes. Been a problem for a while. Looks like flames at bottom do not increase when oven...
When increasing the temp. on a gas range the oven's burners do not increase flame size as the cooktop burners do. It just keeps the burner lighted for a longer amount of time.
First if you can see the burners do they light within about a min. or less. If no you probably have bad igniters which are not lighting the burners as quickly as they should or they are "opening up" (stops working) when they get too hot. In this case replacement of the igniters should solve the problem.
Second if it lights quickly but still takes a while to heat; you want to look at the burners to ensure that the flames are down both sides of the burner tube and not dancing around too much. If only part of the two sides of the burner tubes are lighted then a pluged orifice or burner tube is the most likely cause. Once cleaned it should work fine.
As with anything mechanical there are numurous possiblities for something not working correctly and above are the two most popular reasons that come to my mind.
May 17, 2011 | Viking VGRC485-6 Gas Kitchen Range
Our Viking oven is not heating up? what can we try before calling for service? It is only 2 years old.
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 11, 2010 | Viking Ovens
Turned on oven to 400. When opened door no heat. Checked that I had turned the right knob and saw the oven light doesn't come on either. Ugh!! I need my oven. All six burners work but need to be lit...
Just because it glows that does not mean it is not bad...
heatman101
Aug 31, 2010 | Viking VGIC365-6B Gas Kitchen Range
Oven out/flat top has hot spot/burners ticking everywhere
heatman101
Jan 11, 2009 | Viking VGRC605-6 Gas Kitchen Range
Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Jan 09, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Burner ignitor will not turn off after the burner lights Viking
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Kitchen Ranges Logo
321 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
